Question about Samsung "UN40D5500 40"" LED TV "
Micom upgrade On Service Menu I accidentally clicked on Micom Upgrade and then unplugged the tv when I freaked. Any fix without replacing the main board? Thanks!
2 Suggested Answers
ctf1800
  • 4402 Answers
SOURCE: no sound or picture
HLP, HCN HL-S The Start-up Problem or/and
3 LEDs in the front blinking.
Unplug the set, pull out the lamp module (not all the way - leave it on the track) and push it back in.
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Posted on Feb 06, 2008
Sanyo 5-cup Micom rice cooker, no power
I had the exact same problem with my rice cooker. I took the lid apart. There was a broken wire because of the constant friction of the hinge when open and close the lid. After I soldered it, it started to work again.
Jan 29, 2010 | Sanyo Kitchen Appliances - Others
Tv philips 20mf605t no power
write down the number of the micon if that is the component that you are suspecting and go online checking for company from who you can purchase the micon.one such company is dalbani.com and mcmelectronics.com
Aug 29, 2008 | Philips 20MF605T Television
Sharp 32U S50
Maybe a problem in deflection section. If there is a problem in these section the micom ic is trying to protect to continue anymore short circuit. Or there is a leakege in power supply section. This could be fixed by service technician only. Better to call nearby service people.
Jun 24, 2008 | Sharp 32U-S650 32" TV
Television will not come on after low voltage surge
Good day.
Check on the horizontal output transistor, vertical transistor, and loose contacts along MICOM and system ICs.
chris
Feb 09, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony32fs120
1. Try your Memory to replace.
2. Check all estated voltage in each particular section.
3. TRy also to replace your MICOM / System IC if your Confused.
Feb 07, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv switches itself off then back on again
Hi.
If the tv set is still under warantee get it sorted before gtee runs out.
The problem is caused by cummunication error between ATV Micom and DTV Micom.
To correct this problem requires going in to service mode to make changes & updating the DTV firmware.
This will need to be done by a proffesional.
http://dysonmanuals.llc.nu/
Chris.
Jan 02, 2008 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Adtran problem
try repalcing ethenet cable if that does not reslove issue either there is an accumulation of dust in the port or the port has gone bad.
Oct 11, 2007 | Adtran ESU LT Modem
No sound or picture
Sep 29, 2007 | Samsung HLN467W 46" Rear Projection HDTV
Samsung HCP4752W
You can not change a value in 480p or 1080i unless that is the incomming signal type. Unless you really understand these setting I would be careful of changing any.
Apr 13, 2007 | Samsung HC-P4752W 47" Rear Projection...
Samsung "UN40D5500 40"" LED TV " Logo
246 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
