Aeg lavamat 54610
Code 4
zeusfaber
  • 247 Answers
SOURCE: Problem C2 with AEG Lavamat 86741
Find the drain pump (on most front loaders, it's at the bottom of the machine at the front - often with an access hatch).
Open it up (you may want to tip the machine backwards and put a basin underneath to catch the water - and be prepared to close up again if the basin gets full before the machine is fully drained). Check that the pump impeller isn't jammed with a collection of old coins.
My next move would usually be to set the machine going in a part of the cycle where the drain pump is supposed to be running, and to give the impeller a quick flip with my fingertips (taking great care to avoid injury). If the pump doesn't run until you flick it, but then starts, this is a sure sign that you need to replace the pump motor - a quick, cheap and easy fix.
If the pump starts by itself, the the problem is more likely to be one of blocked hoses.
If the pump won't start at all, either by itself or when you flick the impeller, you need to check whether the pump is getting electricity. Do this by disconnecting the machine from the mains, connecting a voltmeter across the two terminals on the pump, then switching back on and selecting a bit of the cycle where the pump is meant to run. If you see mains voltage, then again you want to change the pump motor. If you don't, then check all the associated wiring before starting to look at the main timer. Disconnect the power before removing the voltmeter connections.
A.
Posted on Mar 05, 2008
SOURCE: AEG Oko-Lavamat 86820 Update Error code C9
Hello. I got error code C9 on a LAVAMAT 86800. It pumped in water, and it pumps out water. You can select pump in or out....But the motor dont turn. It will not sentrifuge. So I bought new carbon brush'es on the net. One of them were totally wore down. Now it works. They lasted for 10 years.
Posted on Feb 05, 2010
taran_2005
  • 10515 Answers
SOURCE: What means error code
C9 Indicates Motor Fault. It seems that the Carbon Brushes have Worn out.
Replace it and more likely it would Fix the Problem.Once you replace that, you need to put the machine into Service Mode to Reset the Error.
Steps for Reset the Error Code
1. Press and Hold the Prewash and Soaking Buttons Together.
2. Whilst Holding them, Turn the Dial from Off one Click Anti Clockwise
Note - If problem persists, Check the motor plug for broken wires and check the state of the carbon brushes.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Feb 28, 2010
  • 174 Answers
SOURCE: What does error code c9 mean?
c9 means there is no motor movement, typically worn out motor carbon brushes.
Posted on Jul 16, 2010
  • 174 Answers
SOURCE: aeg oko lavamat 72600 update, ce error code
error code ce is a faulty water distributor fault . you have to replace the top part of the soap dispensor compartment. sometimes you can hear a clicking noise when its trying to operate
Posted on Jul 20, 2010
Testimonial: "Cheers thanks very much, washer now working, great help"
How can I correct error code 25 on an AEG OK-LAVAMAT 74640 update washing machine mean?
Family error code "E20" means difficulties in draining, but I never heard for error code E25 on this model. Could be : E21, E23 and E24 error code.
Dado
Aug 24, 2014 | AEG Washing Machines
AEG Lavamat 64809 error code E30
Lavamat?! Where in the *&%^ is this machine from? Yugoslavia! I'm guessing it will not allow water IN Because only the Spin (Centrifuge) cycle works?! So if that is so you need your water inlet valves replaced, there are Two. Even in machines named after a Bar of Soap!
Jan 04, 2014 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG Lavamat 11842 Error code E66
http://bastlman.wz.cz/2010/08/AEG-Lavamat-error-codes.html
Feb 23, 2013 | AEG Washing Machines
I have a AEG oko-lavamat 75520 update. It stopped and the code C9 showes on the display. What does the code mean, and is this something I can fix my selfe?
Hi Mrs Willems from retired Englishman in SW France,
According to my list, AEG Lavamat 8*** Series Onwards C9 stands for 'tacho fault' (monitoring the motor speed) requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Aug 16, 2011 | Washing Machines
AEG Lavamat 76810 E70 7Beeps Does seem to still work but display shows E70 and 7beeps over and over. Many thanks gary
I Have AEG Lavamat 76810 E70 7 Beeps and Beeps never stops
The water was not hot
I took all the multi-plugs out and put them back in the whole machine ALL CONNECTORS
Now it works fine E70 is gone
Jul 14, 2011 | AEG Lavamat 16810 Front Load Washer/Dryer
Jul 14, 2010 | AEG Lavamat 72640 Front Load Washer
Aeg oko lavamat 72600 update, ce error code showing any idea?
Jul 09, 2010 | AEG Lavamat 72640 Front Load Washer
AEG Lavamat 16830 washer dryer
can anyone tell me how to remove the rear panel of a AEG lavamat dryer. regards Roy
Jul 20, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
