Question about Andis Outliner II Hair Trimmer
Hair trimmers vibrate too much - Andis Outliner II Hair Trimmer
Hair trimmer vibrating too much
I also use Philips Norelco Trimmer doesn't vibrate. It's rechargeable so has a "rotary" motor instead of a "vibratory" mechanism. It does a great job on my beard, though I have not tried it for the hair on my head.
you must try it.
Jul 10, 2017 | Braun Health & Beauty
What's the role of the "power screw" ????
To adjust clipper/trimmers to run to their voltage needs. If clipper/trimmer rattles or over vibrates it may need adjustment to the line voltage in your area. Before adjusting, make sure the clipper/trimmer is clean and blade is oiled. Then turn the SMALL power screw clockwise on the side of the clipper until the noise disappears.
Mar 14, 2011 | Andis 01690 Hair Trimmer
Sideburn trimmer does not cut anymore but still makes noise. trimmer blade does not move.
It is pretty common for the trimmer to get jammed up with hair particles and skin oils which can prevent the blade from moving.
Try running the blades of the trimmer in a shallow dish of rubbing alcohol. Then clean the blades vigorously with an old toothbrush or similar. If the blades still does not move try using the tip of a small flat screwdriver or similar object to push and advance the moveable blade. Repeat running in alcohol and brush clean
If this doesnt work, you will probably need a new trimmer
Apr 15, 2010 | Braun 360° Complete 8985 Electric Shaver
What is nasal trimmer
This is a trimmer to clip those nasty hairs growing in your nose. J.
please rate my answer as very helpful. thanks
Mar 24, 2010 | Emjoi AP-4M Nasal/Ear Trimmer
The head of the trimmer vibrates like it is loosening
check the 2 screw that hold the blade and see if they are tight. if this is not the problem take the blade off and see if the lever in the middle where the blade sit is not broken.
Feb 15, 2010 | Oster 76997-010 Hair Trimmer
Andis Outliner II Trimmers
look if the trimmer is pulling hair, its not lack of oil
its maybe the speed of the trimmer needs to be faster.
its the the plastic flat head skrew on the side.check if the blades separate easiley if theyt do sometimes that makes the trimmer pull hair to.there might be a little plate on the inside of the trimmer and its not holding the blades tight.adjust that not to tight though then the trimmer wont cut
Dec 06, 2007 | Andis Outliner II Hair Trimmer
Andis Outliner II Hair Trimmer Logo
Top Andis Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Kolbrun...
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
