Question about Seville Classics MSC10166 Tower Fan
Not working Seville fan will not work but rotates
1999 Cadillac Seville cooling fans not working. relays and fuses are good
There is a temperature sensor that the ECM uses to activate the cooling fans, but a quick test is to simply turn on the A/C. The cooling fans must run anytime the A/C is on. If that doesn't work, then the temperature sensor is not the issue. If they DO run with A/C, but not when the engine gets warm w/o the A/C on, then it is the temp sensor.
Sep 12, 2016 | 1999 Cadillac Seville
Seville classics fan turns on and oscillates but does not blow air
Fan blades installed backwards? I assume the blades are rotating?
Aug 03, 2014 | Dryers
Why blades are not rotating or throwing air?
some of these have a expansion pin that holds the fan blade assembly onto the shaft, this may have fallen out or ? broke,,,
May 13, 2014 | Seville Classics MSC10166 Tower Fan
What causes cooling fans to stop working on a 92 cadillac seville,i unhooked the temperature sensor and they still didnt come on can it be the relay
Unhooking the temperature sensor will not cause the fan to come on. Yes it could be the relay. It could be the fan. It could be something else also. Usually the cooling fan won't come on during winter.
Feb 28, 2011 | 1992 Cadillac Seville
The fan has power and will rotate, but no air is being blown out. any troubleshooting tips or is it a goner?
Try to free up top fan bearing, it is under switch cover. Pry cover with small screw driver, insert screw driver blade in access hole and pry, top fan bearing is held by two screws, remove, clean and lubricate with oil or grease. It works!
Sep 29, 2010 | Seville Classics MSC10166 Tower Fan
The fan has stopped blowing it rotates and the lights are on but it has stopped blowing air
Try reversing the fan by using the switch or another chain in the cub. You might have accidentally reverse the fan
Sep 26, 2009 | Seville Classics Dryers
Fan vibrates either in stationary or rotating position
Vibrations are a cause of friction. I can only assume that the motor or the fan veins are being interferred with. If you feel comfortable you can take the case off and look or take it to a repairshop and have them look it over.
Aug 20, 2009 | Seville Classics MSC10166 Tower Fan
My 95 cadillac sevile sls is overheating. radiator
check cooling fan sensor,which tell the fans to come on
Apr 16, 2009 | 1995 Cadillac Seville
Cadillac seville sts 99 overheating
dose it have an electric fan ? if it does look to see if the fan is working hope this helps.
Dec 25, 2008 | 1997 Cadillac Seville
Seville Classics MSC10166 Tower Fan Logo
22 people viewed this question
Top Seville Classics Dryers Experts
Are you a Seville Classics Dryer Expert? Answer questions, earn points and help others
