Question about Swingline Shredder, Cross-Cut, Auto, 100 Sht Cap, 17"x12"x17", Black
Where would I take this type of shredder to get fixed in Canada.
Where cn I get new suctioncups for my Rival Salad shredder?
You can order a set of four (4) from lallin@juno.com; as of 1/1/15, the price was $13.50, postpaid to US addresses, $14.50 to Canada.
Apr 24, 2014 | Rival Vintage Kitcheneer Shredder Salad...
I used WD-40 just once. How can I know if I damaged it completely?
WD-40 probably hasn't killed it, most of it will evaporate in time. It can cause the shredder to get gummed up with little paper particles so you might need to clean it out with some compressed air. I wouldn't use any sprays on a shredder unless Fellowes recommends it.
Apr 16, 2014 | Fellowes DM12C Shredder
My shredder does not shred in forward mode only reverse mode. how can I fix it?
Gene,
You would need to replace the motor in this, what type of shredder we talking here?
There is a lever that engages FW and reverse many times people jam these things and the lever also becomes effected. I would need the make and model and further details but it sounds to me its going to need a fix-in or a new shredder. I hope its not one of those heavy duty shredders because your looking on spending some cash there then.
Best of Luck
update me with make and model asap
Rulds2008
Mar 22, 2011 | Office Equipment & Supplies
I have a SECURE-SHRED (tm)shredder, approx. 10 years old, which will not operate at all. Is there a likelihood that it might be the power supply? If so, where can I obtain a replacement power supply? TDC...
Probably more practical to replace with a new shredder. There are several standards though.
If you wiki or google shredder standards you can check this stuff out. So if you're doing crazy stuff and you need it shredded like Enron did then go with one of the new Federal Standard type shredders, otherwise risk electrocution or a small fix if you try to fix it your self - time / money in doing so as well.
Thanks!
Jan 20, 2010 | Shredder Secure Shred Shredder
Was shreeding paper and it stopped? cleand it. thought it might be over heated. compucessery mo.#ccs60061. Its new. Thanks Mark
some of the new shredders do that so you should get a shredder that has a warrenty so if this happens again you dont have to worry about haveing to buying or fixing the shredder because when you try to fix these type of machines you ether end up just causing the machine to be comepletly unusable or it works of a little wile and u have to try to fix it again instead i advise you buy a replacement Fellowes® PS-79Ci doesnt jam and can dice 12 sheets of paper
hope this helps
Jul 31, 2009 | Compucessory Office Equipment & Supplies
Need Ativa X1800 Shredder Parts
Hey check out this link they service all types of shredders hopefully they should be able to service yours.
http://www.factory-express.com/blog/2005/10/paper-shredder-parts.html
Jul 03, 2009 | Office Depot Ativa DQ60M Shredder
We are in need of spare gear for Intimus 385 se shredder
I can provide you with parts. What broke on your shredder and can you provide me with the serial number?
Jan 16, 2009 | Intimus 385 se Shredder
My Ativa DQ60M shredder has damaged cutters in one spot. The paper packs in these cutter wheels and on occassion causes it to run continuously. Can I replace the cutter rolls?
Hi, I have checked into this with my shredders. There are plastic "cleaners" that break very easily and when they do, the cutters jam up. No way to get just the cleaners (that I have found). Very poor design. Only thing to do is to clean the rollers from time to time.
All of these types are shredders are mainly junk. I have one that is blowing the fuse. I am an electrical engineer and am trying to see what the fix is.
Jan 04, 2009 | Office Depot Ativa DQ60M Shredder
Swingline Shredder, Cross-Cut, Auto, 100 Sht Cap, 17"x12"x17", Black Logo
57 people viewed this question
Top Swingline Office Equipment & Supplies Experts
Paul Bade
Stitch85
Level 1 Expert
Are you a Swingline Office Equipment and Supply Expert? Answer questions, earn points and help others
