Question about Lexmark Interpret S405 - multifunction fax / copier / printer / scanner color
Unable to print or make copies even after replacing ink
    Sergeant:
  • 317 Answers
Not enough info. What, when, etc., etc., etc. OEM or refill cartridges? What was error msg before replacement. What is msg now? Did you clean contacts?
Posted on Oct 21, 2013
I have a MFC-79CW running out of yellow colour, now it seems unable to copy paper by pressing 'BLACK' buttom. Do I have to replace new colour boxes just to use B/W ? Thank You
Yes, you have. Inkjet printers use color ink in cleaning cycles, so your color cartridge will be eventually empty even if you only print in B/W.
If you need to print/copy a lot of B/W documents, I would recommend a laser printer, or an inkjet printer with individual color cartridges (printers from Epson, Officejet from HP, etc). You'll save some money by using those.
Mar 02, 2011 | Brother Office Equipment & Supplies
I am unable to copy, i keep getting the message "Unable to print 36"
The error message is an indication that the machines ink absorbers are almost full. The ink absorbers hold liquid and dried ink after it has been purged from the print head. These absorbers can control enough ink for the expected life of the machine.
Dec 15, 2010 | Brother MFC 490cw Color Inkjet...
My mfc240c says to replace the yellow ink cartridge but I don't want to spend money on that if the 'light bulb' is ruined. When I turn on the machine, I don't see any light for scanning or copying. ...
By the "light bulb," do you mean the scanner lamp? That lamp should only turn on when you are actually scanning, faxing, or copying a document. You should be able to still use the machine to scan and fax, even with the yellow ink empty. Try scanning a document to see if the scanner lamp comes on.
As far as printing or copying goes, you won't be able to print or copy anything until you replace the yellow ink, even if you try printing in black and white only.
Apr 19, 2010 | Brother Multi-Function Center MFC-240C...
I don't know how to change the ink cartridge of epson tx 110
http://files.support.epson.com/htmldocs/nx110_/nx110_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Replace Ink Cartridges
Your Epson Stylus NX110 Series and its software will let you know when an ink cartridge is low or expended.
If ink is low, the ink light flashes. You can continue printing until a cartridge needs replacement.
If a cartridge is expended, the ink light stays on. You must replace the cartridge to be able to print.
SEE IMAGE BELOW
Warning:
Keep ink cartridges out of the reach of children and do not drink the ink.
Note:
If you need to change a cartridge before it or any other cartridges are low or expended, run the Ink Cartridge Replacement utility.
You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expended. Replace any expended cartridges before printing or copying.
Leave your old cartridges in the Epson Stylus NX110 Series until you are ready to
replace them to prevent the print head nozzles from drying out.
When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head.
Follow the instructions in these sections to check and replace your ink cartridges:
Mar 21, 2010 | Epson Office Equipment & Supplies
Says:ink system failed,unable to copy,fax,print error code Oxc18a0106
It means you are out of ink and on newer printers, it can be only one color that will cause ink failure.Check your ink levels and replace the color that is empty.
Oct 26, 2009 | HP Photosmart C6180 All-In-One InkJet...
Ink system has failed. Unable to copy, receive
normally in this scenario the whole printer needs to be replaced..
Oct 22, 2009 | HP Photosmart 3310 Printer
Wont print with all new ink cartridges
If the error message is only "magenta/cyan low", it doesn't cause any error. The low message stays after replacing ink cartridges if they're replaced too early (before they're indicated as actually empty), it doesn't cause the printer to not work.
However, some other problem might be faulty, or there might be another error message. Try emptying printer queue and print from Ink Management -> Menu/set (twice) to check wether the problem is with communication from pc or if the printer actually is unable to print.
May 29, 2009 | Brother MFC 210C All-In-One InkJet Printer
HP Photosmart C7280 Ink System Failure
Contact HP for Care at 1-800-585-2494 Toll Free
Oct 08, 2008 | HP Photosmart C6180 All-In-One InkJet...
Lexmark Interpret S405 - multifunction  fax / copier / printer / scanner   color Logo
24 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
