Question about Garden
Troy bilt push mower
Try to manually raise front wheels with lever,and this doen't hold during operation of mower? Mower is brand new!
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
If mower is brand new, take it back
Posted on Oct 22, 2013
  • 279 Answers
SOURCE: Troy-Bilt Mower is running real slow.
If you can, check the flywheel key. If it is bent but not quite broken, it can cause slow operation. To do that, take the starter off the top of mower. Take off the big nut on the flywheel. Find a nut of the same size and place on the thread you took the nut off, but only a few turns. Hold the flywheel with one hand, lifting a little, and tap the nut with a hammer with the other hand. The flywheel should come off. Look at the key, it holds the flywheel to the shaft. If it is bent or broken, that is the problem. Replace it and go about your day! Good luck...Lee
Posted on Sep 25, 2009
radar001
  • 1051 Answers
SOURCE: front wheels lock up when pull mower backwards
Typically self-propelled mowers are propelled using the front wheels, which only turn forward. Pulling the mower back while the front wheels are turning will damage the drive gears. It's best to raise the front wheels slightly off the ground before pulling back.
Posted on Mar 24, 2010
heres2maine
  • 84 Answers
SOURCE: How do you remove the gears on a front wheel self
Take the front tires off, pull gears and take out pins, put tires back on and you have a "non-self propell" mower.
Posted on Apr 15, 2010
RonInFla
  • 86 Answers
SOURCE: Troy Bilt lawn mower used months 2009 will not
stale gas in carburator...take the screw out of the bottom of the carb and let the gas run out...
Posted on Apr 18, 2010
  • 152 Answers
SOURCE: troy bilt mower 6.75 hp smoking too much oil...
Check oil level, it could be just excess oil. Also check air filter, it may need cleaning/replacing. Depending on how old the nower is, it could be broken rings in the engine, in that case... time for a new mower. hope this helps!
Posted on May 25, 2010
Have a brand new Troy bilt push mower,when raise the front wheels it moves down to the bottom and won't stay on the proper adjestment.
do you mean, when you raise the front of the mower the front adjustment brackets let the wheels fall to the lowest setting ??? try bending them where they're supposed to snap into the adjuster bracket.
Oct 21, 2013 | Garden
Troy-Bilt Horse XP, Model 13bx79kt011 - Won't Move
You need to check the belt to the hydro units is connected properly and is tentioned and not slipping in the pilleys
May 31, 2013 | Garden
Brand new Troy-Bilt XP Horse, model 13bx79kt011 - Won't Move
Confirm the park brake is off. If a hydro-static drive tractor starts but engagement of the operator controls for the transmission drive results in neither a forward or reverse drive of the mower itself, the operator should check that the manual bypass controls have not been left in the activated (bypass) position.
Look in to where the lever connects and confirm the movement. You should be able to hear the hydraulic oil with a slight whine as you activate the drive forward pedal!
See page 18 for bypass setting?
Cut and paste link
http://www.troybilt.com/wcsstore/TroyBiltUS-CAS/Attachment/ownersManuals/riders/HorseXP_2012_769-07569[1].pdf
Jun 27, 2017 | Garden
Can't push troy bilt lawn tractor when it is in neutral
It sounds like the tractor is hydro, if so you need to find the release lever to allow it to move in neutral.
Most hydros have the lever under the seat or at the back of the tractor just behind the back wheels.
if and when you find it, it will need to be slid across and locked in to the operset position or pulled out, depending on what type it is.
Hope this helps
Regards
Micky
Jun 14, 2012 | Troy Bilt 175HP Manual 42" Riding Mower
I bought a brand new Troy-bilt lawn mower model 336077 and tried to start it by pulling on the started string after filling gas and oil. But the cord is stuck and the mower does not start. WHat coul be the...
Are you holding the emergency stop lever? If you were operating the mower with your hands on the handle, there is a separate lever that you are expected to hold together with the main handle. You have to hold these two handles together to start and to operate the mower. Good luck.
May 31, 2011 | Troy Bilt 5.5hp Self Propelled Mower
Variable speed doesn't work troy bilt self propelled lawnmower
Cable could be stretched belt could be worn or old, if it has a gear box maybe it slipped a gear or lost some teeth. Do some investigation, Good Luck
Jul 26, 2010 | Troy Bilt 5.5hp Self Propelled Mower
How do you remove the gears on a front wheel self propelled troy bilt push mower?
Apr 13, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Front wheels lock up when pull mower backwards
Mar 24, 2010 | Troy Bilt 5.5hp Self Propelled Mower
I have a troy bilt front wheel drive mower, model
ya the trans is trying to go out and thay look up thay do that all the time
Nov 02, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
43 people viewed this question
Top Garden Experts
Jay Finke
Jay Finke
Dennis Key
Dennis Key
john h
