Question about KitchenAid Kitchen Aid KEBS207SSS Double Wall Ovens
The doors on my Kitchen Aid KEBS208 built in Electric Convection Double Oven will not close tight. I have replaced them within the last 12 months. The ovens are seldom used. It's as if the hinges are sprung but they are too new for that.
    Director Badge:
    Uploaded 100 video answers.
  • KitchenAid Master
  • 488 Answers
HINGES WHERE PART NUMBER ENDS ON 6 - THEY TIGHTER
Posted on Apr 27, 2014
5 Suggested Answers
  • 1314 Answers
SOURCE: Kitchenaid Convection oven
F5
E0
E1
DOOR AND LATCH SWITCH DO NOT AGREE
DOOR LATCH NOT OPERATING.
PROCEDURE: Before proceeding, press OFF, OFF, START to enter
the Diagnostic mode and verify the error codes.
TO VERIFY DOOR SWITCH:
A. While in diagnostics, open the oven door. The second digit on the clock display
should toggle between “1” and “0” as the door opens and closes. When door is
closed display should show “1”, when the door is open display should show “0”.
If the second digit on the clock display did not toggle, go to step B.
If the digit did not toggle after replacing the door switch, go to step D.
If the digit did not toggle after replacing the door switch harness, go to step F.
B. Unplug oven or disconnect power.
C. Replace door switch. (If door switch is integral to the door latch motor
assembly, replace the entire door/latch motor assembly). Go to step H.
D. Unplug oven or disconnect power.
E. Check the integrity of the harness wires and connections between the
appliance manager and the door/latch assembly. Ensure there are no shorted
or pinched wires.
If the wiring harness is pinched or damaged, replace the door switch harness.
Go to step H.
If wiring harness is good, go to step H.
F. Unplug oven or disconnect power.
G. Replace appliance manager. Go to step H.
H. Replace all parts and panels before operating.
I. Plug in oven or reconnect power.
J. Press OFF, OFF, START to reenter the Diagnostic mode and complete checks.
Repeat step A.try this lighting may have knocked either the door switch or latch motor out
Posted on Mar 30, 2008
SOURCE: shattered glass window on oven door
can I install a cooker by a window
Posted on Feb 08, 2009
SOURCE: Kitchen Aid Double Convection Oven blows circuit breaker
the kehc359jss mircowave won't start, it says "door" on the display but the door is closed.
Posted on Jun 13, 2009
dmftrucker
  • 1922 Answers
SOURCE: How do I remove the built in oven to replace the
there are no internal fuses, chk your houses main power panel and stove plug to make sure you have 240 volts for proper unit operation
Posted on Nov 04, 2009
Door does not shut completely
OVEN DOOR HINGES WILL NEED REPLACEMENT IF YOU PUT ADDITIONAL WEIGHT ON THE DOOR THEY WILL SOFTEN THE SPRINGS AND THE DOOR WONT FULLY CLOSE.
May 29, 2010 | Electrolux 30" Built-In Double Electric...
We have a 30 in prostyle electric double wall oven - the oven takes forever to preheat and the doors do not seal tightly when they are closed.
Hello- Many ovens use spring-loaded hinges to carry the weight of the door. Over time, these springs weaken or the hinge gets bent just enough to not fully close door. The door gasket can also become flat and stiff, compounding problem. Any small gap releases heated air, and oven will not heat up properly. Replacing the door springs should solve problem.- Thanks -Ed
Mar 14, 2010 | Jenn-Air 30 in. Pro-Style Electric Single...
Feb 19, 2009 | KitchenAid Architect Series KEMC308KSS...
KitchenAid Built-in microwave middle glass shattered
not a problem, first you can refer to your user manual as to how to remove door, (pg 21) heres a link if you misplaced it.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%204456573.pdf
then Ill include this link as well, which is apart breakdown for your GENERAL oven, and i do this so you can see the different panes of glass( ther are 4 of them inthe oven door, each one different so ordering hte right one will be half the battle. http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208186032.pdf
the numbers after you model example, kemc308kss** (01,02,03,04) these last 2 digits will also determine which glass you actually have
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=kemc308kss&siteCd=WHRCOM
Once the door is off and you have the correct glass, changing the glass is nothing more then reomving screws from the door frame, layer by layer until you get to the broken pane, not real difficult at all
Dec 09, 2008 | KitchenAid Architect Series KEMC308KSS...
Service Manual
when you took down the control panel and gained acess to the upper cavity , there wasnt a service manual just to the left inside a red plastic bag???, if not there is another fuse loacted just behind the micro front looks to be atop the capacitor area
Mar 09, 2008 | KitchenAid Architect Series KEMC308KSS...
KitchenAid Kitchen Aid KEBS207SSS Double Wall Ovens Logo
156 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
