Question about Toshiba e-Studio 4540C Multifunction Color Copier
Insert staples canon cartridge
I can't get my 4540 C to go online
How do I reload staples into my Xerox WorkCentre 7530?
You did not indicate finisher? Xerox MFPs' come with the most finishing options of any manufacturer.... I included instructions for all of them below. Enjoy!
Solution : Load Staples in the Professional Finisher With Booklet Maker The stapler in the booklet maker uses two Staple Cartridges labeled R2 and R3. Booklet stapling requires that both Staple Cartridges be free of jammed staples.
WARNING: Do not perform this procedure when the printer is copying or printing.
  1. Make sure the printer has stopped copying or printing.
  2. Open the Finisher Front Door.
  3. Squeeze the orange R2 and R3 levers together and pull the Staple Cartridge unit out of the Finisher until it stops.
    NOTE: The Staple Cartridge unit does not detach from the Finisher.
  4. Grasp the orange tabs on both sides of the Staple Cartridge and lift the cartridge out of the Staple Cartridge Unit.
  5. Push the new cartridge into the Staple Cartridge Unit.
  6. If no jammed staples are found, repeat step 4 - 6 for the other Staple Cartridge.
  7. When finished, return the Staple Cartridge Unit to its original position.
  8. Close the Finisher Front Door.
Solution : Load Staples in the Main Stapler of the Professional Finisher NOTE: Using Staple Cartridges other than the recommended staples may impair quality and performance. Only use only Staple Cartridges recommended for this Finisher.
  1. Make sure the machine has stopped copying / printing.
  3. Grasp the orange R1 lever on the Staple Cartridge and push it to the right.
  4. Grasp the orange tabs and pull the cartridge out of the Finisher.
  5. Check inside the Finisher and remove any loose staples.
  6. Pinch both sides of the staple case and remove the staple case from the cartridge.
  7. Insert the front side of the new staple case into the Staple Cartridge, then push the rear side into the cartridge.
  8. Grasp the orange tabs on the cartridge, and then insert the cartridge into the Finisher until it click into position.
  9. Close the Finisher Front Door.
Solution : Load Staples in the Booklet Maker of the Optional Office Finisher LX NOTE: The Booklet Maker uses two staple cartridges. Booklet stapling requires that both staple cartridges contain staples.
  2. Open the Finisher Side Cover.
  3. If the Staple Cartridges are not visible, grasp the vertical panels to the left and right of the opening and slide them to the center.
  4. Hold the tabs on both sides of the cartridge and pull the cartridge out of the finisher.
  5. Hold the tabs on both sides of the new cartridge and insert it into the original position in the Finisher.
    NOTE: If you have trouble inserting the cartridge, make sure the staples are positioned correctly in the cartridge.
  6. Starting at step 3, repeat the procedure for the other cartridge.
  7. Close the Finisher Side Cover.
Solution : Load Staples in the Integrated Office Finisher WARNING: Do not perform this procedure when the printer is copying or printing.
  1. Make sure the machine has stopped printing or copying, then open the Front Cover on the Integrated Office Finisher located under the Scanner Assembly.
  2. Remove the Staple Cartridge by grasping the cartridge by the orange handle and pulling it straight out of the Finisher.
  3. Remove any loose staples inside the Finisher.
  4. Pinch both sides of the staple case and remove the staple case from the cartridge.
  5. Remove the new staple case from its packaging and insert the front side of the case into the staple cartridge. Push the rear side into the cartridge. The cartridge will click into place when it is installed correctly.
  6. Grasp the cartridge by the orange handle and insert the cartridge back into the stapler until it clicks into position.
  7. Close the Front Cover.
    NOTE: If the Front Cover is not completely closed a message will be displayed. The machine will not operate if the cover is even slightly open
Nov 18, 2013 | Xerox WorkCentre M-24 Color Copier
How can i refill my mp540 cartridge?
