Question about Refrigerators
Whirlpool sb540w ice cube dispensor lose
fridgetech
  • 473 Answers
SOURCE: Whirlpool side-by-side refrigerator ice dispenser
First pull out the ice bucket and close the door.  Set for cubed ice.  Press the button for ice to come out and listen for a loud clunk noise.  That is the sound of the solenoid.  You can open the door, hold the light switch and press the button and watch for the solenoid moving up and down.  Solenoid is at the back of the freezer in a little square opening where the rod on the ice bucket goes into.  If that solenoid is moving ok then put the bucket back in while the solenoid is in the down position and cubes should work.  If solenoid is not working then it will need to be replaced.  Let me know what you find.
Posted on Oct 14, 2007
fridgetech
  • 473 Answers
SOURCE: Ice maker not making ice
Chances are it will be best to replace the ice maker but give me your complete model # from the sticker inside the fridge.  Also, make sure the fill tube to the ice maker isn't frozen up.  There should be a 3 digit # in front of the 52554100.
Posted on Oct 18, 2007
flashig F 0-1%
Posted on Aug 22, 2008
  • 57 Answers
SOURCE: strange taste in ice cubes
Did you use new water lines? If you did then clear the icecubes from the tray and use an appliance store cleaning solution to wash it out with. their solution is designed for fridge use and wont leave an after taste......Rinse well...... Also for awsome Ice......Install a large in-line water filter.... Makes mine taste like frozen mountain spring water with no nasty taste or smell. Hope it works for ya!
Posted on Jan 04, 2009
  • 3 Answers
SOURCE: ice dispensor only dispensing crushed ice - not cubed
The spring coming off the rod will also cause this problem, also the bypass flap may be stuck open, always check the simple things first, hope this helps.
Posted on Apr 16, 2009
Whirlpool model # ed5vhexvq1 side by side ...ice maker will not dispense ice..water works but it sounds as if there is no power going to icemaker from dispenser
Does the icemaker bucket has ice cubes. If yes then your problem is in the dispensor. If no ice cubes on the icemaker bucket then your problem is with the ice maker unit.
Let say Ice cubes on the ice maker bucket and dispensor makes noise when pressing for ice cubes. Then either your ice dispensor flapper is frozen or may be ice cubes in bucket may have defrost and frozen again sticking together.
Oct 01, 2014 | Whirlpool Refrigerators
Our GE Profile Arctica will not make ice cubes.
You have 2 problems .
1 . the water valve is not letting enough water in . Pt # WR57X10032 . This is located on the back of the refrig , where the wall water line connects to , on the refrig .
2 . The dispensor flap door , is not closing completely , to seal off the warm outside air , thereby , causing frost on the inside dispensor area , and , on the bottom of the ice dispensor bucket . The usual cause , is the door flap solenoid , pt # WR62X10055 . The plunger , which comes with the solenoid , usually rusts , causing the flap not to close completely .
Dec 15, 2009 | GE Profile PSW26P Stainless Steel Side by...
Frost inside the ice dispenser chute and the ice cube dispenser seems "stuck" on crush mode instead of dispensing full cubes.
The stuck on crush mode , is caused by ice frosted in front of the ice bin , blocking the ice bin flap from opening , when calling for cube ice . Removing the ice bin and cleaning or defrosting completely , will solve this problem , AFTER , resolving the frost in shoot problem .
Remove the top freezer door hinge cover , and disconnect the plug there . This removes any power , going to the door . If no plug there , remove the bottom kick plate , by removing the screw on each side in the front , and disconnect the receptical from the wires comming from the bottom of the freezer door .
Remove the dispensor control board , by prying , or pulling , from the bottom of the board . Disconnect the 3 plugs to the board . You should now see the white dispensor cover , being held on by 4 screws . Remove these screws , and slide the cover out .
In the top right , inside the dispensor area , you will see a solenoid with a plunger , with the door flap arc , inserted into the plunger . Usually rust inhibits the movement of the plunger , keeping the door flap from closing completely .
Remove the 3 screws holding the plunger and solenoid ( part number WR62X10055 ) and replace . Cleaning will not help , due to rust will return .
Oct 10, 2009 | GE Refrigerators
GE refrig/freezer dispenser makes ice, but no dispensing of water
The dispensor water line , is probably trying to freeze , inside the door . raise the freezer control slightly warmer , to keep this from happening . May take 2 or 3 raisings to find the proper temp . Also , you can order a dispensor heat kit , pt # WR49X10173 , which comes with installation instructions .
Oct 05, 2009 | GE Refrigerators
Ice maKer is not getting water but the water side works.
Your refrig water valve , has 2 coils on one valve . One is for the water dispensor , and one is for the ice maker . So even if you get water thru the dispensor , the other coil ( for the ice maker ) could be bad . The fill tube from inside the freezer to the ice maker , could be frozen solid , keeping the water from entering the ice maker . This frozen tube , would be caused be the water valve " seeping " , which means , it isn't closing completely , and drips freezing inside the tube . indicating a bad water valve . Pour about 2/3 cup of water into the ice maker . If it dumps , but doesn't refill with water , replace the water valve but also check this tube . If the ice maker does not dump the frozen cubes , replace the ice maker , but also check the coils under the refrig , for dust , lint , etc , needing to be cleaned off . The ice maker needs to be 5 degrees to operate , and dirty coils can keep the freezer at 6 degrees or above .
Sep 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Doors got to hot
Check the warrenty on fridge . Usually you have a 5 year warrenty on the compressor AND sealed system ( parts and labor ) . However , a service call charge may apply . Also check to see if something got sucked into the compressor cooling fan blade causing the noise , after you cleaned the coils .
From the description about dispensor leaking and ice getting stuck , sounds like the water valve needs to be replaced . Small ice cubes ( from not enough water ) will get caught between the rake and fingers . A leaking water dispensor , usually indicates that the water solenoid is not closing completely when letting off the water dispensor arm . Both solenoids come togather as the water valve ( located where the wall waterline connects to refrig ) .
Aug 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE GSH25KGMD Crushed Ice Only
Remove the ice bin . Set the dispensor for cube and push in the door switch . Press the dispensor pad and you should hear a loud bang . If your looking inside at the same time , you should see a square white "gate" lift . This gate lifts to lift the rod on the ice bucket to give cubed ice . If this gate does not lift , then the auger solenoid is probably bad . Part # WR62X58
http://www.apdepot.com/Buy/IPLFrame.asp?Brand=GE&ModelNo=GSH25KGMDWW&IMGFile=LD1IEWSN&IMGID=uZmA
Aug 14, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice dispensor only dispensing crushed ice - not cubed
Make sure that your ice tray is properly instaled. There is a rod that must go into a hole. When you select ice cubes rather than crushed ice a solenoid raises which moves that rod. It then opens a flap so the cubes can bypass the crusher. Either your rod is not in the hole correctly or the solenoid has gone bad. The rod that I am speaking of runs along the underside of the ice tray. It has a spring on the rear end that holds the bypass flpa closed.
Dec 02, 2008 | GE GSH22JFT Side by Side Refrigerator
Ice dispensor is stuck on crushed ice, and will not go back to cubed ice.
Pull out the ice bucket and remove every piece of ice.Place the whole pieces back in and re try.If it still is not making cubes come through than you have a blade jam. Please rate this !
Sep 08, 2008 | Frigidaire FRS23H7C Side by Side...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
