When I turn my Computer on IT comes up on a black screen saying *SIGNAL OVER RANGE* Also I messed it up in safe mode so I cant go on safe mode either! and It was working fine just after I rebooted it , then about 4 days later.. I got the problem again... Any solutions? .. Thanks - Tyler Jordan Crooks.
    Top Expert:
  • 12,223 Answers
Go to control panel use the utility Restore system. and put the last days that you know was working good, and fix it.
However you must RUN the antivirus+anti-malware VERY IMPORTANT.
God bless you
Posted on Oct 22, 2013
siawolf
  • 749 Answers
SOURCE: Computer will not start past safe mode screen
In safe mode, hit start button -run, and type "msconfig" in the box , hit enter.
the system configuration utility opens.
select startup tab at the top
when the startup screen opens, UNcheck all the boxes, press APPLY, then OK
the computer will prompt you to restart, when it restarts it will give you a message saying you have use the system configuration utility to change the way windows starts, this is normal. Check the box that say dont show this again and click OK.
doing this will keep the programs set to start when windows starts from starting untill you start them manually. If one of them is causing the freeze, this will make the system accessible.
Keep in mind, you may want to turn some of them back on after you get the computer going and when you do , turn them on one at a time and restart the computer after each change. this way you can identify which program is causing the problem.
Hope this helps. please repost if you have more questions
Posted on Oct 08, 2008
SOURCE: Monitor will not start up!!
سلاموو..
يوجد لدي"acer T310" المشكلة الي فيه...نسيت الفلاش ديسك مشبوك فيه...ولمن أعدت تشغيله طلب مني أضغط على "F1" لحفظ التغيرات .... وأنا طبعاً فصلت الفلاش ديسك بدون ماأضغط ال"F1" وأعدت التشغيل.....هنا ظهرت المشكلة..لم تظهر الشاشة.
طبعاً حاولت أفصل الرام عشان أسمع إذا بيجيب صوت إنه الرام مش موجودة ....لكن ما جاب صوت نهائياً...
ومش قادر أحدث ال"BIOS" لأنه ما يدخل على ال"DOS" نهائياً...
فيا ريت من معاه حل لايبخل عليا ويرسل لي على البريد الموضوع تحت..لاننا صدق زعلان على خسارة الجهاز..
وشكراً على إهتمامكم بنا...أخوكم ....كمال حيدر
البريد هو/ aboulshamiz@yahoo.com
ولكم جزيل الشكر والإمتنان
Posted on Nov 30, 2008
  • 2692 Answers
SOURCE: Running Vista system restore 8hrs (not in safe-mode)
I am fairly sure that if you stop the system restore mid stream it  will just resort back to where it was w/o any problems.  Then you can restore in safe mode. If it took that long ,if I were you , i would go and clean the harddrive or run check disk or download hard drive tools from;    seagate.com      and check the hard drive .  Your other option is to use you restore disk and restore the whole thing. If the hard drive is bad you will ending up doing this after you install a new hard drive.
Posted on Jan 17, 2009
Fixe_You
  • 1800 Answers
SOURCE: Computer monitor stuck in safe mode
the problem is with ur Computer's Graphic card.
u can put a new one in case if it is a built in graphic card Chipset.
check ur manufacturer support page for more details.
plz rate this post as good as u can
Posted on Feb 06, 2009
championfutu
  • 5 Answers
SOURCE: Can't get PC to boot up, monitor says power saving mode & beeps
JUST CHECK FOR MEMORY
Posted on Jul 13, 2009
Emachines T6524 won't reboot after automatic update. I get the windows screen when I turn it on, and everything seems fine, then the screen goes black and I get the no signal message.
You should try to boot in safe mode without the card removed..If this got on after an update it is possible (almost sure) it messed up with your graphic card driver and now it needs to be reinstalled > To do so ..try to boot in safe mode...To do that press the key indicated on screen for boot menu and choose safe mode ...usually it is f8 key or f12 ..depend on the model .If it seams not to be able to find the safe mode boot ..try to stop the computer by unplugging it ..This will force it to stop improper way ..and will show the screen for safe mode and other ways to boot-up .select the first safe mode ..and let it start ..This mode will not load any drivers and work just with the minimum needed for to start .Go to control panel ...remove programs ..and remove the graphic card driver from the list ..after that if you have the disk insert it and run the driver again in original ..If you do not have it look for it on the manufacturer's site ..and download it ..
If you need help with the driver ..let me know exact model of the computer ..and if it is not an on board card I need to know the exact model of the video card ..
Dec 30, 2011 | eMachines T Computers & Internet
When OS starts I received an over range signal and my monitor turns black
1. restart your computer
2. change it to safe mode
3. change your screen resolution to lower
4. save and restart . .
have a nice day
May 10, 2011 | Computers & Internet
Over Range Signal
OK, you need to boot up in safe Mode, then change your screen resolution, to say 800x600, or 1024x768, this will then allow your monitor to operate, IF this doesn't work, then you will have to swap out, the Monitor and VGA card to find out which one is faulty.
May 22, 2010 | Star Logic 17" LCD Monitor
When i turn it on it says out of range and i have a black screen
Hi, The reason behind the out of range (frequency of monitor) because the video display adapter is trying to set resolution more than what the monitor (screen) is capable of. In this case, try to boot your computer in Safe Mode using F8 function key while starting your computer. Once you are in safe mode, try to decrease the resolution of monitor to the lowest resolution level and apply the settings. Now try to boot computer in normal mode once again, you will get the settings which you have applied in safe mode. Adjust the screen resolution accordingly till the settings work with the monitor (screen).
Cheers!
Mar 01, 2010 | Microsoft Windows XP Home Edition
Input signal out of range
You could try going into safe mode and make sure the correct drivers are installed and if they are then you can then set the correct resolution.
Feb 28, 2009 | Dell OptiPlex GX260 PC Desktop
Inspiron B130 won't boot
plz try to boot through safe mode, if you can then log in normally.
if you cant boot from safe mode then you have to reload or repair your os.
Dec 23, 2008 | Dell Inspiron B130 Notebook
I ran a driver scan on my ACER Power2000 and the results said one of my drivers was out of date. (Unfortunately I didn't note which one it was, except that it was an Intel.) So I downloaded and installed...
Hey
Ok, the resolution the computer is using now is out of the range that is supported, try another monitor or try pressing F8 on the startup to get the advanced startup menu then select safe mode, in safe mode uninstall the driver you installed, this should return it to normal, then restart the computer and in normal mode you will need to install the old driver to get everything back to normal.
Dec 04, 2008 | AcerPower 2000-UD431C - Core 2 Duo E4300...
Can't get screen display
Out Of Range
Do the same procedure you do to enter "safe mode" but this time choose the "start in VGA mode" option, then change windows resolution.
May 08, 2008 | iiyama ProLite E380S-S 15" LCD Monitor
I was adjusting picture on monitor and now picture completely messed up
  • Signal out of Range.
  • Out Of Scan Range
  • Horizontal frequency is out of range.
  • Cannot Display This Video Mode Out of Sync
This issue may occur if the signal from the video adapter exceeds the scan range of the monitor. The video adapter setting for updating the screen (the refresh rate) is incompatible with the monitor.
you should reinstall your video drivers in safe mode.
To restart in safe mode repeatedly press the F8 key during the computer startup. This will bring a menu where you'll be able to choose safe mode.
LCD monitor 60 - 75 Hz
Jan 25, 2008 | IBM E74 17" CRT Monitor
Computers & Internet Logo
11 people viewed this question
David Payne
David Payne
