Question about Zebra LP 2844 Thermal Printer
LP2843 printer This printer, LP2843 and LP2844 seems to have alot of problems with the top not being sensed as being closed and not picking up that it is closed. If you press on the top, then you get a green light and the printer works. I do not see a switch for the lid. Is there a door/lid switch or is this sensed by a sensor? What can be the problem? Thanks
Throw it away
Posted on Nov 07, 2007
When I try to print, I get the error: Top Cover Open: The printer cannot print because the top cover is open. How do I fix this?
Hi cduckyquack ,
  • All you need to do is close the printer cover if it's open , once it's closed you should be able to print correctly without any warning messages.
  • If the cover is closed and still you are getting the same message , then it might be a problem with the censor switch which indicates to the printer whether or not the cover is open, so if the switch / sense has gone faulty then you need to repair it.
  • Sometimes just because of dust the printer does not sense the cover being closed and it results in the error message that you have described.
  • Hope this helps ...) your feedback would be appreciated.
Jun 02, 2011 | HP DesignJet 1050c plus InkJet Printer
I want to print 2X4 labels without skipping 2 labels each time
obviously its your vb software. try using a real label program and end this issue.
Sep 05, 2017 | Zebra LP 2844 Thermal Printer
We are in need of thermal printers and Zebra LP
The LP2844 can only print on Direct Thermal labels.
DT labels have the ink within the label and the labels react to heat. If these labels are to be exposed to direct sunlight they will eventually turn black.
Hint:
If you scrape the label with fingernail you can usually see the black ink on label
The physical size of the labels is this max width 1 inch (MInimum) to 4 inches (Max). Maximum length of label depends on the amount of memory in printer but maximum size for standard LP2844 is 11 inches. With full memory can be 22 inches long.
The labels must be on a 1 inch core.
These printer can handle all label types.
1: die cut Labels - Use gap sensing.*
2: Labels with Black mark on back - Use Black mark*
3: Continuous roll - select continuous *
* Select in printer driver media setting
Use the latest ZDesigner Driver V1.5.10
Download from Zebra Website.
Printer Preferences - Advanced Setup - Media Type.
Dec 02, 2009 | Zebra Eltron TLP 2844 Thermal Label...
Zebra lp2844 printing incorrectly with paypal multi order
Same here... Can't be the printer - has to be something with either the paypal software or the driver since my 'SAMPLE' prints solid as well. Did you ever find a solution?
Oct 15, 2009 | Zebra LP 2844 Thermal Printer
Zebra LP2844 cannot print LABEL
Please be aware that zebra Lp2844Z is different with LP2844.
LP2844 - Eltron
LP2844Z - zebra
please make sure the programming language is correct
Aug 23, 2009 | Office Equipment & Supplies
I need the driver for Zebra LP 2844 for MAC OS X.
OS X 10.5.2 and above have built-in ZPL and EPL drivers. Plug the printer in to USB, go to System Preferences > Print & Fax, click + , and choose the Zebra driver. For the LP2844 you choose the EPL2 driver.
Apr 09, 2009 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 printer will not print anything but the test page
possibly not a real LP2844 but an LP2543, a printer mass produced for and used by UPS. refurbishers change the label and sell as LP2844 because they are almost identical.
if it has an AC-AC adapter, it is an LP2543. LP2844 uses a AC-DC adapter, and all LP2844's have USB ports.
Mar 24, 2009 | Zebra LP 2844 Thermal Printer
Zebra LP2844 Thermal Printer won't print from a browser
I posted this problem last week and since that time discovered the problem (at least for me). I had to replace the HD and failed to update a current version of Java. Without Java in place I could call for it to print but the print job would disappear into thin air. After installing a current version of Java the machine began printing again and has worked perfectly.
Jan 14, 2009 | Office Equipment & Supplies
Flashing red light
Hi Quadralady,
I found these possibilities listed in the manual:
1. Perform media length sensing.
2. Possible problem with label stock. Use only approved
labels and tags.
3. Possible label jam.
4. Insufficient memory for label size. Check the printer
memory configuration.
5. Possible software problem. Refer to the programming
manual.
Apr 16, 2008 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 Thermal Printer Logo
212 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Gateway information...
Marvin
Marvin
Computer Links
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
