Question about Elna Sewing Machines
I have an Elna Diva. I am trying to sew fabric with a waterproof rubberized backing and my machine skips more stitches than it sews. How do I fix this?
    Champion:
  • 208 Answers
Because you have a rubberized backing the fabric is very tight and a loop cannot be formed properly, try using a leather needle
Posted on Oct 21, 2013
bargainbox
  • 1388 Answers
SOURCE: Machine not sewing
Make sure you have threaded the machine from right to left, it sounds like the needle thread is trapped under the lower looper thread and cannot form a stitch.........start the threading over from scratch like this:
  1. Lower Looper
  2. Upper Looper
  3. Left Needle
  4. Right Needle
Is there a diagram for how to thread on the inside of the door ?
Follow that slowly and carefully to make sure you have not missed any thread guides on the way, as each one needs to be followed through to ensure correct tension and thread progression.
If you are certain that all threaded correctly, did you have a fabric jam and pulled it loose ? If so, the timing may well be affected.
Post an update and we'll get this right.
Bargain Box
Posted on Feb 03, 2008
  • 14 Answers
SOURCE: ELNA 7000 SEWING MACHINE
If you bend over the front of the machine, you will see a slider switch on the back of the machine, and there is a small "button" at the bottom right of the switch (your right). If you push this button down, you can slide the slider switch to your right and the feed dogs will go up.
Posted on Mar 26, 2009
  • 43 Answers
SOURCE: skip stitch
The three most obvious causes (other than that of the machine possibly being slightly out of time) are:
1) Too small of a needle size - increase the size.
2) A needle that has a flaw / defect - change the needle.
3) Needle not inserted correctly, either not pushed all the way up into the needle bar, or not installed facing the correct place. On this machine, the small "scarf" in the needle (an indent just above the eye) shouldface the right side of the machine.
Posted on May 07, 2009
bargainbox
  • 1388 Answers
SOURCE: My Elna Supermatic model 722010 now skips stitches.
Take a look through this comprehensive list of
TROUBLESHOOTING
symptoms and possible solutions, it may also be useful for further reference in other times of need.
Check the timing of the needle to the hook. HERE is a guide to generic principles of Timing
Now also take a more specific look at tension issues....
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks
Best Wishes
Martyn
Bargain Box in Australia
Posted on Sep 10, 2009
  • 96 Answers
SOURCE: stitching loose. won't thread the fabric
try to rethread the machine all the way back to the spool of thread and check the top and bottom tensions on scrap of same fabric
Posted on Dec 13, 2009
What is the rght tension for The Elna Contessa 410 sewing machine?
Every machine is different, so a "right" tension will vary. The factory standard tension setting is the midway point between high & low number...BUT that needs to be tweaked per your machine.
Skipped stitches? Be sure to use a brand new needle and a needle that is compatible with the thread and fabric you are sewing. (Replacing an old needle is the most common and least expensive fix for a lot of machine problems.)
Optimal tension is when the upper and bobbin threads meet in the middle of the fabric.
Basic Maintenance Tension Skipped Stitches
What to Do If Your Sewing Machine Is Skipping Stitches
Feb 24, 2017 | Elna Sewing Machines
I have a CS 6000i which I have really appreciated. But now it is skipping stitches - mostly skipping. I have been sewing the same project and it had been sewing fine. What will fix it?
try increasing/decreasing the needle thread tension for the added material thickness
use scrap material until you get it right
Feb 14, 2017 | Sewing Machines
I have an elna 664 serger and I am experiencing skipped stitching. I am sewing thicker fabric, so I am assuming this might be the problem, but not sure. I was told it might be my timing but I am not sure...
SKIPPED STITCHES ON A SERGER
1. Is the needle bent or worn--replace
2. Is the needle inserted correctly into the needle holder--check needle
3. Is the Serger threaded correctly--rethread
4. Is the presser foot pressure right for the fabric--adjust
5. Possible timing problem--need to be checked at a sewing machine shop
May 01, 2014 | Sewing Machines
My machine runs but will not pick up stitch or skips stitches. how do i fix or adjust my machine so it will sew.
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Dec 02, 2012 | Sew Pro ZZ401 Sewing Machine
Sews fine on cotton, but skips on synthetic stretch cloth. Manual doesn't really offer a suggestion.
Needs to be a ball point needle for stretch fabric, sounds like you are using universal sharp needle. Stretch fabrics require ball point to push between the fibres, also, a slight zig zag stitch is more durable as when you stretch the garment during wear a straight stitch will often break, need some elasticity in the seams. Some machines have a stretch stitch too.
Oct 31, 2012 | Elna Xplore 8600 Computerized Sewing...
My machine is skipping stitches
Lower the pressure on the feed dogs, use a stretch stitch, and longer stitch length. Be sure to use a good quality thread, and maybe go lighter weight thread.
Oct 25, 2017 | Janome Memory Craft 9000 Computerized...
I have a Elna 6003. Recently I started having problems with the stitches skipping, and the machine was making a clicking sound. Now I have discovered that the needle is hitting inside the bobbin case and I...
skipping stitches can be the needle is damaged--flat side of needle goes to the back side of machine
normally when the needle is hitting the inside of the bobbin the timing is usually off, & can only be fixed by a sewing machine repair tech
Jan 31, 2012 | Elna Quilter's Dream 6003Q
Pressure foot on Elna Diva
Make sure your presser foot is in the lower position. Open the door on the left and it has 3 settings. You may have moved it up for sewing something thick, and forgotten to lower it again. Sometimes things are simple, though your problem could be mechanical.
Jan 17, 2009 | Elna Sewing Machines
Sewing Machines Logo
53 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
