HI I HAVE A MXT SET TOP BOX, THE MODEL NUMBER IS MSTB202SD, AND AN OLD ANALOGUE SANYO PORTABLE TV WITH VIDEO AND AUDIO OUTPUT ON THE REAR AND FRONT OF TELEVISION, THE BOX WAS ORIGINALLY TUNED INTO THIS TV, BUT I STOPPED USING IT AND LOST THE REMOTE.....CAN SOMEONE TELL ME WHICH CABLES GO WHERE, ANTENNA, LOOP IN ETC., AND HOW DO I GET IT TO WORK AGAIN WITHOUT A REMOTE....ANY SUGGESTIONS WOULD BE GREAT....THANKS
4 Suggested Answers
SOURCE: old philips tv model no 21PT1532/05
this may be too late, but i had the same problem, then discovered that if you press the top of the volume up/down buttons together, the menu comes up. I was trying to solve another problem this way when I accidentally locked the TV. The instruction booklet tells me that you can only unlock it with the remote control, but that has long ago bit the dust. Does this mean that I'll never be able to turn it on again??!!
Posted on Jul 17, 2008
SOURCE: cannot remove channel display from tv screen
Using the tv remote (or selecting TV button on cable universal remote) hit the INFO button. It remove the channel # for me. I might have a different model.
Posted on Apr 26, 2010
SOURCE: Sylvania 6420FF TV - SELECTING AUDIO/VIDEO INPUT w/o remote
During a recent move the remote was lost. I have the 6420FF in my son's room and trying to set up dvd and wi console set up, but cannot adjust tv via menu button on tv. Is there any way to set-up game system and/or dvd without remote?
Posted on Sep 06, 2010
What would cause the audio on my TV to go in and out?
The audio output circuit and speaker to your tv should be suspected. Just connect the TV to any external audio devices, like an Amplifier, connecting the TVs audio out sockets to Amps' audio in socket by means of an audio cable. If you feel sound problem with settings also, the digital processor board should be suspected. To give you more details, the exact model number to your Sanyo TV needed.
Apr 19, 2012 | Sanyo Televison & Video
How to connect HDMI set top box to analogue VCR and then to Digital tv to record
Most set top boxes with HDMI also have a yellow video out and white audio out for connection to a VCR or DVD recorder. Connect these two RCA cables to the VCR's yellow and white INPUTS for recording. Set the VCR to LINE input. For VCR playback, connect yellow video and white audio OUTS from VCR to your TV's yellow and white INPUTS. Select this input on the TV set.
Feb 13, 2012 | Sanyo Televison & Video
Help! My not so electronically inclined husband has a Sanyo stereo system (came with the marriage, the manual did not)..we just bought a HD Vizio, I want to hook it up to the Sanyo, but no manual and he...
I personally do not follow the route-everything-through-the-receiver model. Sound - ABSOLUTELY; Video? Nah.
Is the Sanyo a SOURCE of sound? More likely it's just the light show at the end of the Cable Box, which IS a source of high-end audio. Treat it as any digital source like a CD player for audio.
The Sanyo NEEDS a basic video output to the TV so you can use the Sanyo's menus. The Vizio NEEDS basic audio from the Cable Box (for watching news and other lo-fi content); and the absolute BEST video from everything.
As far as manuals for the Sanyo go, a model number would help.
Maybe run it by the manufacturer's support site or these guys...
retrevo.com
audio.manualsonline.com
hifiengine.com
usersmanualguide.com
Mar 30, 2011 | Audio Players & Recorders
My sister has just bought me a Sanyo 26 inch TV (LCD-26XR9DA) but it won't pick up SBS and ABC jumps all over the place. I have an outdoor antennae and had no problems picking up the channels on my old...
Go to the TV setup menu and autodetect all channels. This should fix it. This is assuming your Sister is not using a set-top box.
In that case, you neet to leave the set on either channel 3 or 4, or use the video/audio input jacks and leave the set on VIDEO IN. The best picture with a non-HDMI set-top box will always be with the AV OUT from the box going to AV IN on the set [the white/red (audio left/right) and yellow(video) connections].
If she is using a set-top box with an HDMI output, connect an HDMI cable to the set and select HDMI IN for the absolute best picture.
Jan 29, 2011 | Sanyo Televison & Video
I have a MXT Standard definition set top box model num: MSTB202SD. When I try to auto tune it comes up database empty, can you help?
The commonest cause of this problem is tuning the set top box when the aerial lead has become disconnected or is plugged into the wrong socket (should be in the rf in or antenna socket) . As part of the normal tuning process, all previous tuning info is automatically deleted and with the aerial lead disconnected you will then end up with nothing. Make sure the lead is properly connected to the aerial and tune again.
Another possibility is to go into the main tuning menu and select return to factory condition. This will force a main reset deleting all data and you will then have to work through the whole tuning process from scratch including, setting your State, setting the tv resolution (720p, 1080i etc.) If neither of these options work, and you are certain that the box is connected to a good signal, then the box may be faulty. Good luck.
Jan 02, 2011 | Televison & Video
2 AV inputs, only 1 works at a time.
hello try using a scart block at the rear good luck
Jul 19, 2009 | Sanyo Televison & Video
Don't know where the antenna input is on my tv
You can download the manual for this TV from Sanyo here:
http://www.sanyotv.com/CLT2054%20(E)%205071--.pdf
It has all the hookup information for you.
All the input jacks are on the rear of the set, and they are pretty clearly labeled.
You can connect the converter box two ways. One is to use the RF output from the converter to the antenna input on the rear of the TV. Then set the TV to channel 3 or 4, depending on the converter box setting.
The second method, which is better, is to connect the direct video and audio outputs from the converter box to one of the TV's A/V inputs. The cable you need is usually supplied with the converter box. Just follow the color-coded jacks at both ends: red and white for right and left channel audio, yellow for video. Then set the TV to that source. This will give better quality picture and sound from the box.
Please take a moment to rate this solution if it has helped you. Thanks for asking here!
Feb 07, 2009 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
JVC LT-Z37SX5 no sound when using hdmi connection to HD box
the tv has a configaration that conveys the sets focus on both audio and video performance. full hd resolution of 1920-1080 pixels.
hdmi inputs allow connection of the generation of 1080p sources for the systems which offer 1080p outputs
Jan 12, 2009 | JVC AV-36D303 36" TV
Televison & Video Logo
Top Televison & Video Experts
