Question about Refrigerators
Kenmore 58582890 coldspot refrigerator
I have water leaking on the floor under the water filter. It leaked before and after I replaced the filter. I turned the water supply off to stop the leak. Can you help me detect the source of the leak.
SOURCE: The water input to the water filter is leaking - admiral model GC2224GEKB
my water filter water line is leaking from the bottom in the back of my refrigerater. How can i get to it to repair it.
Posted on Oct 09, 2008
  • 123 Answers
SOURCE: Water leak under refrigerator, Frigidaire, FRS6R5ESBC
chk out dis video
http://www.ehow.com/video_112132_fix-leaking-refrigerator.html
Posted on May 14, 2009
aasc
  • 1606 Answers
SOURCE: Freezer leaks water even after water supply turned off
Remove the food from the lower portion of the freezer and remove the 2 screws which hold the rear freezer panel on . Remove the panel and use a hair dryer to defrost the ice built up over the drain . Once you see the black drain hole , concentrate on defrosting the hole . Once defrosted , the ice water will drain into the hole . I would use a small hose inserted into the drain and blow thru , to remove any debris built up inside the drain . Reinstall the panel and food .
Posted on Aug 09, 2009
woodchuck789
  • 4070 Answers
SOURCE: My Kenmore refrigerator coldspot #70192001 is not
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
If you need help finding your model number see here> http://www.appliancepartspros.com/modelnumber_locator.aspx
To locate your timer, motherboard, control or adaptive defrost control , enter your model number and search for the part or post back on Fixya.
http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a
Posted on Oct 01, 2009
SOURCE: Water filter leak Whirlpool ed25rfxfw01
I have an undersink filter from Whirlpool that is leaking also. I had an older one that also leaked and I replaced it. Worked fine for about six months then water all over under the sink. I believe it is leaking from the O-ring which seals the body and the cap. I think they have a lousy design and will look for another filter.
Posted on Jan 01, 2010
Water leak from my Kenmore Coldspot Frig Model 106. 59792990
U have a restriction in drain tube under evaporator coil. So every time it goes into a defrost instead of going down the drain tube it is running over and out the front of fridge
Mar 08, 2013 | Kenmore 53642 / 53644 Side by Side...
Kenmore Coldspot Model 51572200 is leaking water all over the floor
On the bottom rear of the refrigerator as you are looking at it from behind the left side where the water is feeding into there should be a double valve. 1 is for the water and the other to the icemaker. Many times that valve won't shut off, however the switch that dispenses the water is evidentially bad and needs to be checked if it is stuck open.
Jun 03, 2017 | Kenmore Side by Side Refrigerator
I have a leak inside my Kenmore Coldspot Model # 106 72104100. It is not coming from the icemaker.
If the water filter is old the seals will leak into the evaporative tray overflowing it. Replace the filter or give it a turn to bypass.
Jan 26, 2011 | Kenmore Refrigerators
Kenmore coldspot model 106: top freezer leaks water slowly into botton refrigerator. how do I repair it?
Have you tried adjusting the freezer temperature to a higher level? This worked for my Kenmore. It will take a couple of days to quit leaking.
Dec 19, 2010 | Kenmore Refrigerators
Getting water
I have Kenmore Coldspot refreidgerator and am having a problem with water pooling inside the fridge at the bottom underneath the drawers (mostly the left side). Where is the water coming from and it formed a thin ice.
Thanks
Nov 25, 2009 | Kenmore Refrigerators
Water Dispensor leak on Whirlpool Refridgerator
The solenoid valve needs replacing, located at the back of the refrigerator. If you have well water you will need to install a filter on the supply line.
Jan 04, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Leaking water and replace filter light not resetting after filter replacement
are you sure that the filter is installed corectly
remove the filter and reinstall it to be sure
May 11, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Question about water leaking on the floor under fridge
remove and reinstall water filter, possibly o-ring got sideways during installation.
Mar 21, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water Leak
do you have a water dispensor?? is there ice in the bottom of the freezer??
Oct 02, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
73 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
