Question about Samsung Lands Phones
Samsung phone I've a Samsung GT i9003 mobile. I did a factory reset on my phone. Since then i can't make any call or browse internet through mobile network. WiFi and etc is working fine. But no mobile network related matters. Even IMEI No is not showing. Need a solution.. Plz.
You messed up your imei. try this : http://forum.xda-developers.com/showthread.php?t=1264021
Posted on Oct 29, 2013
  • 67 Answers
SOURCE: Hi, I have a Samsung GT-S5320 Toco Lite and need
try this *2767*3855# your data and setting will be erased without warning so back up it first. hope this will help.
Posted on Dec 28, 2009
SOURCE: My Samsung gt-e2120 phone just blinks.
Same problem here... Samsung sucks!!
Posted on Aug 01, 2010
  • 567 Answers
SOURCE: need to unlock my samsung gt-e2120 from o2 network
the universal code you could try is take out the sim power on input # * 7337 # phone resets then its unlocked it may work ?
Posted on Aug 19, 2010
SOURCE: I have a samsung Gt s3370. this is the settings
GT-S3370 puk code
Posted on May 05, 2011
mrmiyagi
  • 119 Answers
SOURCE: I NEED A MANUEL FOR
You can download manual here http://www.cintelcorp.net/samsung-gt-s5830-manual
I hope I helped you, rate my solution...
Posted on Jul 30, 2011
Testimonial: "Many thanks for your help, at last i can now use & understand my phone, thanks again."
My samsung mobil GT- i9003 is locked
Thank you for providing all the info! Greatly appreciated!!
Now on to a solution. You can try to do a factory reset. You don't need to log into the phone in order to do one. However, this WILL erase everything on your phone, and revert it back to when it was originally purchased. Not sure if the unlock will remain.
To do a factory reset:
1) Turn off your device
2) press the power button and the volume up button simultaneously until it takes you to a new menu.
3)Use the volume keys to navigate, and the power button to select (Exact directions are provided on the screen)
4) Look for an option to "Wipe/Factory reset" (Note: It might be located in a sub menu, and not actually on the first screen.)
5) Select that option and press the designated "OK" button. (usually the power button).
6) Phone will reboot and you should be able to get back in.
Hope this helps!!
Jun 22, 2014 | Samsung Unlocked i9003 GT-i9003 4GB Galaxy...
My Samsung GT-i9003 is locked fo pattern lock & email & password lock
  1. first press Up Volume Key on phone and hold it on lock screen.
  2. then press on the home button and hold it.
  3. Last the power button and after it starts up just release it.
  4. A menu will come up.
  5. just click on home button to select up and down in the menu.
  6. go to third option named as "DELETE ALL USER DATA".
  7. It can take up to a couple minutes.
  8. the phone will restart and the unlock pattern problem is fixed.
    *note this will reset phone to factory settings, but it will allow you to access it again.
Micromax master resetting code all
1.NormalReset - Dial *#7780#
If you dial this code in Nokia handset, it will restore system setting without missing phone memory data (videos, photos, songs).
2. .Deep Reset - Dial *#7370#
When this code isdialed in Nokia handset, it will wholly clean internal phone memory. Entire phone settings and profiles will be deleted, but there is no effect on memory card data.
Remarks -
For Nokia Symbian 60 V1 supported mobile handset (7650, 3650, 3600, 3620, 3660, N-Gage)
you can dial *#7780#*#7370#
Latest S60 mobile handsets, you can dial Deep Reset through another way.
*.Switch off mobile handset first.
*.Press calling key (green), 3 and * keys or (Green calling button + 3 + *)at same time and grip them down.
*.You find a message about format mobile and then release these keys.
*. Password of Reset factory setting code will be either 1234 or 12345.
Nokia X3-02 mobile Restorefactory -
*.Go to Nokia menu lists, browse these options one by one-
*.Menu --settings-- Menu--- Restore Factory Setting
*.Insert phone code 12345and wait few moments to complete restore process.
Nokia 5230, 5800, 5233 and similar mobile handset Restore factory settings, how ?
*.Browse phone menu lists,
*.Then, go to
Menu - Settings - Phone -- Phone mgmt Factory settings
*.Insert security code -12345
*.Without data lost of internal memory, Nokia handset returns in original modes.
Hard reset of Latest Nokiahandset through another code -
*.Switch off mobile handset.
*.press and holdGreen (calling) +Red (End call button) + Camerakeys at the same time along with switch on power of mobile handset.
*.Then mobile asks to insert phone security lock code , so insert12345.
Samsung Restore factory code
*.*2767*3855#
*.*7465625*638*00000000*00000000#
*.#7465625*638*00000000#
or
*.Remove SIM card from mobile handset
*.Once off and on handset
*.Type *2767*2878# to perform internal memory reset
*.Insert SIM card again in mobile.
Samsung Androidsupport handset restore factory code -
Type*#*#7780#*#* - To Factory Restore.
Micromax Restore factory code for all version with Android -
You can use any following below code one by one to perform restore factory of Micromax mobile:
*.1122
*.0000
*.1234
=*symphony> 1122
=*nokia >5071 or 0000
=*micromax> 1234
=*tecno > 1234 or 0000
=*samsung> 1234
=*apale i phone >5869
BACK2HOME
Information from:
http://peperonity.com/sites/a--a.secret.mobile.codes/47096442
Terry
Apr 16, 2014 | Samsung Computers & Internet
Samsung i9003 back & option button not working
Samsung gt- i9003 back & option button not working pleas halp
Mar 25, 2013 | Samsung Ybsvine Galaxy Sl Gt-i9003...
Why my samsung galaxy s gt i9003 cell phone reeboot automatically
This is controlled in your settings menu under 'Fixed Dial'. (or similar command). You will need to change this setting.
I do not have a copy of the user guide for your phone but for most phones these are the directions:
When you turn on fixed dialing, you
can call only numbers stored in the
fixed dial list.
Turn fixed dialing on or off:
- > Settings > Security > Fixed Dial
Use the fixed dial list:
- > Settings > Tools > Dialing Services
> Fixed Dial
Jul 31, 2012 | Samsung Cell Phones
My samsung GT B3410 phonecannot access internet,just says Google License Expired
All you need to do is by resetting the factory setting of the Samsung GT B3410 phone and re-figure the browsing setting. for example; GPRS.of the phone.
Nov 16, 2011 | Samsung Cell Phones
Lands Phones Logo
47 people viewed this question
Top Samsung Lands Phones Experts
Don Hart
Jose Ma DM.
Jose Ma DM.
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
