Question about Exercise & Fitness
I have a 10 yr+ PaceMaster ProSelect Treadmill it works fine other than being stuck at its highest elevation. Is there a solution to bringing it back down to normal elevation. I was given a short excerpt from the manual by the manufacturer to reset the computer but it didn't work. THanks
    New Friend:
  • 6 Answers
What about the incline number at your display ? is 0 or at higher level? at this incline your treadmill is work or stop after 10 sec?
Posted on Oct 21, 2013
SOURCE:
SOURCE: richelle07
was able to locate error codes from manufacturer.
Posted on Sep 10, 2009
  • 1796 Answers
SOURCE: Where is the elevation fuse on a Pacemaster Gold
Hi!!
On page 6 of your owner's manual, step 3 shows a diagram to remove the shipping bolts. On that diagram, you can see the motor and the power cord wrapped around it.
Click on the following link to get a copy of your owner's manual on .pdf format, scroll to page six and magnify it to 400%, you should be able to see the blue circuit board and two white fuses. Make sure your Pacemaster is disconnected before working on the fuses.
http://www.pacemaster.com/manualPDF/PremiereGoldEliteFoldup.pdf
A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Posted on Nov 06, 2010
2manyhobbies
  • 135 Answers
SOURCE: Hello, WE have the model 4100i
Try the calibration procedure found in the troubleshooting section of your manual first. Here are the basic instructions.
With the key in the console, press one of the Incline buttons. While the incline is changing (or the numbers on the console) , remove the key. After a few seconds, re-insert the key. The treadmill will automatically rise to the maximum incline level and then return to the minimum level. This will recalibrate the incline.
If it still doesn't move, remove the cover. Find the incline motor. You will see a slot in the end of the motor. Using a drill with a standard slotted screwdriver bit, spin the motor counterclockwise (if it is having difficulties spinning, turn clockwise instead) for just a couple seconds. Now do the calibration procedure again.
I have had machines that got stuck before. Once released and recalibrated, the operation was OK.
The service number for your machine is found on the model number sticker on the frame of the treadmill.
Posted on Feb 26, 2011
ercupa190
  • 12223 Answers
SOURCE: pacemaster treadmill no power
http://www.youtube.com/watch?v=N6Yg5S0WML8
see the step for torubleshooting your problem.
Of course test the breaker or fuse from your house. See if the wire ground is connected to your outlet supply. Do not use any extension cord.Use regulator voltage recommended.
If necesary call some electrician .
sincerely.
Posted on Dec 22, 2011
ercupa190
  • 12223 Answers
SOURCE: ifit treadmill stuck on highest incline
RUN inmedaitely the software calibration for diagnose, troubleshooting and fix it. Now that machine is running in slow speed.
sincerly. God bless you
Posted on May 06, 2012
How to adjust tension belt on pacemaster proselect treadmill
Tread Belt Tension Adjustment - Aerobics ProSelect ...
www.manualslib.com > ... > Treadmill > ProSelect > Owner's manual
Aerobics ProSelect Manual Online: Tread Belt Tension Adjustment. Step One:Locate ... Treadmill Aerobics PaceMaster Gold Elite Owner's Manual. Treadmill (38 ...
Aug 26, 2015 | Exercise & Fitness
I have a Pacemaster Gold treadmill that will not hold elevation. I have no error codes. It will go to the proper elevation and then immediately start descending. If I change the elevation setting it will...
Run the utility software calibration for easy diagnostic, and fix it.
Go to HOOD open the cover motor and follow the steps indicated. or your owner manual.
God bless you
Sep 30, 2013 | PaceMaster Gold Elite Treadmill Upper...
Pacemaster treadmill err 133
I just fixed the same 133 error, it's about the communication between motor module and upper panel. There is an 8 wires cable, uses standard RJ45 connectors. In my case, one of the RJ45 connector to motor module is poorly done by the manufacture, so the connection is not reliable, I re-do the connector, problem fixed.
Apr 15, 2013 | Treadmill Doctor Pacemaster Platinum...
Pacemaster treadmill will not start, no lights, nothing.
Is there a spot on the control board you can check for out going power? You might have a bad board. You can visually inspect your board for anything that looks burnt or one component that looks swolen or loose. Poor solder joints are a common problem with treadmills because of the constsant movement.
Feb 18, 2013 | PaceMaster Aerobics Pro Plus Walking Belt
My treadmill no longer asks me for my weight, and I'd like to reset it.
go to reset. Turn off the power and reset the button too. Try again.
After that RUN the software calibration for easy diagnose, troubleshooting and fix it.
Happy New Year. God bless you
Jan 01, 2013 | PaceMaster ProSelect Treadmill Incline...
Treadmill no longer asks me for my weight, and I want to reset it.
try to turn off the machine. and reset the button and try again.
Happy New year. God bless you
I have a T85 Treadmill and the running platform is stuck in the highest position. A message on the display says 'check Transmitter'. Is there anything I can do to fix it?
PLeae RUN the software calibration for troubleshooting go under the HOOD motor and read the instruction steps, or go to instr. manual in how to enter in the s.calibration and fix it.
However you can measure the input voltage elevation motor, and lube the shafte, gear, see the photo and diagram attached.
God bless you
Nov 18, 2012 | Tunturi T85 Treadmill
Proselect pace master treadmill incline does not work
Dear Sir:
1) You must test the Main motor board, RUN the software calibration for easy diagnose and troubleshooting.
2) The elevation motor has a Potentiomente adjust. 3) The gear from elevation motor can be LUBE. However RUN the s. calibration.
3) Another machine has relais for down and up, you must clean the relais contact, if the board has relais.
sincerely. God bless you
Apr 23, 2012 | Exercise & Fitness
My cardiozone supersport HR club II started elevating by itself to highest level then stopped running but stay elevated. Could not get it to return to lowest level, just stuck there. I got an E7 code on...
Sounds like the motor control board went wacko.....ran the incline motor all the way up and shut down the treadmill motor for no reason....sounds like a control board problem...
heatman101
Dec 15, 2010 | Sport & Outdoor - Others
Exercise & Fitness Logo
280 people viewed this question
Top Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Tom Chichester
ray gallant
ray gallant
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
