Question about Ovens
Belling 860 WH - how to get access to the fan for replacement. Rear panel has a circular panel with holes in the fan area but this seems to be part of the main back panel - do you have to cut this out?
5 Suggested Answers
Tomwillfixit
  • 5 Answers
SOURCE: belling no heat in main oven
You need a new element buy on line much cheaper,
Posted on Oct 04, 2008
barkencoa
  • 3463 Answers
SOURCE: Belling 592SS self clean panels need replacing
Go to:
www.belling.co uk and follow the links
You should find what you are looking for
Posted on Dec 08, 2008
  • 193 Answers
SOURCE: Belling Electric Cooker - Main oven keeps tripping electrics
yes use an ohm meter to test it
Posted on Apr 29, 2010
barkencoa
  • 3463 Answers
SOURCE: indesit FID 20 WH fan
The fan nneds replacing, as it has a tight or worn bearing/s, the fact that you turn it manually and it then goes, temporarily frees it enough to get it running, but the the only guarantted solution is to replace the fan motor.
Posted on Feb 17, 2011
Tip
Common faults Belling XOU252
For all Free appliance repair videos visit our VIDEO TUTORIALS
1, If the Belling fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the BELLING element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your BELLING fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your BELLING oven thermostat
4, A quite common and easily overlooked answer is if your BELLING oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 17, 2010 | Belling XOU252 Electric Single Oven
Tip
Common faults on belling cookers
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Belling fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
on Jan 17, 2010 | Belling XOU592 / XOU593 Electric Double...
How do i strip the element out of my belling fan oven
The element is located at the rear of the oven compartment behind a removeable cover.
If there is no provision for undoing the screws from inside the oven, then you will have to remove the outer rear panel of oven and possibly the top cover also to gain access to the element screws.
Hope this helps.
Feb 08, 2010 | Belling Ovens
How do I change the oven element on a belling format 800 oven
1, If your Belling fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.To gain access to the BELLING element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
Jan 03, 2010 | Belling XOU492 Electric Double Oven
We have a belling format oven - when we turn the top oven on it is making a sound like a helicopter
The noise is probably cominbg from the externally mounted cooling fan. to access it, you will have to remove the side panel and rear cover, and top cover if it is bullt in.
If it is free standing, you should be able to get to it by removing the top cover/hob.
Hope this helps.
Dec 07, 2009 | Belling XOU492 Electric Double Oven
I have a creda belling fan oven, the main fan oven is not getting hot, please could you give me any information on a remedy
Hi the most likely cause is the element. Remove the panel at the back of the oven (inside) you may have to remove the bulb lens cover as well. You will see the circular element. The fan will be in the centre. Remove the fixing screw and remove old element. MAKE SURE THE POWER IS OFF BEFORE DOING THIS!!! Check element with test meter or in some cases it is obvious that the element is faulty as it will be in bits! replace all screws and test
Oct 21, 2009 | Ovens
Fan stopped working
If it is heating without the fan working, then there is probably something wrong with the fan.
If there is no heat as well as the fan not working, then check that the timer is set to manual and not on auto.
To access the fan and heater, remove the rear panel inside the oven, spin the fan by hand,it should be completely free,
If it is not, then it needs replacing.
Plz rate my solution.
Thanks
Jan 02, 2009 | Belling XOU252 Electric Single Oven
Replace Bottom Element in Belling XOU270
If this is a fan assisted oven, then there is no bottom element, only the fan element..
Remove the panel at the rear of the oven, there you will see the element, remove any screws that you can see and pull element towards you, disconnect the leads, don't loose them, and replace element.
If no screwws are visible then you will have to remove the oven from housing and do it all from the rear of the oven. Make sure power is off before you do anything.
Good luck.
Thanks.
Dec 15, 2008 | Belling XOU270 / XOU271 Electric Single...
Replacing timer unit
if like other belling, take side panels off. take off screws holding hobtop and move it backwards. clock should be then accessible
Mar 29, 2007 | Belling XOU492 Electric Double Oven
Ovens Logo
24 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
