Question about Elo Computers & Internet
I have a problem with my Elo touch screen monitor. (Model No: ET1925L) When I plug in the power cable, the power led (near the power input) goes on. On the screen "No input" message is shown. Every thing seems ok. But when I plug in screen cable, power led starts flashing and there is no picture or message on the screen. Is there anybody experienced this problem?
    Sergeant:
  • 139 Answers
First of all do the flash light test. If you can see dim picture, your monitor's Backlight Inverter board is faulty.
Posted on Feb 06, 2018
    Sergeant:
  • 324 Answers
Disconnect all cables - press and hold the power button for about 5 seconds connect all cables back then turn on the power.
Posted on Oct 21, 2013
  • 3 Answers
SOURCE: 924x
having the same exact problem...it started with the green led power light flickering and it would take a long time to come up and then it got progressively worse...now the led light flickers red, yellow, green and the screen displays white lines randomly as the led light flickers...seriously doubt that the monitor is repairable....paid $500+ bucks for this sucker and have only had it for 1.5 years...have 3 CRT monitors that only cost $100 bucks from the mid 90's that are all still running strong (none are ViewSonic monitors), so needless to say we are very very disappointed in the QUALITY of ViewSonic Products. Our Company Will Avoid ViewSonic Porducts at all Costs in the Future!
Posted on Jan 03, 2008
  • 286 Answers
SOURCE: veiwsonic 924x
This is a generic symptom that could happen to any LCD monitor.
The following is a generic answer applicable to most.
The most possible causes are bad capacitors or a bad semi-conductor.
Open the unit and check to see if any of the capacitors in the power supply or other boards look domed or vented on the top.
Replace any capacitors accordingly. Use the same value capacitors. Most often, 1000uF 16V or 25V, 470uF at 16 or 25V, 220uF at 16V or 25V.
If this doesn’t solve the problem, try checking the surface-mount transistors on the inverter board that run the lights. Some times these transistors go bad and can cause the power to cycle up and down. Check the area for any cracked or overheated ceramic or mylar capacitors.
Don’t forget to check for caps on the main board. Some times these boards are overly simple and only have a couple of caps, but other times they are teaming with them.
Posted on Feb 14, 2008
  • 7 Answers
SOURCE: Elo ET1725L with no video. Flash on screen on
When LCD's "turn on" momentarily before going blank again it is an indication that the backlights have worn out. Cold Cathode Floursecent Lamps (CCFL's) have a limited amount of hours which they can be in operation for before the mercury vapor in them breaks down (or leaks out). When that happens the backlights no longer look like a load the inverter (device inside the monitor which turns low voltage into high voltage) is programmed to look for, and long story short, the inverter does not keep the lamps illuminated because of this being a safety setting, if the load no longer looks like what the inverter is looking for, it could be sustaining an open arc which then leads to extremely high temperatures, and a possible fire. The flash you see is the "firing voltage" (I think that is what it is referred to in the industry) which is a very high voltage pulse used to create the arc between cathodes in the CCFL, creating the arc takes a much higher voltage than sustaining the arc, so even if the inverter successfully creates the arc and lights the cathodes, it quickly doesn't look like a proper load and then inverter quickly turns off to prevent damage.
In essence CCFL's are usually the weakest link in LCD monitors as far as what is most prone to failure, technology has been improving, but if you keep your monitor on all day long at full brightness, never shutting it down, don't expect more than 3 years out of it :( Some brilliant LCD manufacturers recognize this problem and even make the backlights replaceable!! What a novel concept!!! But due to price gouging, the replacement backlights are usually sold for a premium from resellers, better option than the majority of LCD displays which have the backlights so integrated that you end up destroying the LCD and introducing contaminates in the process of "reviving" the display...
Your best bet if the backlights are in fact shot, is, if you are handy with a soldering iron, get the LCD apart, get out the backlights (there are probably four in there, possibly 6) measure the diameter and length, and look on eBay to see if someone is selling the particular CCFL you need-- that may be the cheapest route if you are out of warranty...
Posted on Jul 25, 2009
  • 1684 Answers
SOURCE: Acer AL1716 A Monitor does not start
The problem on your monitor is a bad power supply. Because of heat buildup in LCD monitors parts called capacitors overheat and blow out. You can go to our web site at:
www.ccl-la.com/badcaps.htm and see what to look for. If you open your monitor and see blown capacitors that look like the pictures on our site then replace the bad ones and you should be back going. Email me if you have additional questions or if you need to get the capacitors, we carry them in stock.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Aug 27, 2009
SOURCE: blank screen
What the hell kind of deal is this? Everyone has the same problem, yet not one solution.
Posted on Nov 19, 2009
I can not hear any sound through the speakers of my ELO 1527L touchscreen monitor. I have a stereo 3.5 mini jack connected from my PC sound card and then to the speaker input on the back of the 1527L. This...
The Elo ET1527L Monitor has stereo speakers. Within the OSD (On Screen Display) you can control several properties of the monitor like; brightness, contrast, positioning, color, and SOUND. See the buttons on the right side.
I recommend setting the sound to 100%. The speakers are small and weak. They are pointed to the rear, I assume for customers to hear.
The buttons do have a lock-out feature too. If they don't respond, while on, hold down the top two buttons and the screen should display Lock / Unlock. Wait until you see the one you want and then release. The power button lock out works the same way, holding top and 3rd button to lock/unlock.
The device drivers give you an option to use internal (monitor beeps) and external (PC port) sound sources.
Jul 22, 2017 | Elo Computers & Internet
ELo touch screens not responding to the touch?
is the screen worn? you might need to replace the touchscreen glass
Aug 31, 2009 | Elo 15" Touch Monitor
Elo 17" LCD Touch screen ET1725L Powers off after 1 second
Your problem lies ion either your back light inverter or in the backlight tubes ( bulbs) which are embedded in the LCD display. The display has 4 ccf tubes inside of it that provide the backlighting. if any of these tubes are bad the backlight inverter will shut off after about 1 second. Because there are 4 of these tubes inside the screen you may not notice ( brightness wise) if 1 of them is out.
You can buy another backlight inverter( about $70.00 US) however, from my experience that would be a waste of money. Unfortunately, I think your problem probably lies in your LCD and the backlight tubes are not replaceable.
Hope this helps all who have this problem.
Good luck
Jim
Oct 28, 2008 | Elo 17' LCD MONITOR, TOUCHSCREEN, 1280 X...
Install software for touch screen elo
try this link : http://www.elotouch.com/Support/Downloads/dnld.asp
Jun 09, 2008 | Elo 15" Touch Monitor
Broken Elo Monitor Screen
Touch screens are even more expensive that straight LCD panels. This repair may cost more than the original monitor. Why do you need another panel? Is the panel cracked or is the touch screen portion not working correctly?
Dan
Mar 28, 2008 | Computers & Internet
Blank screen
elo touch screen ET1925L -7SWA1 i get no picture on the screen but i hear sounds coming ou the back of theespeakers.. could it be the inverter?? help
Oct 24, 2007 | Elotouch 17" LCD Monitor
How to adjust sensitivity on ELO Touch Screen monitors
you probably have a capacitive screen, it only responds to finger press. You need a resistive screen to be able to respond to finger, nail, or pen press.
Aug 28, 2007 | Elo 15" Touch Monitor
Computers & Internet Logo
284 people viewed this question
Top Elo Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
Sam DeGonia
Level 1 Expert
shahid_ptv
Are you an Elo Computer and Internet Expert? Answer questions, earn points and help others
