J3 error code duplo 700 burster - Office Equipment & Supplies
2 Suggested Answers
ZJLimited
  • 17970 Answers
SOURCE: duplo v-700 j3 error
Hi there:
You directed this question at me, but unfortunately this isn't my expertise and I am unable to provide you with a real solution at this time.
Hopefully one of other experts will be able to provide you with a real solution.
Thank you for using FixYa.
Posted on Feb 13, 2012
Please help me, I have a Duplo machine DP L500 and it's giving me service call E001. What would be the problem?
    ewol3i Apr 01, 2012
    main motor error..check main motor boards fuse at the back of the machine or the timing belt might be damage
  • Joseph Nov 28, 2013
    check the encoder sensor
ERROR CODE E001 DUPLO DP C120 Duplo Office Equipment Supplies
The manual is here, although it does not mention error codes.
http://www.toshiba-sa.net/Documentation%20%20Duplo/DPL-500/DPL-500_Instruction_Manual.pdf
Duplo machine DP L500 error E001 Google Search
Mar 07, 2018 | The Office Equipment & Supplies
Installed new toner cartridge into the machine. Still getting the J3 error
Toner cartridge and J3 are two different things J3 is jam code something is not correct in the paper path.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Nov 16, 2013 | Minolta EP1031/1031F CS/PRO Copier
Duplo v-700 j3 error
Hi there:
Jan 06, 2012 | Office Equipment & Supplies
Would like to download owners manual for Duplo DP21
YOU CAN DOWNLOAD IT VIA WWW.GETMANUAL BUT HAS TO PAY SMALL FEES VIA CREDIT CARD
Mar 31, 2010 | Duplo DP21L Copier
Duplo DF-520 Error Code
you will find it in the operation guide. i uploaded the pdf copy here: http://www.mediafire.com/view/?7wvzv3jqwcyga1g
Jan 15, 2010 | Office Equipment & Supplies
I have a Duplo DP 43s which is displaying "paper jam at the ejection end" error message. Can't find anything at all stuck in the machine but the sheet passes just past the drum and then stops, so causing...
i don't know if duplo is same as the gestetner type of digital duplicator. try to look if the exit sensor is clean or in good condition and if the paper coming out in a normally manner what i meant is if it is flowing normally.
Nov 29, 2009 | Duplo Office Equipment & Supplies
Got error code e104 duplo DP-460H
We AEBO is professional manufacturer of compatible duplicator ink and master for Riso ,Ricoh,Gestetner,Duplo.
For Risograph : RZ/GR/RA/KS/CR/RN/RP/RZ/TR/FR /GRHD/RPHD
For Ricoh: VT/JP-6/JP-12/JP-500/JP-10
For Gestetner: CPI2/CPI7/Stencil ink 217 /CP15/18
For Duplo: 504/51F4/544/744/ND 24
With high quality at economical price . We have been awarded USA SGS certificate and China Excellent Brand.
AEBO packing ,neutral and your customized packagings are all available.
Sincerely hope a pleasant cooperation with you .
meachell@chinaaebo.com
Jan 08, 2009 | Duplo DP460H Copier
Print head assembly on my Lexmark Optra S 1855 needs to be replaced. My question is what causes the print head to malfunction in the first place?
I guess you're getting an error message which is normally one of the below (causes underneath)
Error Code 931
No first HYSNC Signal
Error Code 932
Lost HYSNC =
These errors usually indicate a
failure in the HYSNC signal to the
printhead. Check the continuity of
the cables connected to J3 and J8
on the engine board. If incorrect,
replace the defective cable. The
voltage at J8-4 measures
approximately +5 V dc. If incorrect,
replace the engine board. The
voltage at J3-7 measures
approximately +24 V dc. If incorrect,
replace the engine board. If correct,
replace the printhead assembly.
Error Code 934
Mirror Motor Lost Lock
Error Code 935
Mirror Motor unable to
reach operating speed =
These error codes indicate a
problem with the mirror motor circuit
in the printhead assembly or the
mirror motor cable to the engine
board cable or engine board
assembly. Check the continuity of
the mirror motor cable connected to
J3 on the engine board. If incorrect,
replace the cable. The voltage at
J3-7 measures approximately
+24 V dc. If incorrect, replace the
engine board. If correct, replace the
FRUs in the following order:
engine board
printhead assembly
Jun 19, 2008 | Lexmark Office Equipment & Supplies
48 people viewed this question
k24674
jasbo
jasbo
