Question about Dometic Refrigerators
Dometic model RM2663 Bo Blowing fuses
  • 48 Answers
Need more information. If its new it might be drawing more amps than your circuit is rated. If its a new problem with an existing unit then you either have a grounding issue due to an open motor winding or bare wire to metal. A loose wire connection can also cause this issue. Does it run for awhile then blow the fuse or does it blow the fuse when it tries to cycle?
Posted on Oct 21, 2013
5 amp fuse keeps blowing on ac input into cir. brd. on norcold model 6162
shorted heater element unplug and see if it still does it if still shorted board
Jun 17, 2014 | Dometic RM2652 Refrigerator
I have a duo therm model 57915531. i have checked the breakers all the fuses and the thermostat. i have found a 3 amp fuse in the control panel of the roof unit. this fuse was blown. i replaced it and it...
That unit has a thermostat I believe and 12 or 24 volts to power it. The 3 amps tells me it may be either line or low voltage, see manual. the fuse blows due to a short in the control circuit, a transformer if low voltage.
Sep 10, 2011 | Dometic Rooftop RV Air Conditioner
Dometic rerigerator won't work on electric keeps blowing fuse on circuit board
Have you tried locating the connectors on circuit board for the AC (hydro) element and removing them from circuit board and see what happens when you turn it on hydro then? Follow them back from element if necessary. If fuse doesn't pop, then I'd suspect a shorted element and change the heating element. Double check fuse is correct amperage as well. If it's a 3 way fridge, make sure it's the AC element and not the 12 volt you remove.
Sep 03, 2009 | Dometic RM2652 Refrigerator
Which fuse is the on that controls the problem, No manual when bo
speed odo is blank and o/d flashes and abs and brake light is on
Aug 13, 2009 | 2001 Ford Windstar
Dometic Air conditioner model 57915-531 blows hot air
Have freon and compressor checked out, could also be bad capacitor
Aug 11, 2009 | Heating & Cooling
Dometic 57915.531 Air Conditioner Blows 3 amp fuse in control box
Steve,
The three amp fuse is installed in the board to protect from shorts or overloads created by disconnecting or reconnecting components when DC power is still connected to the system. If the fuse is blowing, then you more than likely have a short in the 12VDC system between the control unit and the thermostat.
1. Pull the cover off of thermostat and remove the +12 (or +7.5 depending on the model) wire. Access the other end of the wire in the AC compartment. Using an ohmmeter, touch the end of the wire at the AC with one lead and touch the control box with the other (or any ground source). If you get a reading other than OL or Infinity, then that wire is shorted out in the wall somewhere. If not, repeat the steps for the rest of wires except the ground of course. If all of these wires appear to be fine, you may need to take it in for some more extensive troubleshooting.
Hope this helps,
Jeff
Please rate me!!
Jul 04, 2009 | Dometic 57915531 Air Conditioner
Dometic Blizzard 1300 roof top unit blowing fuses
YES< this is a "direct ground and either the motor or compresso is grounded--(DEAD)!and needs to be replaced.
Sep 09, 2008 | Dometic Rooftop RV Air Conditioner
Refrigerators Logo
56 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
