Question about Keurig Coffee Makers & Espresso Machines
Jaws stuck - Keurig Coffee Makers & Espresso Machines
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Use vise grips .
Posted on Nov 02, 2013
TOOK OUT DRILL BIT NOW CAN'T GET IT TO CLOSE SO I CAN USE SMALLER DRILL BIT CRAFTSMAN BD0737
its likely you have something stuck inside the the jaws.if you open up up the jaws fully and gently remove any bits(sometimes a squirt of WD40 helps)
Jul 09, 2017 | Craftsman Drills
How to release a stuck wand in a shark dust away rotator vacuum?
very difficult
it can be done if you have access to a vice
place the smaller wand section in the jaws so that it slips easily but the larger part is stopped by the vice jaws
a sharp pull will break the seal effect and it will pop apart.
if the wand is metal you can enlarge the outer part at the joint by applying heat carefully with a gas lighter for a few seconds and pulling apart
Oct 21, 2016 | Shark Vacuums
Dewalt DW972 frozen chuck
Spray with WD-40 and let sit for a while and try again. If it is still stuck, tap on the end of the jaws with a nail punch to loosen them up and add some more WD-40. Try opening or closing the jaws and repeat. Usually it is due to some rust on the jaws and it may take several attempts to loosen it.
Sep 22, 2013 | Dewalt DW972 Battery 1500mAh, 12V, Ni-Cd
I have a skill 18v drill and the chuck jaws that hold the bit has one stuck down and two even, i have taken off the chuck but was wondering how to disassemble the chuck itself or if there is another way to...
Lube the chuck with some penetrating oil and bring the two loose jaws near the surface. Take a brass or soft hammer and pound the face. The stuck jaw should come down. They have a spring to push them down, but sometimes grits or other contamination causes them to stick.
Apr 26, 2011 | Next Generation Power Engineering Skil 18V...
Bit tighten stuck open
If you mean the chuck jaws seem stuck open, spray around them with some penetrating oil or spray like WD-40, RP-7 or similar and let sit for a couple hours... Then you can tap around the chuck body with a light hammer or spanner etc... just lightly tap... Then if the chuck has an arbor lock to prevcent it from spinning, be sure that is engaged then try to release the chuck jaws. Sounds like they are stuck open through tight friction or rusting on the inside edges (that you dont see). Be careful not to leave them in the fully open position when stored as this is exactly what can happen!
Mar 31, 2010 | Makita 6304LR 1/2" Chuck Electric Drills
My dc927 chuck is jammed fully open and won't move. How can I lossen it. Regards George
Something I would try:
George, look down the center of the chuck jaws with a bright light. It's going to be difficult to see, but there is an Allen head screw down in there.
Taking the screw out, will afford you the opportunity to remove the chuck from the drill. The drill should have a slightly tapered shaft, and the chuck has a tapered hole to match. It might be stuck on tight. Tap on the back side of the chuck, with a wooden block, and hammer.
(Yes, this may require a helper)
Tap on one side, then the other to try to remove the chuck evenly.
With the chuck off it may release pressure on the jaws. It may not.
In this case the chuck will have to be opened up, (Which will release pressure on the jaws), and the jaws reset.
Aug 22, 2009 | Dewalt 18 Volt Compact Drill Kit
Driver side door will not "catch" and close
open the door and look at the 2 jaws that go around the strike. then pull the door handle as if you were opening it from the outside and manually retract the jaws back to the open position. this is a common thing that happens. after that it should be ok. lube it with wd40 afterwards.
Jul 20, 2009 | 1999 Chevrolet Monte Carlo
Lawm mower blade adapter removal
I use a two jaw puller to take them off. Screw the blade bolt partially back in the hole so not to damage the threads, hook jaws on each side and they always come off. Penetrating oil could help.
May 20, 2009 | Craftsman Garden
Dewalt DW988 drill chuck
lock the drill in a vise so you can work on it. Then try working a very small screw driver tip into the jaws as you at the same time back up the jaws. They may be jamed against each other.
Oct 16, 2008 | Dewalt 18 Volt Compact Drill Kit
Coffee Makers & Espresso Machines Logo
22 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
