Question about GE Profile JS998 Kitchen Range
PGS975SEP3SS range is dead - GE Profile JS998 Kitchen Range
I have 2008 range rover sport..it was locked and battery is dead. now the doors wont open.. how to unlock the doors so i can open the hood and re-charge the battery Or does it have key hole for manual...
How to unlock your RR/L322 with dead battery
http://www.rangerovers.net/forum/6-range-rover-mark-iii-l322/38786-how-unlock-your-rr-l322-dead-battery.html
I found this on the range rover site.... hopefuly this helps with your model. You just have to pop one of the lights off to get to the postive wire then strips some of the wire and use a battery pack to send enough power to open the doors.
Hopefuly that helps
Mar 04, 2013 | Upgradeyourauto 2003-2008 Land Rover Range...
My range rover 2007 key is completely dead
surely my friend your key has lost its program. Need reset the program even I believe the ignition key. Refer to main dealer about it
Sep 14, 2012 | 2008 Land Rover Range Rover
Electric range heard a loud bang then it went dead
I WOULD DISCONECT THE POWER AND REMOVE THE BACK PANNELS AND LOOK FOR A SHORTED WIRE OR A BURN MARK ON THE BOARD. ALSO CHECK WHERE THE CORD ATACHES TO THE STOVE. GOOD LUCK!
ERIC
Jan 17, 2010 | Kitchen Ranges
Nothing on rage works
Open the control panel and check all connections inside. Look for loose/burned/corroded wires and connections. Plug the range back in and use a wooden spoon, move all wires individually with the wooden spoon until a light comes on. Check out whatever the wire goes to for a bad connection.
Jun 08, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Frigidaire Range control panel DEAD
We tested the EOC and it will indeed need a replacement. Also, just a couple weeks prior we ran the "clean" mode on the oven as did another poster who experienced the "pop" and loss of the control board/oven function, but still had stove top function.
Dec 16, 2008 | Frigidaire FEF366EC 30" Freestanding...
Touchpad buttons dead
Most people don't know there is a 5 year warrantee on solid state electronics. or else i found the part on repairclinic.com. I don't know if they will be cheaper
Nov 07, 2007 | Jenn-Air JGS8750 Gas Kitchen Range
GE Profile JS998 Kitchen Range Logo
60 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
