Question about Day-Timer Hardware & Accessories
Utilitec 0144506 - Day-Timer Hardware & Accessories
Instuctions for utilitech 0208812
That Utilitec number does not show up:
Copy following link to help identify Utilitec timer:
http://waterheatertimer.org/Program-wire-Utilitec-LW60418.html
Jul 05, 2012 | Hardware & Accessories
How to set my utillitech time
Timer is not identified.
Check following options.
1) Add a comment and describe timer in detail
2) Open following link for typical Utilitec digital plug-in timer, with links to other Utilitec timers.
http://waterheatertimer.org/How-to-program-Utilitec-0155671.html
3) Open following link for setting Utilitec analog timers by experimenting with features:
http://waterheatertimer.org/How-to-set-timers.html
Sep 22, 2011 | Woods 2C 24 Hour Indoor Mechanical Timer...
The instructions say the TimerMax Digislim needs to be charged. No instructions for that. Also I pulled out the little battery protector and it still doesn't work. If all the plastic didn't come out how...
You posted under a photo that looks like the Utilitec 0144506
See image of timer and timer manual on following link.
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-week
If this is not your timer. add a comment
Batteries for most plug-in timers are internal rechargeable batteries.
They are not replaceable and cannot be accessed.
To charge the battery: plug timer into receptacle for an hour.
Afterward, unplug timer to set timer program
Next, plug lamp into timer, and then plug timer into wall.
Be sure that lamp is turned ON.
If battery does not charge, then display doesn't show. That means timer is busted.
About 6-8 of new timers are defective from the start.
If battery won't charge, then return timer for another one.
Most of these timers work for a season or two, and then you buy another.
Dec 16, 2010 | Stanley 38424 TimerMax Digislim Daily...
How do you set a utilitech timer
Which Utilitec timer do you have?
Following page has instructions for 0192773, with links to 0155671, 0144506, and 014124 programmable timers:
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
Add a comment with your timer ID and I will help more.
If your timer is not shown on link above, add a comment and describe your timer.
I have extensive files on timers.
Dec 03, 2010 | Hardware & Accessories
How to program utilitech 1 outlet daily timer
Do you have the Utilitec number?
Add a comment with description of timer I can help.
I own several Utilitec timers.
Following link shows programming for 4 different Utilitec timers;
http://waterheatertimer.org/How-to-program-Utilitec-0144506.html
Dec 01, 2010 | Day-Timer Hardware & Accessories
I have a one outlet utilitech timer and forgot how to set it ....help
Utilitec makes 2 different plug-in timers.
Utilitec 0155671 is about size of baseball and has 5 buttons and two outlets. Programming is shown on link below.
Utilitec 0144506 timer is small and rectangular with 5 buttons and slide switch located on top of timer. This timer can turn lights on-off once a day and has 1 outlet. 0144506 Instructions are given in steps shown below.
Also see:
Steps:
-Plug timer into wall for 1 hour until rechargeable battery is charged and display shows.
-If battery will not charge, then check electricity to wall outlet, if electricity is good and battery will not charge, then timer is no good.
-Lamp has to be turned on for timer to work. Check bulb if timer stops working.
-Unplug timer to set program.
-Press reset button with paper clip to remove any programming.
-Slide switch on top of timer to 'Timer'
1) Set current time
Hold down Time button
Press HOUR until current hour am-pm shows in display.
Press MIN button until current minute shows
Since this is a one-day repeat timer, no day program is available.
2) Program ON > this is when you want lamp to turn ON
Hold down ON button.
Press HOUR until ON hour with am-pm displays.
Press MIN until ON minute displays.
2) Program OFF > this is when you want lamp to turn OFF
Hold down OFF button.
Press HOUR until OFF hour with am-pm displays.
Press MIN until OFF minute displays.
3) Set timer to operate
Make sure slide-switch on top of timer is set to 'Timer' to run program
Plug lamp into timer, and then plug timer into wall outlet
For manual override, move slide-switch to 'On' and light will stay ON
Nov 27, 2010 | Day-Timer Hardware & Accessories
I have no programming instructions for the Utilitec in wall digital timer. I can't find a website or phone number for the manufacturer. Lowes Home Improvement can't help me. The timer has the following...
I posted a webpage for Utilitec timers that shows instructions and wiring tips.
Utilitec seems to be another pacific rim knock off product with nobody claiming ownership of the product. The body of the timer looks just like Intermatic, with identical markings. That's what happen when we exported all our knowledge along with our jobs. The other guy copied everything, put up a cheap product, exports our dollar for their profit, and never gives customer service.
Oct 14, 2010 | Intermatic Inc. ST01C Digital In-Wall...
I installed the Utilitech self-adjusting timer exactly as shown in the instructions: black to black, red to red, green to ground and white to neutral. It didn't work. I swapped out all of the colors. ...
Here's a Utilitec page with step by step wiring help:
http://waterheatertimer.org/Program-wire-Utilitec-LW60419.html
I've done testing on the Utilitec.
Utilitec timers are made to replace 2-pole switches where one switch (or one timer) controls the lights.
If display shows after wiring timer, then wiring is usually correct
If display does not show, then electricity is OFF
If you are replacing a 3-way switch, the Utilitec is wrong timer
If the wiring is wrong the Utilitec will not function.
If you do not have a neutral wire in the box, the timer will not function
Oct 12, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Hardware & Accessories Logo
Top Day-Timer Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Day-Timer Hardware and Accessory Expert? Answer questions, earn points and help others
