Question about Ace Hardware Power Glide Cordless Hedge Trimmer
Charger for cordless sweeper 60101384 - Ace Hardware Power Glide Cordless Hedge Trimmer
Keeps stopping even though I have taken it apart and checked for blockages. +
Are you sure your wall charger is working ok? You might just have a bad battery pack in the sweeper if your charger is working. Do you have a friend who knows electronics and has a voltmeter?
If so, have them check the voltage output of the charger at the plug that goes into the sweeper. Verify that the charger is indeed working ok. Then you will need to check the voltage on the battery pack inside the sweeper to see if your battery is good and holding a charge. A mechanical blockage could be something caught in the vacuum fan blade. You should be able to hold the main part of the sweeper up to your ear so you can hear and then pull the sweeper trigger and see if you can hear the motor try to start. Nothing happening may mean a dead battery pack. Regards, Dennis
Aug 15, 2015 | Dyson DC44 Animal Cordless Vacuum Handheld...
My Sharp UV617 cordless sweeper is not holding a charge. Should I replace the charger? # is AD-1215-U8
Replace the battery pack, not the charger.
Hope this helps, if it does, please place a vote for me. Thanks,
Handie Andie
Mar 28, 2011 | Vacuums
I need to purchase a new adapter for a Shark Cordless Sweeper model #V1700Z, adapter #KA12D075015023U. Can anyone shed light on this problem. Otherwise I have to through away the sweeper.
what you need is a 7.5 volt DC 150mA charger. If you check on some sites like ebay you may locate one. Another option is you may be able to go to an electronic repair shop and they might make one up for you. You nedd to bring them the sweeper so they know what connector needs to on it. A 7.5 volt is not expensive or uncomon and barrel plugs are cheap also.
Sep 27, 2009 | Vacuums
Want to buy a charger for Shark Cordless Sweeper
If you have the old charger, look at the pin and read the output. Many electronics clearance stores sell a generic charger which will match the output in volts and amps as long as you find the identical pin configuration. Volts may exceed the original battery rating by 20%, amps can as well. IE I have a 9.6 volt charger on my 7.2 volt battery pack.
Sep 06, 2009 | Euro-Pro S3325 Handheld Steam Vacuum
Shark Cordless Sweeper ModelVI1900SI
Solution #1 You helped me out Thanks a bunch!! I just have one thing to add when you go to the site on the left side click on Vacuums then click on Cordless Sweepers in the middle of page their you will see what Model you are looking for ...
Aug 12, 2008 | Euro-Pro S3325 Handheld Steam Vacuum
Ace Hardware Power Glide Cordless Hedge Trimmer Logo
50 people viewed this question
Top Ace Hardware Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you an Ace Hardware Garden Expert? Answer questions, earn points and help others
