Question about Creative Labs SBS 370 Computer Speakers
I have intex it2000 2.1 speakers,of which the volume, bass and treble controllers are not working. i want to remove the controllers and make it direct with full volume, bass and treble.which wires do i need to connect with each other.there are 7+6 wires.pink,brown,black,white,grey,purple,blue in one set and green, yellow, orange,red brown black in other set.
5 Suggested Answers
SOURCE: UC-280 speakers volume control not working
I purchased my new PC at Walmart. They did not know that the moniter had builtin speakers. My problem is solved. Thank you
Posted on Jan 27, 2009
anand_sachan
  • 89 Answers
SOURCE: I need a power supply/
Hi, Yes you can purchase the power supply and base control for you creative product. You can go to the website www.buy.com or you can select the below link to go to the webpage directly. http://www.buy.com/retail/usersearchresults.asp?querytype=home&qu=Creative+Labs+Inspire+T2900+power+supply&qxt=home&display=col&cb=422451212
You just need to type in as what you want in the search box and then select from the categories available. Free shipping is also available.
Hope it Helps. Regards Anand Sachan
Posted on Nov 06, 2010
SOURCE: Creative Speaker Of Model SBS-370 The Volume Control is not working, How to directly Connect those two Wires connected to Volume control,bypassing the Volume Control Switch
1. connect:Both Ground (copper wires) with Green wire
2. Connect Red with Blue and
3. Connect White with Yellow
This will give Stereo Output.
Posted on Feb 06, 2012
SOURCE: Creative SBS 2.1 370 Speaker.
posted by Sandeep Sharma
hai, Here is the solution. when u cut the PCB from both sides u will find 4 cables i.e. green blue yellow and a copper wire coming from woofer and 3 cables white, red, yellow coming from audio lead. connect the green cable to copper cable and yellow to blue coming from woofer. Now take white cable coming from audio jack.connect this with yellow blue cables of woofer. Now attach Red and Yellow, connect these to green and copper cables of woofer and enjoy. if problem persist then make experiment to make interchanges with red white yellow coming from audio lead to the 2 sections of woofer side. woofer connections green/copper and yellow/blue remain same.
an.astrologer@gmail.com
Posted on Oct 03, 2012
Where can I find a satellite speaker that controls the sound?
For the most part volume is controlled on computer, though speakers may have separate volume \ bass \ treble controls. Or, are you looking to purchase?
Aug 31, 2012 | Harman Kardon SoundSticks II Computer...
I lost the treble on both Alesis Monitor 1 speakers. The treble is good on the amp output toward the speakers. I'm thinking they went out one at a time and I didn't realize it until I lost the...
It's probably blown tweeters. But if you want to spend the money on a hipshot guess, try to find the the crossovers somewhere first; then find the readily available tweeters if/when that doesn't work out. Google "alesis monitor one MK2 tweeter".
You could test the tweeters by just removing one non-functional tweeter and wiring it directly to the speaker leads and with REALLY LOW volume containing NO BASS see if it makes any sound, which would prove it does/does not work.
Going forward, if the speakers sound stressed at high volume - THEY ARE. Too much power or too much distortion (overdriven amplifier) will kill speakers.
Sep 16, 2011 | Alesis Monitor One Mk2 Speaker
A creative speaker SBS A200 connector pin was damaged. we need to connect that cable directly into the board.so we need that pin details.
Hi, I hope this helps,
Pins look like this: (Top view, not copper side)
1 2 3 4 5
6 7 8 9
1 = Thin white wire from thick white cable (Left input)
2 = Gray (Speaker out)
3 = Orange (+V return from volume unit to bass unit)
4 = Not connected
5 = Thin Red wire from thick red wire (Right input)
6 = Blue (+V power from bass unit to volume unit)
7 = Black (GND - if socket removed, solder 3 socket shield holes to each other or solder black wire directly leftmost hole)
8 = Not connected
9 = Shield copper from thick red wire
Shield copper from thick wire : Solder to GND or Left unconnected
Jun 23, 2011 | Creative Technology SBS A200 2 Speakers
What are good settings to have to make the music sound clear for a jvc KD-R310 deck?
you will need to access the bass and treble setting on the unit.
If you have stnadard speaker then dont put the bass to high as you can not turn the volume up high.
The same for the treble.
Set them at about the same and turn the volume up until it sounds good.
If it is to quiet then turn the treble and bass down and then the volume up more
Mar 02, 2011 | JVC AM FM CD DET FACE CAR STEREO
No sound
If you know your speakers are working and there is nothing wrong with them go on your computer and go to sound settings in control panel and adjust treble bass and volume.
May 30, 2010 | Insignia 2.0 Speaker System (2-Piece)
Hey there, I have JLB Creature II speakers, that have been working fine for nearly a year. Until one day, when the treble's maximum volume became a lot lower than before. The bass still rocks it up like...
Hi Nikita,
The problem may be with the internal electronics of these speakers, especially the sub-system that controls the treble. If they are still under warranty, you should talk to the dealer. If not, you should contact a technician.
Hope that helps,
Regards,
Raspal
Mar 22, 2010 | JBL CREATURE II Computer Speakers
Can't adjust bass and treble
The only adjustments available on the unit are Volume and Bass (Subwoofer Level). There are no Mid-Bass or Treble adjustments.
Sep 20, 2009 | Jasco GE 98903 2.1 Speakers
I need to find out what buttons control the bass and treble
Press in on the volume control repeatedly to step through the menu of audio functions. The
first option is Volume, followed by subwoofer (only if the subwoofer feature is currently
activated), Bass, Treble, Balance, Fader and back to Volume. When adjusting audio functions,
the unit will automatically exit audio control mode after five seconds of inactivity
If you need the user's guide, click her to download.
Feb 21, 2009 | Jensen MP7610 CD Player
Creative Labs SBS 370 Computer Speakers Logo
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
