Question about Cyberhome CH-DVD 300 DVD Player
Red light is barley on
~My red light is barley on.It was working 2 years but a couple months ago. It has no power.The door won't open.I opened it with a pencil in the slot.I had to struggle and shove it in.I have no idea what 2 do now !!!!
  • 4 Answers
The CyberHome CH 300 is a good, inexpensive DVD player with a power supply board prone to fail, because of a few weak components, especially if left turned on and not used.
Usually, if the power supply fails, the red light will not illuminate when plugged in, and of course not turn green when turned on.
If you have this specific problem, I can repair the power supply for $20.00. Contact me at FrancisH49@hotmail.com to arrange shipping and return of the repaired board.
Posted on Nov 17, 2007
This is probably a power supply problem. See notes on power supply issues on previous post.
Francis
Posted on Oct 13, 2007
The light on the Garage door blinks but doesn't stay on.
Three blinking lights & door won't close by Candi
(Winston-Salem, NC)
Garage door will not open and close with remotes. Three blinking lights occur when we try to close door. What does this mean? It is a Linear unit.
I will assume you mean that your garage door will open with your remote but will not close. It should close if you press and hold the wall control button until the door is fully closed.
If that is the case, the 3 blinking lights indicate that your garage door's infrared safety beams are not properly aligned.
1) Check that the operator has power. The green lights on the sender and receiver should be lit.
2) If the receiver's green light is on, but the red light is off, the receiver has power but is not detecting the infrared beam from the sender. The red light might flash when the beam is partially detected. This can be caused by
mis-alignment or something blocking the beam.
Adjust the safety beam sender and receiver while watching the receiver's red light (stay out of the beam while aligning it). When the red light stays on, the beam is aligned and your garage door should operate normally.
http://www.linearcorp.com/pdf/manuals/LCO75.pdf
NOTE: If the receiver's red light remains off, check for:
1) Dirt on the receiver's lens,
2) Sunlight shining into the receiver's lens,
3) A short in the safety beam wiring (from staples or at the operator terminals).
Dec 02, 2013 | liftmaster Garage Door 1/2 Hp
I have a Chamberlain Whisper Drive and it started beeping. Reading the manual, it seemed that I needed to replace the battery. It is about 5 years old. Replaced the battery and the LED is no longer red but...
On the back of the garage door opener there is a red button. Depress this button and sync your keypad to the opener. This will re-establish the code and reset the remote.
May 27, 2011 | Sears Craftsman LiftMaster Chamberlain...
1. Problem noticed a couple of years ago - When it gets cold (40F or below), my passenger side door cannot be opened from inside or outside. The door lever just moves but doesn't seem to...
BMW and Mercedes had the same problem. They changed the type of grease used to assemble the door latch mechanism.
WD40 Squirted into the lock area often does the trick.
Roll down the window and aim nozzle/straw at interior latch mechanism.
Put WD40 straw into key hole and squirt .
Jan 13, 2011 | 1997 Volkswagen Cabrio
The power light is red and the bulb light is blinking red
OK...Did you replace the lamp with a Sony original? If you did, then carefully check that the door is closed properly.
May 28, 2010 | Sony KDF-E55A20 55 in. LCD Television
Craftsman garage door opener (1/2 hp) - light flashing
most of the time when the lights start flashing on them and they won't work it's something in the way of the eyes that cross the garage at the bottom are something bummed them and there not lining up no more check that first.
Apr 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Printer doesn't work at all. Status light is red.
A voltage surge often accompanies a power cut and even when surge protection is used sensitive electronics can be damaged. Often the damage is such that the item doesn't fail immediately, or doesn't completely fail.
That happened to a friend a couple of years ago and he was fortunate enough to suffer immediate failure so the power company paid to replace his motherboard and hard drive.
You should have your printer checked by an engineer.
Jun 18, 2017 | Brother HL 5170DN Laser Printer
WIDl126 - door lock and easy iron flash
worth trying this! make sure the drain hose is only down the waste pipe about 6 inchs, and up off ground level about 24 inchs ie. 2 feet.If that don't not work it could be faulty pcb board!let me know.bye,close,ire.
Dec 23, 2007 | Indesit W 123 Front Load Washer
Cyberhome CH-DVD 300 DVD Player Logo
178 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
