Question about Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum
Kenmore 116.22612 will not suck...only blows out. Checked for all clogs, put in new bag, cut away all long hairs circling the rotator brush and let it cool off. Now what?
  • Nanci Crock
    Nanci Crock Oct 23, 2013
    The last time I used it, six days ago it was fine. It was not showing any suction power so I changed the bag, cleaned the filter, checked for clogs in the hosing, and cut the long hair and one string from around the rotator and have left it cool off.
  • Corky's Craft Shop
    Corky's Craft Shop Nov 03, 2013
    Nanci, I'm sort of confused about what you have as a vacuum, you listed a Kenmore 116.22612, in the question, but the listing shows an Electrolux Oxygen Cannister. These are not the same vac. Second, when you say it will only blow out, where is it that it is blowing out from. Are feeling the exhaust area? or is it coming from somewhere else. When you say you have checked for a clog everywhere, you need to check the wands that connect the hose to the floor tool, as well as the neck of the floor tool,, then hook up the hose alone and check the suction there. Last but not least, check the suction at the machine itself.
    Novelist:
    Champion:
  • 210 Answers
All things being equal, it would be helpful to know what has happened since the last time it was used? and how long ago that was? One thing to check, there must be a bag in the unit or it will not have much, if any, suction. However, other than that there's no good reason for this action.
Posted on Oct 23, 2013
4 Suggested Answers
SOURCE: My oxygen will not pick up pet hair out of the. The brush rotates
Your brush may not be spinning try pressing the reset button on the back of the power nozzle, it that does not work you may need to change the belt.
Bob
eVacuumStore.com
Posted on Mar 27, 2010
  • 10 Answers
cheak belt
Posted on May 13, 2010
  • 694 Answers
SOURCE: I have an Ecectrolux Epic
Try this.
Disconnect hose. Turn machine on and place hand over intake. If it shuts off immediately, first try turning dial on top of machine so largest dot matches up with arrow. Turn on and place hand over intake again. If it still shuts off immediately, the "control valve assembly" is worn or broken and needs replaced. Don't try this yourself.
Take your complete machine to the nearest authorized Aerus Electrolux shop, or call and ask someone to pick it up. There's no extra fee for this, or delivery upon repair.
The repair/replacement should include a complete cleaning of your vacuum in the labor, but ask the service manager to be sure.
The shop nearest you can be found by typing your zip code into the indicated space on the site listed below.
http://www.aerushome.com/storelocator/
Posted on Oct 15, 2010
Roller with brushes is not rotating although light is on and sucking sound is there. Is this a belt problem?Detached from floor part, the hand part is working fine. New filter. new bag.
Hi, it's Allie from Crucial Vacuum!
Your Kenmore vacuum brushroll is connected to the motor by two different sized geared belts. Over time, the belt's gears wear down and stretch out losing the grooves and tension that turn the roller. Another cause could be there is debris stuck on the roller and/or bearings. Changing the belts may be the solution to your problem.
Checking your unit's brushroll and clearing it of any tangled hair strands or debris that my be blocking the airway will be helpful. Follow by checking the internal hose for any blockages.
You can purchase direct your replacement, roller brush, filters and belts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/kenmore.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Alejandra (Allie) Sepulveda-Rivera
Crucial Vacuum Customer Care
Sep 13, 2014 | Kenmore Vacuums
Brush bar is not spinning
Common causes of brush roller failure are belt breakage and clogging. If this is a Dyson animal vacuum, you may find the brush roller is so clogged with hair that it cannot rotate. The solution is to remove the brush roller and clean it thoroughly, particularly inside the end caps where hair accumulates. It is unlikely that an entire animal was ingested.
Nov 20, 2013 | Dyson DC28 Animal Vacuum
I have a Kirby G4. I have noticed the last few days when trying to vacuum that it is blowing more than it is sucking up. I put on a new bag to make sure it wasn't too full. I also put on the hose and...
take the mini emptor off(plastic piece on bottom of cloth bag) this is done by rotating it away from the body of the machine. There is most likely a clog there. Also take the brush head off and inspect fan for chips or cracks this will also reduce suction. let me know if you need further assistance
Apr 08, 2010 | Kirby G4 Bagged Upright Vacuum
It seems to blow air out instead of sucking up
Remove the bag on top and the plate on the bottom. Clean out the air passages, top and bottom, looking for a clog. When it seems clear, turn on the vacuum to see if air is moving through. Don't allow a full bag to remain in place Check the brush on the bottom for string, hair, or thread caught in the bristles or bearings on either end. Hope this helps!
Mar 12, 2010 | Hoover Tempo Widepath Upright Vacuum -...
My kenmore hida filter vacuum cleaner no longer has the sucking ability it used to have. It is only 4 years old and has worked extremely well up until this week. The motor is functioning well, as is the...
well i've hade one come in a while ago and it didn't have good suction so I looked at the bag it was buljing w/ dirt so I put a new bag in it and it had better sucktion but still not good enough so I cheched the fabrick filter and it was dirty too so I washed it and it had even better sucktion so try the paper filter on the end too and if your vacuum still haves bad sucktion try looking if the hose is clogged buy putting your mouth on the end and blowing through it i recomend whiping the end off befor blowing if hard to blow it is clogged, if clogged i would put something thin like a metal rod or or a stirty stick to push the dirt out i'm sorry if my info didnt work out :D
Jun 12, 2009 | Kenmore Whispertone 23312 Bagged Canister...
Vacum not sucking the dirt and the light is not turning on
loss of vaccum brush head not spinning check belt turn over remove bottem plate check belt assmble. remove any string or hair build up sear is the best bet for the belt
Mar 31, 2009 | Kenmore 34923 / 34925 Progressive Bagged...
Kenmore direct drive model 116 31912100 lost vacuum
Check the inlet where the dirt is first sucked in for a clog, also your hose may be clogged.
Sep 01, 2008 | Kenmore 31913 Progressive Direct Drive...
Blowing out?
Did you check the inlet down by the brush roll?
Feb 13, 2008 | Bissell 3522 PowerForce Bagged Upright...
Blows dust and dirt out of brush area
Did you make sure to cut all the strings, hair, etc. out of the brush attachment on the bottom? Look in the corners too to make sure none has gotten stuck on the sides that needs to be cut out.
Jun 03, 2007 | Kenmore 25812 / 25813 Progressive Bagged...
My dirt devil vacuum won't suck up anything and its brand new!!
Take the vac bag off and turn on the vac , it should blow air out, if not unclogg the hose where the bag connects, also when you check the roller and belt, unclog the flex hose(located inside base near roller assembly) that sucks up the dirt. As long as the motor works fine the rest is just maint.
Mar 30, 2007 | Dirt Devil M085805 Upright Vacuum
Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum Logo
41 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
