Question about Epson Stylus Pro 7600 InkJet Printer
EPSON STYLUS PRO 7600 Leaking ink One of my
EPSON STYLUS PRO 7600 Leaking ink One of my customer have an Epson Stylus Pro 7600 It's leaking ink by printhead. NOT buy Ink Tube, neither the dampers. IS THE PRINTHEAD itself. I took off the printhead and sprayed the conector with a electgronic contact cleaner to avoid any dirt or humidity from making false connectivity between leads. Any idea? Already did: Cleaning internal cycle. ALL of them. I'm using refillable ink cartridges, but only Magenta y dropping ink.... Please, help.... I have pictures if you need.....superplotter@hotmail.com
    New Friend:
    Problem Solver:
  • 9 Answers
Sir the printer head of your printer is already thin... try to change the printer head...
Posted on Oct 24, 2013
4 Suggested Answers
BinaryCode
  • 54 Answers
SOURCE: Epson Stylus R230 Light Magenta Not working
Print first a nozzle check pattern, self test which they say. Check your manual for your printer, it should be accessible from that if you dont have any manual, go to the epson website and download a manual. Usually the self test would go like this.
While the printer is turned off, you press and hold down the paper feed button, continue holding it down while turning on the printer. It will print the nozzle check pattern standalone. If you see all the colors then the issue your having is a color management issue, if you do not see the cyan, magenta, yellow, black, light magenta and light cyan from that test; then you will need to do 3 consecutive times of Head Cleaning from the maintenance program in your computer. If you have a windows xp it goes like this.
Click on start go to control panel - printers and faxes -
you right click on your printer icon and select printing prefrences. From there, go to maintenance tab and click head cleaning, go through that cycle 3 consecutive times and see if it improved. Good luck....
Posted on Jun 12, 2008
SOURCE: Epson Stylus Pro 7600
Yes the cartridges are Epson.
Posted on Nov 21, 2008
SOURCE: need new dampers for epson pro 4000
hi please contact at 9324629632 for any printer problem
Posted on Mar 04, 2009
I have a Epson Stylus Pro 7600. How can air get in the lines?
The only reason I know is by allowing the cartridge to completely run out of ink. That is why you cannot print in black only when a colour has expired. The printer does not only use the black cartridge it uses a bit from each cartridge to ensure the nozzles stay clean.
Jan 25, 2011 | Epson Stylus Pro 7600 InkJet Printer
How can I remove the Ink Cartridges from an epson 7600 stylus pro. I lifted the locking arm but to no avail! Help :)
After the printer is powered On, Open the ink compartment on the Left hand side of the machine (Pull downward), then you'll see another small Lock (Ink Lever), raise it upward and remove them one by one.
You can refer to this manual (Page no. 38-40) http://ftp.epson.com/pdf/pro76u/pro76uu1.pdf
If you have problem, let me know.
Good luck.
Thanks for using FixYa.
Jul 22, 2010 | Epson Stylus Pro 7600 InkJet Printer
I have an Epson Stylus Pro 7600 with a Agfa Sherpa 24M sticker on it. Baught some cartridges from Epson but I get Wrong ink message. Any way to work around this problem?
You need to either buy AGFA cartridges ot apparently you can take the chip off the AGFA cartridge and put it on a Epson or compatible. It will always say it's empty but should still work
Jun 18, 2010 | Epson Stylus Pro 7600 InkJet Printer
Epson Pro 7600 Service required error
Service required mean waste ink counter overflow. You need to reset it. SSC Service utility don't work with this type. The resetter is not for free, it's commercial. Only some distributor have it.
May 27, 2009 | Epson Stylus Pro 7600 InkJet Printer
Epson Stylus Pro 9600 vs Agfa Sherpa44
The Agfa Sherpa is not manufactured by Epson. Both Epson and Agfa buy and retag their printers from Mutoh.
I do not know if the 44 is the same as Epson 7600 or 9600, but it should fit the same cartridges.
If the printer does not accept the cartridges, that means that there is something different in the software stored in the Epson cartridge chip.
In this case you will be only able to use only Agfa or Mutoh Falcon cartridges.
Oct 27, 2008 | Epson Stylus Pro 9600 InkJet Printer
Epson Stylus Pro 7600 InkJet Printer Logo
267 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
