Question about Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television
I replaced avi main board now the tv doesn't work at all the lamp doesn't light at all
  • Samsung Master
  • 3,204 Answers
Check that you have put the door back on the light as has a switch tha the door being put back on must contacted so the tv can be turnd on.
Posted on Oct 23, 2013
Sony projection tv...Screen blinks on and off to black several times a minute...audio and everything else is fine
It sounds like either the inverter board or lamp are the problem. I would sway more towards the inverter as when the lamps die they normally do it properly.
Jan 13, 2017 | Sony Televison & Video
I have a sharp aquos lc-37d44u and I have the blinking green power light problem I replaced the backlight inverter board still nothing and the only thing i.think it could be is the lamps but Don't no
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. Check all the CCFL lamps for darkened ends. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Oct 27, 2016 | Sharp Lc-37d44u LCD Tv
Horizontal lines on screen of sony tv
Back - light problem. Damaged CCFL lamp/s. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
Feb 03, 2016 | Sony BRAVIA KDL-46EX720 46" 3D LED-LCD TV...
Tv stays on for 15-20 minutes and then picture blacks out, Can't turn back on. Unplug and plaug in again but still only last 15 - 20 minutes. new lamp, no difference.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Jun 05, 2017 | Hitachi 62VS69 62" HDTV
Dynex dxlcd32 tv not working
No, DX-LCD32 has a known problem with both the inverter and the CCFL lamps or, to be precise, the connections of those lamps, which tend to rust, desolder and break contact.
Doesn't mean that's the problem your TV has, but I am just noting that it is not the main board they are known to have a big problem with.
And the symptoms you describe would rather suggest a functioning main board than a bad one.
Lack of sound is probably simply because you're not having the TV on the right AV input.
Sep 30, 2012 | Dynex Televison & Video
Samsung hlp6163w dlp tv not working, new lamp, new ballast, still three blinking lights
If color wheel does not run lamp will not fire----with lamp removed have you looked at the wheel----if not running it will cause almost instant shutdown of lamp and the set.
If the DMD board is bad time for a new set as it is well over 500 .
Mar 28, 2012 | Samsung HLP6163W 61" Rear Projection...
The LED indicator is flashing/blinking we replaced the lamp and it will not still turn on. someone suggested the cooling fan? Thank you Shawna2735@Gmail.com
If Fan is running when you turn TV on and keeps running then its OK ,Ballast Board is what turns Lamp on, Is Lamp Lighting at all?
Encompass Parts Distribution has Ballast board for $62.00
Be sure to give the whole model # to TV Ending in WXXaa
WAX/XAA or WX/Xaa HLR6167wxxaa or wax/xaa or wx/xaa
1-800-638-3328 You can also go to their website and type in your model # for List of Parts and Free Service Manual.
Sep 28, 2010 | Samsung HL-R6167W 61" HDTV
Sony kdf-42e2000, lost picture and the 3 red lights started blinking. I did all the troubleshooting that have worked in the past, but no luck. Any ideas???
Maybe it's time to replace the lamp, have you ever changed the lamp on the TV before? If not, I recommend you do it, because it might be the main issue. Another thing can be the inverter board but you'll never know until you put another lamp in the TV and see for how ling it works, If it lasts less than 4 months, it will definitely be that board.
Dec 06, 2009 | Sony KDF46E2000 46" Projection HDTV
My color wheel apparently went out so i had a tech replace. when i got it back it worked for a few hours and the turned off and flashed the 3 leds. so i figured it blew the lamp. replaced that. still...
ballast or smps board (power supply board) or the main board. Had same problem, replaced lamp, ballast and power supply, worked for 2 weeks now front lights flashing again. ordered main board per samsung tech. support.
Nov 05, 2009 | Samsung DLP HL-P5663W 56" TV
TV picture and sound goes off--leaving a blinking green light showing as on (power). Several times in the last week I have shut the power strip off and then on again and the TV went back on with the solid...
If TV goes off and the led stays blinking, that is because the TV is going on protection.
Protection is a special diagnostic mode that starts when an internal fault has been detected.
If this happens erratically while you are watching TV, then parts that can commonly cause the problem are PSU board, main board or digital board, ballast board and converge board on DLP, inverter on LCD, low buffer and sustain boards on plasma.
May 14, 2009 | Televison & Video
Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television Logo
16 people viewed this question
Henry  Thomas
Henry Thomas
