Question about BenQ Joybook 3000-01 Notebook
Wireless problems - BenQ Joybook 3000-01 Notebook
    Problem Solver:
  • 5 Answers
This requires far more explanation. What is occuring? What are the symptoms. Usually, wireless problems are the result of a driver issue or improperly setup wifi.
Posted on Oct 21, 2013
Wireless
Your wifi connection problem could be due to firewall, wireless signal quality or wireless signal interference. Here's an article from the Lexmark website that will help you identify and fix the wireless connection problem:- How to identify a Wireless Communication Problem and Resolution Tips
I hope this helps.
Feb 12, 2012 | Lexmark Prestige Pro 805 Color All-in-One...
Do I need wireless interent to conntect a wireless printer? How do I connect my wireless printer to windows xp? Should it connect just as easy as ''plug and play''? I am having trouble disabling Norton...
You don't need wireless internet, but your computer has to have wireless.
Norton can be problem. You can uninstall it, load the printer, then reinstall.
Feb 28, 2010 | HP Office Equipment & Supplies
My laptop wont connect to any wireless connection at all anymore, but I can plug it in to the ethernet and it works. the wireless switch is turned on and when i try to connect to any connection and it says...
Hello.
For your wireless card problem, be certain that your wireless access is turned on. Often there is a switch (location depending on the model) to to turn wireless off and on.
Then, if still a problem, I'd suggest to go to Device Manager. Right-click your wireless network card and select Update to update the driver.
If still a problem, go back to Device Manager. This time delete the wireless network card, restart your computer and see if the problem resolved.
If still a problem, replace your wireless card.
Hope this helps.
Dec 27, 2009 | Sony VAIO Notebook
My wireless adapter for my desktop keeps connecting for awhile and the disconnect from my wireless router /modem. The router is less than 100 feet from the computer ....do i need a new usb wireless adapter...
Is there any other wireless computer in the network ?
Right now the connection is dropping on your computer . It might be the problem with the wireless adapter of the computer or the wireless router .
You will need to isolate the problem.
If you have any other wireless computer in the network and that computer is also facing the same problem then it must be the router problem. You can check the settings of the router . for this you will need to access the router set up.
If you have other wireless computer in the network and that is working properly then it must be adapter issue. Try to uninstall or reinstall the adapter or Update drivers.
If you do not have any other wireless computer then try any laptop in this wireless network just to isolate the problem.
Click Here for more information about the routers and home wireless network
Dec 02, 2009 | 2wire (1000-100052-000) 802.11g/b Wireless...
Wireless connection wont work
To check if the wireless card is bad or OK.
Go to Control Panel - Network Connections - Is the wireless network connection listed and if so is there a red X on this connection?
If so, right click on the wireless and click Repair - this may fix your problem, it forces the wireless router to issue the wireless card with a new IP address.
If it doesn't fix the problem then go to Control Panel - System - Hardware tab - Device Manager - scroll down to Network Adapters and expand and check your wireless card, is it Working and Enabled?
If has a yellow ? against it or not working then reinstall the wireless card driver.
If the wireless card is built-in check the BIOS to see if the wireless card is enabled, if not enable the wireless card and repeat the above steps.
If this doesn't fix your problem then the wireless card is faulty and you need a new wireless card. You can get a PCMCIA wireless card to replace the faulty wireless card. If the wireless card is built-in then disable the faulty wireless card in the BIOS before you install the new wireless card.
Oct 11, 2009 | HP Compaq Presario 2200 Notebook
Laptop states wireless adapter not installed and configured? worked before.
Oct 11, 2009 | Gateway (802.11usb) Wireless Adapter
Wireless Connection Problems between an Dell Laptop and Actiontec
Have you got permission to connect into her Internet using her wireless router?
If so you need to get the WPA encryption key from her to configure your wireless card's encryption to get access.
Jun 28, 2009 | Dell Inspiron E1505 Notebook
Wireless adapter issue
Is the wireless adapter built-in or is it a USB wireless adapter or a PCMCIA wireless adapter?
What make and model is the wireless adapter?
Is the signal strength on the wireless adapter at a good/high level?
Jun 27, 2009 | Acer Computers & Internet
Wireless problem
This is generally cause by a driver glitch. Go into the device manager and unistall the wireless drivers, then reboot. It will find the wireless hardware and reinstall the drivers.
Jul 16, 2008 | HP Compaq Presario V6000T Notebook
Internet problem
It could be several problems:
1. Your wireless router misconfiguration.
2. Your wireless router is bad
3. Your wireless card misconfiguration on your laptop
4. Your wireless card is bad.
If you never had problems with your wireless connection before and you haven't change configuration on your router or your laptop. I have seen and repaired this problem by replaceing wireless router.
Good luck!!!
Jul 04, 2008 | Computers & Internet
BenQ Joybook 3000-01 Notebook Logo
32 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
