What do I put for advanced settings - Computers & Internet
    New Friend:
  • 144 Answers
Please be more especific.
What's the equipment, what settings do you need?
Posted on Oct 21, 2013
Cam timing this is on my 1991 5.7 small block chevy I can set the timing to zero but when I connect the advance connector it jumps off the timing scale.
It is should advance when you put the vacuum hose back on the dist. It is advancing the dist. Does the engine perform if so it is good.
Apr 28, 2017 | Cars & Trucks
For the Singer Advanced 7422 machine. I put on
have you got a buttonhole lever on the sewing machine that has to be pulled down first before starting the buttonhole?
Aug 29, 2013 | Singer 5050 Mechanical Sewing Machine
How 2 install auto advance distribitor an set timing on 65 harley panhead
Hi Anonymous, for more information about your question please visit the website below. Good luck and have nice day.
How Ignition System Works
How to Set the Points on Harley Davidson Shovelhea
Apr 20, 2013 | Harley Davidson Motorcycles
I put a new distributor in my 73 355 engine it runs but i need to know how many degrees to set for base timing
the best way to set timing on a '73 is with a vacuum gauge, but You can set it to 7btc. after adjusting it, look at the advance while snapping the throttle; it should advance 12 to 15 degrees.
Apr 04, 2013 | Cars & Trucks
Nikon FG. Replaced 3V battery. On the M90 setting the film advances OK. On 'program' or other settings it will only advance once and after shutter fires it will not advance until put on...
M90 is a battery independent setting - it requires no battery power to function. If it won't advance until put on M90 from other settings, then either you're not allowing for proper exposure, have the settings incorrectly set (film speed, etc), or you have shutter issues. The shutter is electronically controlled on all settings except M90. In the auto setting, your lense MUST be set to the smallest aperture (biggest number). On any other setting, you can use it however you'd like. I'd suggest unloading any film, setting the shutter speed dial to 1/125 or so, opening the back and looking thru and firing the shutter. If it's not snapping open and immediately closed, theres an issue and you need to consult a repair technician either locally, through Nikon, or through KEH Camera online.
Jun 29, 2011 | Nikon FG 35mm SLR Camera
Can't connect to a wifi because nintendo doesn't support it
if it is your own wifi you need to go into your advanced settings. the DS supports WEP and your Wifi is probably WPA. advanced settings will allow you to put in WPA passwords
Mar 29, 2011 | Nintendo DS Lite Console
MY asus pc continues to not wake up. I have to
POWER OPTION
control panel---->power options--->change plan setting--->
Turn off the display-never
Put the computer to sleep-never
control panel---->power options--->change plan setting--->advanced power setting
-set hard disk "turn off hard disk after" to never
-set Sleep "Sleep after" to never
-set hybrid sleep setting to off
-set hibernate after setting to never
Restart pc
POWER OPTION
-set display to never
Restart pc
Jul 15, 2010 | ASUS Eee PC 900 Notebook
Screen goes blank after a few minutes
POWER OPTION
Restart pc
POWER OPTION
Restart pc
Jul 14, 2010 | Dell Inspiron 1318 Notebook
Think pad t42 monitor keeps turning off. I tried changing power settings to never ... did not help still doing the same thing anything else I can do? thanks
POWER OPTION
Restart pc
POWER OPTION
Restart pc
Jul 02, 2010 | IBM ThinkPad T42 Notebook
Problem in timing
On the distributor there is 2 types of advance.Vacuum and mechanical.The vacuum type has the mushroomed shaped bit screwed to the side of the dizzy.you have to pull the small vacuum hose off when you set the timing.Using your timing light,bring the revs up.The timing should not move.Put the small vac. hose on and off and the timing should move up and down.If its a mechanical advance,there is springs inside the dizzy that hold small weights.As the dizzy spins,centrifical force moves the weights outwards creating advance.Check the springs are in place.If you have access to one,try a another dizzy to satisfy your problem.A good shop will have a dizzy tester they can put yours on to check all these thigs.Hope this helps
Sep 23, 2009 | Boating
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
