Question about Toshiba e-studio 455 Copier
Error code E030
The copier is stating there is a misfeed/paper jam where the paper comes out for the fax. There is no paper jammed in there, and I have been unable to clear the error from the screen in anyway.
checkitright
  • 1362 Answers
SOURCE: misfeed in finisher
finisher is the unit attached to the copier on the left.
open door and look for any green handle, these are what you need to move to locate the jams
Posted on Oct 20, 2008
  • 87 Answers
just check propely any small piece of paper is in machine or any sensor in paper path is disturbed check all sensors and there levers .or take a hard file cover and from bypass with ur hand pull it in copier and send him to toward exit tray .just off copier first and do this .
Posted on Dec 16, 2008
SOURCE: My copier continues to misfeed even though I have cleared the jam
there are little plastic fingers on the drum and heating rollers (hot), one of those is raised up from the surfaces of either component, causing your paper to catch. both move back and forth on tiny springs. on the fuser you can actually remove several of these fingers if they are the problem and still use. on the drum they must be repositioned or replaced
Posted on Aug 05, 2009
SOURCE: e350 misfeed on print/copy 2nd page
misfeed in copier
Posted on Dec 22, 2010
  • 132 Answers
SOURCE: Toshiba 2060 gives Misfeed error. The copier is
sounds like the paper feed rollers are worn or dirty try cleaning the rollers if the problem persists then unfortunately you will have to replace the rollers
Posted on Apr 06, 2011
Toshiba e 255 is error code E 030
E030 indicates jam on exit...It is intermittent jam or totally jam?
U need to check the paper transport from feeder to registration then up to fuser unit, lastly exit unit...
Sep 01, 2015 | Toshiba Office Equipment & Supplies
Error code e030
Code E030 Description Power-ON jam: The paper is remaining on the paper transport path when power is turned ON.
Aug 09, 2015 | Toshiba E-Studio 255 Digital Copier...
Toshiba estudio 455 Error Code E030
E030 indicates jam error on exit...U need to see where the paper stop and why...
Jul 28, 2015 | Toshiba Office Equipment & Supplies
Xerox WorkCentre 7120 error code
Chain Description 001 Cover and Door Interlocks 002 Touch Screen / Control Panel 003, 041, 045, 123 Machine Communications 004 Drives 005 Duplex Automatic Document Feeder (DADF) 061, 062 Scanner, DADF and ROS 007 Paper Supply 008 Paper Feed 009, 089 Xerographics 010, 011 Fuser, Copy Exit 012, 013, 047, 112 Finisher 016, 124, 127 Configuration, Software, Memory, Hard Drives, Color Server, DFE 018 Network Communications 020 Fax, Software 021, 121 Foreign Interface 022 Job Timers 024, 026, 027, 033 Job Parameters 034, 035, 036, 133, 134 Fax Communication 042 Motor, Fan, Sensor 071 Tray 1 Misfeed 072 Tray 2 Misfeed 073 Tray 3 Misfeed 074 Tray 4 Misfeed 075 Tray 5 Misfeed (Bypass Tray) 077 Paper Path Jam 078 High Capacity Feeder 083, 084 Fax Jobs 091 Drum Cartridge 092, 093 ATC, ADC, Toner 094 IBT, BTR 102 Job Queue 103, 116 Software
Aug 23, 2014 | Xerox Office Equipment & Supplies
Paper misfeed error code E030
Apr 09, 2014 | Toshiba E Studio 2330C
I have a Panasonic Workio DP3030 showing error code J93 paper misfeed in ADF. I have followed the manual and there is no paper jammed but I can't get rid of the error message.
Generally a paper misfeed is not a paper jam. The rubber pickyp rollers probably need a clean but turning the printer off for 10 minutes and turning back on should eliminate the message.
Nov 03, 2013 | Panasonic Workio DP-3030 Printer
Toshiba esstudio 500 misfeed to copier error what to do?
Sounds like a paper is jammed in the copier. Pull out the tray and make sure all paper is removed the reinsert the tray.
Jul 30, 2012 | Toshiba E-STUDIO 550 Copier
Toshiba 3511 e030
[E030] Power-ON paper jam(power is turned on while there is still paper jammed inside)
Open the cover of the unit/area whose picture is flashing on the control panel.
Is there any paper on the transport path?
YES - Remove the paper.
NO - Is the sensor in the jamming area working?
NO -1) Check if the connector of the sensor is disconnected.
2) Check if any of the connectors on the LGC board is disconnected.
3) Check if the connector pins are disconnected or the harnesses are open circuited.
4) Check if the conductor pattern on the LGC board is short circuited or open circuited.
5) Replace the sensor.
6) Replace the LGC board.
J
May 19, 2012 | Toshiba Office Equipment & Supplies
I have a GESTETNER DSM645SP copier,fax,scanner,and printer....Everytime I try to print or copy the copier jams..."PAPER MISFEED (J016)". I clear the paper way and try again and it still jams. Help
If it is not a "real" paper jam, just an error message, you most probably would need the right driver for your device to get this work properly. If google is of no help, just send the model numbers of device and operating system to http://manualfox.com/driver.htm and they will come back with a solution.
Aug 24, 2009 | Office Equipment & Supplies
Paper jam
I would like to inform you that this might cause due to dirty paper rollers hence Please click here and follow the instructions to resolve this isse.
May 23, 2009 | HP PSC 1315 All-In-One InkJet Printer
Toshiba e-studio 455 Copier Logo
77 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Branko Djurdjevic
Branko Djurdjevic
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
