I have a Marantz na 7004 network audio player which was working perfectly until i disconnected the broadband- I couldn't get the unit to connect to the internet again, and iv'e followed the instructions as i did before. FM radio is working as well as the USB from a laptop. Would be grateful for any advise. Many thanks. Richard
Marantz bd 7004 stopped responding to remote commands after firmware upgrade
Did you upgrade your firmware because you had a problem with the player to begin with? Or was it working fine all along?
If everything was working fine before the upgrade, I would revert the firmware back to its previous version.
Nov 29, 2014 | Marantz Televison & Video
How do I connect CD player to marantz NR1504 with phono leads
Connect the cd audio out to the line in or cd in on the marantz
Nov 25, 2014 | Marantz NR1504 5.1-channel Home Theater...
Hi _ I have a Marantz CD player a littl;e over 6 years old. Performed perfectly until today, when it started inserting brief gaps in the music, approx 1-2 seconds; at the same time the track / time...
laser cleaning cd's very rarely work. the only thing they are good for is if there is a build-up of dust on the lens. Sounds like you most likely need to have the laser replaced.
Feb 11, 2014 | Marantz CD5001 CD Player
I have a Zhone ADSL2+ 4 Port Wireless Bridge/Router, model number 1518-A1-UK-0MA. it as working perfectly until one day when i turned it ON, only the ADSL LED is lit, no other LEDs are on, nor the power...
Please use the following steps:
1. Remove the router and connect it directly from the pc to the modem.
2. Power cycle: turn the modem off and then the computer for 30 seconds, then turn them both back on, modem first.
3. Check you internet connection to see if it working.
4. If it working, connect the router back up. If it not working contact your ISP for dsl support.
5. Once the router is connected, release/renew the ip address. Go to the dos command type ipconfig/release press enter. Then type ipconfig/renew. Check your ip address, you shouldn't get an ip address starting with 169. If you do, this mean you have a problem with the router getting an ip address.
6. Check you internet connection after the release/renew
Jun 10, 2011 | Zhone 1518-A1-NA Wireless Broadband Router...
My Marantz DR17 CD recorder works fine with TDK CD-RXG 74 min discs, but not with the modern 80 min version. The recorder freezes when updating the TOCs. Are there any currently available audio CD-Rs that...
Sony Music CD-R's available at Target (purple packaging not red - must be music not data). I had been using the TDK's from Costco until I started having issues similar to yours. Sony's work perfect - no issues ever.
Sep 16, 2010 | Marantz DR-17 CD Player
How to connect Panasonic BD60 Blu-ray disc player to 2 components
If there are red and white RCA jacks on the back of the BR player and on the receiver you should be able to get sound. The same as your VHS.
Dec 29, 2009 | Panasonic DMP-BD60K Blu-ray/DVD Player
No audio output - Marantz 2238
This can be as simple as a poor connection somwhere in the voltage regulator circuit or a defective driver transistor or output transistor. In any case, this is a simple repair for any shop that works on vintage receivers. If it is the outputs, that will be the most expensive repair from a parts perspective. The outputs will cost in the $5-$10 range for each one and it could be 2-4 pieces. If you wish to attempt this repair yourself, you will need a multimeter that has a diode checker. Let me know and I'll provide additional details and instructions.
Dan
Apr 06, 2009 | Marantz Audio Players & Recorders
I can not get surround mode on my Marantz 5200 receiver
Check surround mode on the on-screen menu of the amp
Feb 05, 2008 | Marantz SR-5200 Receiver
What does this Error Message mean?
hello AuburnCE, After 4 years of joy my Marantz SR8200 receiver also shows this message from time to time - after 1h of operation or so. Then it is hanging (like a PC ;o). Taking it of from the electricity network for a moment resolves the problem until the next POW 05 hang usually a fiew days later. I brought the receiver to an authorized Marantz maintenance and repair center twice now and they were not able to reproduce the error. They said this has directly or indirectly to do with the power supply unit. They also called marantz. For me it appears that this is not an internal receiver problem IN MY CASE. I think I there might be a relationship to zapping on my Topfield SAT receiver via power supply network as the connection is optical. Or my dimmerunit for the light. Unfortunately I do not have a separate electric circuit for Audio/Video and all other electrical devices. and dimmer units are well known to cause problems in the power supply chain - e.g. like noise in your audio package. Please note: the experts told me: Check POW 05 can have other (receiver internal) causes also. Above is just my suspicion 8as a non-expert) for my case . Regards, Fred
May 29, 2007 | Marantz ZR6001SP
Popping sounds in stereo during playback of burned cd's
Is it just the analogue inputsthat do this? Soulnds like a faulty input board.
Sep 16, 2006 | Marantz CDR631 CD Recorder
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
