Question about Braun Series 7 9585 Hair Trimmer
Why does my shaver turn off automatically when I turrn it on?
Turn on shaver then it shuts off. If I take the razor head off it works. Why?
    Master:
  • 966 Answers
Replace the razor head making sure it sits secure so it won't block the cover and let it spin freely.
Posted on Oct 21, 2013
2 Suggested Answers
Cytherian
  • 109 Answers
SOURCE: The razor head comes loose from the two arms.
I had a similar problem where one of the side covers popped off. I was able to reattach it, by carefully aligning the spring and pushing back into place. If you've lost the pin, you're out of luck. Braun does not make these kinds of parts available for user servicing, unfortunately.
However, the 7000 series models are all compatible with each other in terms of motor, battery, and razor head armature. You could try locating a moderately used example on the cheap (maybe less than $20) and then cannibalize it for the parts you need.
Do NOT send it off to Braun for servicing, as you will be charged much more than the shaver is worth. If it comes to that, you're better off just going with an 8000 series shaver.
Posted on May 23, 2009
Tip
How to use an electric shaver
If you are a using an electric shaver for the first time, I hope that this article will get you going. Proper techniques will ensure the best, closest shave possible. Maintaining the razor by properly cleaning and recharging it will also ensure that the razor works correctly and does not malfunction during use. Proper care and maintenance of the electric razor will also ensure that the razor will last for years to come. Consider this article as a shaving-best-practices template for your first electric shaver.<br /> <br /> Firstly, clean your face and dry it. Electric shavers do a better job when your face is clean. Turn the electric razor on and begin shaving against the direction of hair growth, moving the shaving head linearly and in circles. Circular motion Stretch the skin with your other hand to make the hair stand up straighter so the razor blades shave closer.<br /> <br /> After shaving, turn it off and rinse the cutting heads under warm water. You can also use jet clean system once a week to clean your shaver. Make sure that you charge it for the time specified in user manual. Overcharging may cause damage to the battery.
on Mar 03, 2011 | Health & Beauty
A red warning light is flashing...looks like the razor heads icon...what does this mean??
It's means that you should change new replacement heads, that Norelco RQ10 shaving heads for Norelco Arcitec Electric Shaver heads replacement parts.
Jul 06, 2011 | Norelco Arcitec Electric Shaver -...
What does a flashing red light at bottom of display when you turn razor off mean looks lit the 3 rotary blades
It means they want you to buy a new shaver head. U dont need too, and the light will automatically go off after 7 shaves from when it first came on.
Mar 06, 2011 | Norelco Arcitec Electric Shaver -...
Will the HQ55 razor replacements work on the 5601x razor?
HQ55 heads will fit in your model 5601X but they will not work as well as the correct heads. You will find the correct heads for your model at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-hq5-reflex-action-replacement-heads-p-246.html
Oct 24, 2010 | Norelco 5601 X Electric Shaver
I have a Philips Norelco 7310XL razor and I have a problem. I recently moved, and in the process, something happened, and my razor isn't working. When I turn the razor on, the blades turn slightly and then...
It sounds like maybe one of the blades is damaged and it is jamming the whole thing. Try taking apart the head assembly and then insert each head one by one turning the shaver on in between each one. This should identify if one is damaged and causing the problem
If you require new heads, you will find them at shaveroutlet.com. See link below
http://shaveroutlet.com/norelco-philips-hq8-spectra-sensotec-replacement-heads-p-251.html
Sep 18, 2010 | Philips Norelco 7310XL Electric Shaver
I have taken out the heads to clean and put them back and n ow it wont shave me
Remove the head assembly again and check to see if anything is out of place or missing. If not, try reinstalling the shaver head assembly and give each individual head a light push and spin to try to get the drive connections to line up with the razor.
Then turn the razor on and off quickly for a second or so to let the razor align itself with the shaver heads. If this doesn't resolve the issue, then my first reaction is that you're missing a part(s) that might have fallen out when cleaning.
Give it a try and let me know if it resolved the problem.
Hope you find this Very Helpful and best regards!
Aug 20, 2009 | Philips Philishave HQ7780 Electric Shaver
Replace heads light
I have been able to reset the replace head light on my 8894xl shaver by do the following: Step 1 - Fully charge and clean shaver Step 2 - Turn on shaver holding down on button until shaver display recycles from 0 to xxx minutes. Step 3 - Turn shaver off Step 4 - Turn on shaver again and hold down button until shaver beeps ONCE. (Light will go off)
Jun 09, 2007 | Norelco 8894 XL Electric Shaver
Braun Series 7 9585 Hair Trimmer Logo
96 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Joseph Hoffmann
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
