Question about Canon PowerShot Cameras
Keypad not working
Canon PowerShot Keypad not working
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 116 Answers
I need more information, but unless a cable got knocked loose inside, you will probably need to replace the contacts under the keypad.
Posted on Oct 21, 2013
My combination will not open my canon safari 24 gun safe
The Canon safe, if not modified, comes with a digital pushbutton keypad that activates the interior release mechanism. Without exact details (clicks?..buzzes?..beeps?..totally dead?) an answer is hit or miss.
Adding to the obvious..a good battery, no visible damage, forgot the combination, wrong button sequence...
1. the keypad only sends the open signal for the correct combination after keypad is pressed.
2. if it accepts the combination (no error beep), is the signal accepted to unlock.
3. is the interior mechanism trying to unlock.
If you can determine which stage is failing..it will determine if there's a fix.
If all three are working, you hear a little click after..the door/lever may have pressure on it.
If any one of the three cannot be confirmed..no entry with the pad!
Oct 07, 2016 | Home Security
Micromax M2 keypad not working
Your Phone Keypad Ic Deafult So Please Change keypad Ic
and keypad Problem Will Solved
Jul 24, 2012 | Cell Phones
My craftman 139.52606 opener does not have a learn button to set pin on keypad. I had keypad working at one time but since I changed the battery I can't rember how to reset the keypad.I also changed...
If the keypad is hardwired, do this:
To program the keypad, first unplug the garage door opener from the electrical outlet. Next, remove the nameplate from the console that the keypad plugs into and locate the program/operate switch. Flip the switch to program. Next, enter your desired four-digit PIN number into the keypad. Slide the switch back to operate and plug the garage door opener back in. The keypad should be programmed.
Sep 02, 2011 | Sears Craftsman LiftMaster Chamberlain...
Needed and put in a new 9V battery in my keypad. The keypad now does not work. Do not see keypad light up when pressed, ???
Sounds like you may have a bad battery if the keypad was working before you replaced it. If the keypad did not work I would suspect it has failed.
Dec 31, 2010 | Sears Craftsman LiftMaster Chamberlain...
The down button the numbers 2, 3 and end call button have stopped working. when i press one of these buttons its shutting the phone down-any ideas or advice please?
Hi, it's the keypad IC or the keypad itself. So you can check the keypad if there is dirts that is stopping the keypad from working. Or the keypad needs to be replaced.
After checking the keypad if the keypad still did not solve the problem,
You will have to replace the keypad IC inside the board of the phone.
Take care. .
Aug 20, 2010 | Sony Ericsson K850i Mobile Phone
Micromax q3's keypad is not working
Aug 01, 2010 | Cell Phones
It will not let me view the pictures I have taken. when i press the play button it goes to a weird settings thing rather than my pictures- i dont know what happened!! HELP!!
hi, kindly check if the button is in correct position. sometime the wrong position of keypad it cuase of malfunction or not working properly.if your camera still in warranty its better you bring to service center and for sure your problem will covered by warranty. But if not try to open your camera and check the keypad rubber if in the right position.
if the problem stiil occur you need to bring to service center for estimation.
goodluck and thank you my friend
Jul 17, 2010 | Canon PowerShot SD780 IS / IXUS 100 IS...
Can only program one remote or keypad. which ever
You are going to have to do a process of elimination. I think you have either a bad remote or a bad keypad. Try programming a remote and then the keypad. If only one works then go with the other remote and the keypad. If only one works then program the two remotes. If the two remotes work then the keypad is bad or if you can program one remote and the keypad then the other remote is bad. Get rid of the bad one.
Oct 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
I want to find out how to set up our Canon CFX0-L4000 fax Machine
CANON CFX-L4000 UNOFFICIAL MANUAL
RIGHT KEYPAD
FUNCTION
SET
01 DATA REGISTRATION
02 DELAYED TRANSMISSION
03 POLLING
04 MEMORY REFERENCE
09 REPORT
11 UP
13 +
14 LEFT
15 SPACE
16 RIGHT
18 CLEAR
19 DOWN
Keys 1-20 are speed dial keys. If speed dial is not set, message is displayed and manually entering the telephone number is prompted. Press STOP to clear.
Pressing FUNCTION accesses the menus associated with keys 1, 2, 3, and 4. After accessing a menu, the cursor keys, SET, and occasionally the telephone key pad are used for selecting options and setting values.
EG. Setting a speed dial number:
FUNCTION - DATA (01) - SET - SET - UP/DOWN to select speed dial number - SET - UP/DOWN to set number/name - SET - UP/DOWN/LEFT/RIGHT/PHONE KEYPAD to enter value - SET
EG. Setting unit telephone number
FUNCTION - DATA (01) - DOWN once - SET - DOWN once - SET - PHONE KEYPAD to enter number - SET
EG. Retransmit from memory (assumes memory light is on)
FUNCTION - MEM (04) - DOWN once - SET - UP/DOWN to select document number (LEFT/RIGHT to view associated telephone number) - SET
EG. Delayed transmission
place document into feed - FUNCTION - TX (02) - SET - PHONE KEYPAD to enter time to send - SET - PHONE KEYPAD to enter phone number - SET - SET - document is scanned and will be transmitted at set time
for full guide you will have to search and purchase one.
May 28, 2009 | Canon Office Equipment & Supplies
Keyboard letters 'm,j,k,l,u,i,o' permanantly locked for numerals. i have no idea how i switched this function on.
NumLock is on. Look for the Fn key in the lower left corner, and lookint in the top right, the NumLock key.
Mar 22, 2009 | HP 2133 Notebook PC
Cameras Logo
21 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