First, purchase these refillable ink cartridges from a third party company: http://www.dhgate.com/canon-mp540-mp620-mp630-refillable-ink-cartridge/p-ff80808129a751870129aff7bc723664.html After that, head to staples or go online to order the ink. The cartiridges that come with the Canon or the retail ones may or may not work because of the microchip inside of each cartridge. You can try to refill those by removing the label off the top, and you should see a hole or two to poke a needle into. Once you purchase a refill kit it should come with something to inject the ink with.
Feb 28, 2011 | Canon PIXMA MP540 All-In-One InkJet...
How do you change a staple cartridge in a canon imagerunner 2870?
first open upper front cover.
then pull handle on left corner of front side, the sorter unit will come out. see behind side of sorter unit u'll find a small green handle to detach the staples cartridge, replace the staples cartridge and insert unit into stapler. push back sorter unit an close the upper front door. end
Dec 20, 2010 | Canon imageRUNNER 2870 Copier
Canon Imagerunner 3035. refilled staples, but copier thinks empty
frst: did you set the staples according to the instructions?
second: try the few times remove and insert staple cartridge in and out, until you heare the loading clicks.
third: check the staple holder for damadges or residuals of staples.
Jul 31, 2010 | Canon imageRUNNER 3035 Black and White...
Staple unit impossible to open
Has to be empty to open. At bottom there should be a small black lever that moves down to indicate staples are present. This sometimes falls out giving a false replace staples message. Cartridge itself must be replaced. This is the cartridge where you insert the staples into. Clear plastic with spring.
May 18, 2010 | Canon imageRUNNER 5000 Copier
Need instructions to load staples in Canon imagerunner 2270
pull the finisher out
you will see the staple in the end of it
pull up the staple cartridge using the green handle
then insert the new one
Apr 06, 2010 | Canon imageRUNNER 2270 Copier
How do i add more staples
Hi, You cannot add staples while there are still some left in the cartridge, you will have to wait until it is all finished, the paper holder comes out from the bottom of the cartridge, remove the old staple paper holder, pay careful attention or put a mark on the outside, now you are ready to insert the new staples in the cartridge. First you need to remove the new staples and take out the wrapper carefully, line up the arrow with the cartridge and insert it into the cartridge then snap it into place, replace the cartridge in the machine when you are done.
Thats it.
This fix is for the small finisher that hangs on the machine, it`s called M1 Finisher.
If you need a service manual for this model machine you can get it here
http://www.techmanualarchives.com/canon-irc-2620_3200-_3220-service-amp-parts--manual-25171.html
Oct 07, 2009 | Canon Image Runner 3320I Copier
Replacing staples
1-Open door in finisher ( where paper is delivered and stapled)
or push finisher away from copier and look on the right rear
2- remove the old unit by lifting up and out ( should be a small white box
3-before inserting new staples remove the band surrounding it : Careful not to drop, if you do you must make sure they face the right way in the box !!!!!!
4-insert in stapler
Sep 08, 2008 | Canon imageRUNNER 400S Copier
Inserting staples
If the machine has an in-built finisher, the stapler is located in the rear of device. Pull the finisher release handle and pull the finisher towards you. Extract the staple cartridge by pulling up in the green tab at the rear right of the finisher. The staple cartridge can be opened by squeezing the sides together to allow the spring to act. (Sometimes it can be helped with a screwdriver popping the clear tabs located on the underside). Insert the replacement staple pack and pull the orange tab before closing the cartridge shut. Reinsert into the finisher and push down to locate it. Should work ok after all that.
Nov 26, 2007 | Canon imageRUNNER 3570 Copier
Cannon imageRUNNER 3030
Stapler is located in the finisher. Open finisher door, remove empty staple cartridge, insert new staple cartridge, close finisher door. Check canon.usa.com for operators manual.
Sep 14, 2007 | Office Equipment & Supplies
Toshiba e-Studio 4540C Multifunction Color Copier Logo
27 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
