Question about Utica JD-1200-W Cast Iron Hot Water or Steam Boiler JD
Cant' get utica intermittent gas boiler to work
  • Charles Patterson Oct 21, 2013
    Following the directions but it doesn't fire up. I put thermostat on lowest temp, put gas on and power on then set the thermostat. I get a very low buzzing sound from the power and lights on the auto water cutoff. That's it.
Eurosteam iron no power
try it in another power point , otherwise have it repaired at a service center . not suitable for home repair.
Nov 13, 2014 | EuroSteam Steam Iron w/Boiler Tank & Lint...
Why doesn't carpet cleaner dispense water and soap?
Get a needle and clean all the nozzles, since they work with hot water they tend to get clogged with a white built up.
Aug 27, 2014 | Royal RY7910 Procision Deluxe Upright...
My steamer is no longer producing steam, how do I fix?
To troubleshoot something like this.
1. make sure it's plugged and the outlet is working.
2. Is it getting hot? If not, either the heating element is burned out or not getting power.
3. If it is getting hot check the steam ports for calcium build up (run straight vinegar through it)
Jul 14, 2014 | Garment Steamers & Presses
Why are there hard deposits in the boiler of my eurosteam iron?
Tap water contains minerals/chemicals, whether it's from a well, or from a city source. When water is heated to steaming, these minerals, precipitate out of the water and form deposits. Use some vinegar. The mild acid will help loosen the deposits... and from now on use distilled water.
Jun 10, 2014 | EuroSteam Steam Iron w/Boiler Tank & Lint...
My boiler keeps making a ringing sound. Like a small bell on a bike. What could be causing this noise
Note sure if its the same thing but my boiler (halstead Best 50) made a ringing sound just like you describe. It was the flue fan blades just catching the metal surround of the flue vent on occasions. It only happened when the boiler had been running a while. A new fan was fitted and everything ok now.
Oct 28, 2013 | EuroSteam Steam Iron w/Boiler Tank & Lint...
Euro steam iron
Seems silly... but is it plugged in to a live outlet? Does it have water?
Sep 30, 2013 | EuroSteam Steam Iron w/Boiler Tank & Lint...
Utica JD-1200-W Cast Iron Hot Water or Steam Boiler JD Logo
51 people viewed this question
Top Utica Garment Steamers & Presses Experts
Tom Chichester
Bill Boyd
ray gallant
Are you an Utica Garment Steamer and Press Expert? Answer questions, earn points and help others
