Question about Dell Computers & Internet
Locating fuses I shorted a USB and now all USB ports are not working. The computer still boots to the login screen just fine but I don't have a mouse or keyboard to go any further. From what I have been reading there are fuses that could have been blown that would stop all USB ports from working but I have been unable to locate them. Could you help me locate these fuses?
  • 5 more comments
  • Scott Hunter
    Scott Hunter Oct 21, 2013
    I reinstalled the drivers and now the front USB ports are working. Only the USB ports on the back aren't working now.
  • John Selph
    John Selph Oct 21, 2013
    First thing I would do is to check device manager and see if any USB devices show up yellow or red. If so, it could still be a software issue. If not, check system BIOS setup and make sure all USB ports are enabled. If all else fails, you can purchase a powered USB hub for just a few dollars and plug it into one of the working ports.
  • John Selph
    Or, you could get an add-in USB card which would give you the rear USB ports.
  • Scott Hunter
    They are enabled in BIOS and they are not yellow or red in the device manager. It is a work computer where those ports are needed without an add-in or hub. I have to get it fixed or replace the motherboard.
  • John Selph
    I don't think the fuses are user replaceable. Most techs will not address "board level" repairs, especially on motherboards since they are multilayer. If you can locate the bad fuse, sometimes a new one can be soldered right on top of the old one, but it's never a good idea to attempt to solder anything on a motherboard. If it were me, I'd opt for replaceing the mobo.
  • John Selph
    One other thing to check is to open the case and see if there is another USB port on the mobo. Sometimes there is an unused USB3 or similar plug that could be used with a dual port USB "slot" adapter. I say this because I surmise that the rear port that is blown is the "embedded" port on the mobo.
  • Scott Hunter
    Scott Hunter Oct 22, 2013
    I am a R&D Electronics Tech so I am comfortable soldering on the motherboard. We have a board maker so I can make a board and attach to the motherboard if I need to. We are probably getting a new motherboard anyways but I would still like to fix this one. My area of expertise is not in computers though so I am having trouble locating the parts that would might be bad on the motherboard.
  • 37 Answers
Usually, if you short a USB port, only that port will be affected. Try booting to safe mode and reinstall the driver.
Posted on Oct 21, 2013
  • Scott Hunter
    I reinstalled the drivers and now the front USB ports are working. Only the USB ports on the back aren't working now. The short was plugged into one of the rear ports
5 Suggested Answers
muttuswami
  • 42 Answers
SOURCE: my usb ports aren't working at all
try reinstalling the chipset drivers from
http://support.dell.com/support/downloads/driverslist.aspx?os=WW1&osl=EN&catid=27&impid=-1&servicetag=&SystemID=PLX_GX620&hidos=WW1&hidlang=en
Select the Operating system
The Category as Chipset
Importance should be All
Click on the Intel driver
Download now
File name is R132539.EXE
If this does not work you will be having 2 usb at the back and in the front of the system.IF the back does not work than you need to get a local tech out at your place as it is a problem with the USB controller on the motherboard and that might have to be replced .If it is the front USB (Only if you have them) then there is a cable coming from the USB controller to the fromnt usb ports that cable might have got unplugged for that you need to open the tower.But i would still recommend a local tech.
Posted on May 27, 2008
  • 490 Answers
SOURCE: Unable to use my computer. Usb keyboard, mouse fail
See buddy
If the BIOS it self is not opening means that it is not getting started,at the timing of power startup it just goes off with out showing anything the issue might be with the BIOS cell check that out otherwise there might be any issue with the BIOS than u have to consult with the vendor,
Now in second case where it is not working after the POST is done than might be the first boot sector has gone faulty you have to reinstall the OS.
ANd in if case it is giving a long beep before shutting down the issue might be with RAM check that out.
Inshort the issue might be with three things
1) BIOS cell (change the bios cell)
2) BIOS itself (consult vendor)
3) OS (Reinstall the OS)
4) RAM (Swap or change the RAM)
PLz do rate incase this info is important or giving u any benifit it helps us...
Thanx
Gizmo
Posted on Dec 20, 2007
  • 139 Answers
SOURCE: Compaq EVO D500 Keyboard/Mouse Issues
Just read this carefully as you will get a problem to your solution.
