Question about Primera Technology Primera LX400 Inkjet Color Label Printer 74261
Primera lx 1200 status monitor don't start - Primera Technology Primera LX400 Inkjet Color Label Printer 74261
LX810 Label Printer is printing out labels that are the wrong colour. Oranges are pink, darker colours are pink, and some are purple. I have swapped out the ink cartridges and the problem is occurring. Any...
It's time to clean the printhead. Use the procedure from the printer status monitor. Try cleaning several times but beware it will drain some extra ink from the cartridges. If the cleaning process will not increase the quality of print, probably you will need to replace the printhead. Before replacing printhead, remove all the cartridges and verify if all four gaskets (seals) are present on the inner bottom of the printhead. Also remove printhead, clean contacts both on the back of printhead and carriage with isopropyl alcohol. Put back printhead and cartridges and let the printer do its ink system initialization process. Then try to print your labels again. If all those attempts fails, replace printhead.
Apr 30, 2014 | Primera Technology Primera LX810 Color...
Nissan primera key
The key you are using may not be for that car. Visit a Nissan factory service dealership and provide your vehicles' VIN number to obtain the proper key, there is likely a radio transmitter built within the thumb handle of the key which communicates with the ignition cylinder. The guys at the parts counter should be able to provide further detailed assistance.
Dec 22, 2013 | Cars & Trucks
I don't have webcam in my acer
Some computers don't come with an integrated webcam, probably the best idea would to go buy a usb plug in one. :)
Aug 30, 2012 | Acer Aspire 5750Z-4885 : 2.2GHz Pentium...
Epson Status Monitor 3 : Epson LX-300+II ESC/P 'Communication Error' appears after printing successfully ?
Check all connections and make sure all devices are on. If the power was turned off during printing, cancel the print job. If the error does not clear, see your printer documentation.
Jan 28, 2011 | Epson LX-300+ II Matrix Printer
Where can i find the drivers for Epson LX-400 printer? Thanks
Please try this driver from the link below. It might be of help.
http://www.primera.com/ftp/XPVistaDriver/DriverCL400v1.30-32-64bit.exe
Inform me if it fails.
Dec 01, 2010 | Office Equipment & Supplies
How to change boud rate from 19200 to 9600
Here are the complete steps to change your LX-300 bit rate to 9600.
1) Load a paper with the friction lever up.
2) Hold the FONT button and switch on the printer. The printer must sense the loaded paper and must start printing some stuff. If not it rolls and tries to load the paper. In such case insert the paper again and press PAUSE button. Now the printer will print the stuff i.e) the current printer settings.
3) After the printing finishes (the print matter will be around 25% of a 11inch page length), press LF/FF. You will find the current settings. Check the current bit rate which is indicated in the 10th line of the current settings table.
4) Now press LF/FF which takes you to the Table B.
5) Now you are in table B and the lights 1, 2 and pause must be Blinking, Off, Off conditions respectively.
6) Now press the FONT button 9 times. After pressing FONT nine times, Light 1 = Blinking : Light 2 : Blinking : Pause light : ON.
This means that you are in Bit rate menu now.
7) Press PAUSE button.
8) Note down this order of bit rate and the status of 1, 2 and Pause lights.
--300 = ON-OFF-OFF
--600 = OFF-ON-OFF
--1200 = ON-ON-OFF
--2400 = OFF-OFF-ON
--4800 = ON-OFF-ON
--9600 = OFF-ON-ON
--19200 = ON-ON-ON
From the current bit rate you are in now, press the FONT button a particular number of times accordingly.
Suppose you are in 1200 bit rate currently, the lights status will be ON-ON-OFF. If you want to set to 9600 you have to press FONT button 3 times and the lights status change to OFF-ON-ON , which indicates 9600 bit rate.
9) Now, press PAUSE button so that the settings get saved.
10) Switch off the printer and turn it back on after 20 seconds.
11) Switch it off again, Hold the FONT button and switch it in again.
12) After printing finishes, press LF/FF and check the bit rate in the current settings that is printed.
You can have the user manual for your reference.
files.support.epson.com/pdf/lx300_/lx300_u1.pdf
Thats' it. You're done!
regards,
Sabharish
Sep 30, 2009 | Epson LX-300 Matrix Printer
Epson LX-300+ ''please insert paper'' error on Windows 98 system
try using an older driver from epson, sometimes you can luck up and find one that will work. try and find the prior model the one it replaced and see what happens. any of the 9x drivers should work try several just because one won't dosent mean another wont. hope this helps
Jul 16, 2009 | Epson LX-300 Matrix Printer
Don't know how to scan multiple documents and save
Here is the website for downloading your manual.
http://www.lexmark.com/publications/eng/1200/index.html
It may be able to help you. If it solves your problem please give a good rating.
May 01, 2009 | Lexmark X1270 All-In-One InkJet Printer
Primera Technology Primera LX400 Inkjet Color Label Printer 74261 Logo
22 people viewed this question
Top Primera Technology Office Equipment & Supplies Experts
Josh Whitehead
Josh Whitehead
Guy Loeffler
Guy Loeffler
Level 1 Expert
Martyn01202
Martyn01202
Are you a Primera Technology Office Equipment and Supply Expert? Answer questions, earn points and help others
