Question about Dell Office Equipment & Supplies
My Dell 2155cn printer is making a loud knocking noise everytime it prints, and the paper will rip and not fully print the whole document. The only way I can print through it is via the SSF manual feed in the front.
Inky
  • 691 Answers
SOURCE: Epson stylus photo 830
Yes it can probably be fixed. I hope you poked your friend in the eye for giving you such a headache though. You will need to dismantle the machine and remove the Auto Sheet Feeder (ASF) Once removed, check there is no bits of paper stuck inside. Then turn the pick up mechanisme by hand through a couple of revolutions to re synch everything. Also check the paper sensor is still intact - if not you can construct a new one from a piece of plastic or if the old one is still present, just glue it back together. You can download a service manual to hep you out with the dismantling from either: http://www.TheServiceManualShop.com http://mikeburton.tradebit.com/
Posted on Apr 12, 2007
  • 142 Answers
SOURCE: Printer sends out extra page everytime I print
either your paper size settings need to be adjusted in the software, or your setup has included a seperator page.
Posted on Jan 27, 2009
SOURCE: Paper feed not working properly
1. first check to see if there is any bits and pieces of paper in any place in the paper carriage -- look very carefully in front access and rear access
2. if this is not the problem, then disconnect printer from computer -- turn off printer, unplug power cord, unplug printer cable from printer
3. gain access to paper roller assembly, usually in rear
4. using lint free cloth, dampened with distilled water clean rollers -- read manual to determine direction of rotation (usually clockwise)
5. keep rotating rollers until all is wiped clean of paper dust
6. reassumble and try a test print as your printer manual directs
Posted on Apr 22, 2009
  • 40 Answers
SOURCE: hp laserjet p3005dn tray1 manual feed problem
you can choose mp first in "paper handing" printer menu or print tray1 is A4 default in properties of printer software.
Posted on Jul 27, 2009
  • 118 Answers
SOURCE: hp 4250 manuall feed heavy paper message
You'll have to set up the paper settings within the copier to reflect heavy paper for the bypass tray. You'll need to make this a default setting. Then when you print out with heavy paper via the print drivers it should pick up automatically at the printer.
Posted on Aug 28, 2009
Change BLACK AND WHITE DEFAUT TO COLOR
You can change the font color in the document you want to print.
(This will not help if the printer refuses to print blue while the black toner is empty.)
May 12, 2014 | Dell Office Equipment & Supplies
Dell 2155cdn toner rubs off
It sounds like the fuser is not heating up to the correct temperature. If you are printing on specific papers, for example: envelopes, bond, linen, make sure to set your printer settings accordingly. Otherwise you will need a new fuser unit for the printer.
Feb 19, 2014 | Dell 2150cn / 2150cdn / 2155cn / 2155cdn...
2155cn printer giving error #006-370 what should I do
Power off the printer and turn it on again with the big button held down (the one with the tick on it).
This seems to clear the error and allow printing but won't fix the fault itself.
Feb 17, 2014 | Dell 2150cn / 2150cdn / 2155cn / 2155cdn...
Dell 2155cn will not print
Hi Joyce,
Use this link for help:
Troubleshooting Printhead Problems on the Dell AIO V313 V313w V515w...
  1. Turn off the printer, and remove the Printhead out of the printer,
  2. Connect the printer and the computer with a USB cable and turn on the printer.
  3. Open this link in the computer:
Drivers Downloads Dell US
4.Select the operating system of the computer from the list of options.
5. Under the Firmware, select the right Firmware according to the printer model depending on Wifi mode.
6. Click "Get driver" and follow the onscreen instructions and update the Firmware software.
7. Reinsert the printhead and try printing and check.
OR
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Dell Printer Support
Feb 05, 2014 | Dell 2155cn and 2155cdn Color Laser...
When I go to print Avery labels 5160 i get the error code load ssf 024-0969. I can print all other documents
Hi, Brad;
the label with the adhesive on the back when it go through the heating unit it goint melt will coming off and stick on paper path it cause paper jam, sugest print label use inkjet printer.
Oct 31, 2013 | Dell 2155cn and 2155cdn Color Laser...
Dell 2155cn Installs without error, but won't print
Most router (DHCP servicer) issue an IP to any device on the network, is your PC on the the same subset of the network? Can you ping the printer? Check your printer and device property, make sure you have the same IP address and you're on the same subset.
Feb 02, 2012 | Dell 2155cn and 2155cdn Color Laser...
Need a printer driver for Dell 2155cn for Mac Os X Lion
Google Cloud Print works with all printers I've tried. Good solution for those printers with no Mac drivers
Jan 25, 2012 | Dell 2155cn AllInOne Laser Printer
Dell 5310n knocking noise when printing envelopes
This is a good thing. The 'knocking' noise is actually called a "Thumper". It's purpose is to get the air out of the envelope before it hits the fuser. Air in the envelope typically leads to creases on the envelope itself.
Feb 25, 2009 | Dell 5310n Laser Printer
Dell printer not printing!!
Ok, did you first make sure that the cartridges were fully inserted and not empty?
Feb 27, 2008 | Dell 922 All-In-One InkJet Printer
284 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
