Question about GE JKP45 Electric Double Oven
My GE double oven JKP45 will work for a while and then the control panel will go dark and the oven shuts off. Is this something I can fix myself? Other than that it works beautifully, good temperatures etc.
jumptrout51
  • 3361 Answers
SOURCE: GE mod.JDS27G0P2BG Oven Wont start
You have a bad electronic control board.
No repair.
It must be replaced.
Posted on Feb 21, 2009
jumptrout51
  • 3361 Answers
SOURCE: Temperature is wrong
Many ranges show a beginning temperature that is higher than actual temperature, then the gap closes as it heats up.
Use a accurate oven thermometer to check your temps.
If it is faulty, it will not recalibrate to offset 200 degrees. You will have to replace the ERC.
Posted on Mar 20, 2009
Sea Breeze
  • 4654 Answers
SOURCE: GE Profile JT952 Touch Pad Button Issue
Try this link
http://www.fixya.com/howto/h155060-dreaded_f7_error
Posted on Mar 28, 2009
heatman101
  • 43501 Answers
SOURCE: replace or fix a 10 year old JTP56 GE Profile double oven
The heating element is easy to replace and you can buy it online...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on Apr 26, 2010
SOURCE: GE JKP45 double wall oven shuts off
Several months ago, my lower GE JKP45 oven started making funny noises and stopped working at the same time. The same thing happened to my top oven recently. I can still hear the funny noises unless I leave the door open. And if I close the door then the noise starts again and the door will lock itself and won't open for awhile before suddenly I am able to open it.
Posted on Mar 17, 2011
Neither oven will heat when start is pressed, get a clicking sound from panel, temp stays at 100 deg.
Check for 220v as 110v will give one leg of power but not both. your breaker. or your control board is faulty.
Sep 03, 2012 | GE JKP45 Electric Double Oven
My GE JKP45 double oven needs a new control panel (part # WB27K5047 which is no longer available) There are a few place I've found on-line that refurbish electronic panels, or if it only has a loose...
according to the website i use to look up part#s while the part# you have is indeed not available a replacement for it is WB27T10050
to removeand replace it unscrew the screws that hold it to the cabinet pull it out about 4-6 inches,remove the grill directly under the control panel on the upper oven and look for screws around the panel where ya have pulled it out of the cabinet
to see yourself the replacement part# go to searspartsdirect and enter the model# and you will see the eoc (electronic oven control) as item #16 under the control panel and top tab
Jul 20, 2011 | GE JKP45 Electric Double Oven
Getting F1 on the display and the oven shuts off
Error F1 means that the control panel has gone bad and to resolve this issue it should be replaced. Unfortunately there is no other way it can be resolved.
The part is no longer available so unfortunately the only way to fix the issue is to remove the control board and mail it to a place like Appliancetimers.com to have them refurbish the parts. This will likely cost $200 or so but it's the only way to fix your issue at this point.
Additional details about this part coudl find in this DIAGRAM PARTS LINK.
Good luck (remember to rate and comment this answer).
Jun 17, 2011 | GE JKP45 Electric Double Oven
Oven is display F-1, what the problem? Model JKP45
Hi
Thanks for using FixYa. Error F1 in your GE Electric Double oven means that the control panel has gone bad and to resolve this issue it should be replaced. Unfortunately there is no other way it can be resolved. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 23, 2010 | GE JKP45 Electric Double Oven
F1 error beeping steady
This is usually a problem with the oven control but sometimes can be caused by the keypad. You may find this description useful:
http://www.fixyourboard.com/techzone/ovens/f1_error/f1_error.html
Best Regards,
Bruce
Jun 15, 2010 | GE JKP45 Electric Double Oven
Bake element doesn't heat, broil does. When I turn on pad, it goes to 100 but won't heat up
replace element. it is approx 19 dollars. 2 screws in back and then 2 screws holding element to wires. not a hard job
Nov 12, 2009 | GE JKP45 Electric Double Oven
Cant read control panel. LED is very dim JKP45
Ordered a new panel . Control panel is not serviceable
Oct 12, 2009 | GE JKP45 Electric Double Oven
This sounds like a loose connection (solder joint) on the main control board. I had one that had a similar problem. checked the price of a control board $350. I took the control panel off, took the board apart and found a loose connection on one of the relays. resoldered the bad connection. oven works fine now.
Nov 07, 2008 | GE JKP45 Electric Double Oven
Top oven will not heat up
Had a similar problem. The overheat sensor had failed to the open position and the oven control would light up and you could set the temp, but it would drop to 100 degrees and then go blank.
Nov 14, 2007 | GE JKP45 Electric Double Oven
GE JKP45 Electric Double Oven Logo
54 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