My Computer ->right click ->properties ->hardware -> device manager -> in last you will find USB controllers -> unistall all the usb controllers one by one. Restart the machine and your USB devices will be working fine
Enjoy
Posted on Jan 13, 2009
SUPERMAN_B_1
  • 294 Answers
SOURCE: Dell C521 Will boot to User login But cannot use mouse or keyboar
did you try starting the computer with both mouse and key board allready pluged in so it can recanize that there pluged in,no any mouse and key board will work also did you switch the 2 to make sure you did'nt have them pluged in the others spot?
Posted on Mar 10, 2009
What do I do ,my mouse is not moving the careen?
IF IT IS A USB MOUSE UNPLUG IT THEN PLUG IT BACK IN AFTER 5 SECS OR SO. IF THAT DON'T WORK TRY ANOTHER PORT IF IT IS A USB MOUSE. ALSO SOMETIMES OTHER DEVICES CAN CAUSE IT TO LOCK UP THAT MAY BE CONNECTED TO A USB PORT LIKE A PRINTER. MOST DESKTOPS COMPUTERS ALSO HAVE USB PORTS ON THE FRONT OR TOP OF THE MACHINE AS WELL AS THE BACK. GOOD LUCK.
IF YOUR SCREEN IS TOTALLY FROZEN THEN MORE THAN LIKELY IT IS A PROGRAM THAT IS CAUSING THE LOCKUP. THEN BOOT INTO SAFE MODE AND ROLL BACK THE REG A COUPLE OF LOGINS IF POSSIBLE. GOOD LUCK.
Feb 19, 2016 | Computers & Internet
Dell E521 cannot get to bios with usb keyboard.
check the loose connection on mother board try to reconnecting again then after that power on the computer quickly press f2.
Mar 06, 2010 | Computers & Internet
Not responding, batteries good per the tester, dongle plugged in to USB port, was working fine for weeks months
Try testing the mouse in another computer if available to make sure the problem is not the mouse. Also try removing the usb dongle, re-boot the computer, and then re-install the usb dongle in a different usb port then the one you removed it from. This might bring the computer back recognizing the usb mouse. You could also go into the control panel(if you are using windows) and then into the device manager. Then try removing the mouse in the device manager and then re-boot the computer and see if that works.
Dec 18, 2009 | Logitech Cordless Mouse
Ps2 port doesn't recognize Microsoft Optical mouse
You might think about a USB hub for all your USB devices. ps2 port is more or less dedicated for mouse, which is why your mouse pointer is stuck in the middle of the screen. Go ahead and get an externally powered USB Hub to power other USB devices. To answer, ps2 for mouse needs just a mouse, not USB device.
Sep 28, 2009 | Microsoft Windows XP Professional
Same prolem with a m8s dell dimension 3100
Every Device connected would lit up while you start the computer,power on self test.Set the BIOS to Default.
Jul 06, 2009 | Dell Dimension 3100 PC Desktop
Keyboard not responding
Have you tried a USB keyboard and mouse wired.try also to hook up the normal keyboard and Mouse with out any usb devices hooked on the computer
May 05, 2009 | Logitech 967461-0403-PK Keyboard/Mouse
If it is a USB then it should work with any keyboard and mouse. When you say it shuts off after XP loading screen, does the machine power off? have you tried unplugging the mouse and keybaord and let Windows load?
Mar 10, 2009 | Dell Dimension C521 PC Desktop
Usb issue
Do you have a ps/2 keyboard/mouse? Or a usb->ps/2 adapter. I'd say boot up normally and log in with the ps/2 keyboard/mouse. Then, from device manager, right click everything under USB and such and uninstall. Then right-click your computer name in the device tree and scan for changes.
Feb 16, 2009 | Dell Dimension C521 PC Desktop
Dell Dimension 3100 e10 ...usb won't work
Does the system respond to boot keys (F2, F12) when the DELL logo appears? If so the problem is with Windows drivers and probably can be resolved by reinstalling or rolling back the drivers, but how? Do you have access to another keyboard? Does the system have PS/2 ports? Do you have access to a PS/2 keyboard or adapter? If boot keys work, you could also choose F8 for Last Known Good Config (XP) or System Restore (Vista).
Have you tried different ports (front if using back or visa-versa)?
Try using just keyboard or mouse to see if one has somehow shorted. Also check the ports for any sign of damage.
Jan 10, 2009 | Dell Dimension 3100 PC Desktop
Computers & Internet Logo
62 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
