Question about Samsung Computers & Internet
Samsug SyncMaster S22B150 Monitor screen will not display and only button that functions is the On/Off button.
SOURCE: No display Samsung SyncMaster 710N 17" LCD Monitor
same problem here...
here is a translated version of a webpage discussing the repair for this error...
http://72.14.235.104/translate_c?hl=en&sl=es&u=http://www.dtforum.net/index.php%3Ftopic%3D55304.msg1010695085%3Btopicseen&prev=/search%3Fq%3DNT68F63LG%2B50%2Bohm%26hl%3Den%26rlz%3D1T4SUNA_enUS219US220&usg=ALkJrhiRO8V09Lo7lnjqW47LE8IE653r7w
solder a 50 ohm resistor on pins 5 & 6 of Novatek NT68F63LG chip...
good if you can DIY, best if a qualified technician do it for you..
Posted on Oct 22, 2008
SOURCE: How to rotate display when I rotate screen - SyncMaster 203B
You ought to be able to bring up the video card settings from your control panel and change it there. For instance I have a nVidia graphics card. When I bring up the settings panel it offers me the opportunity to change the rotation there.
Posted on Feb 07, 2009
stabelabel
  • 51 Answers
SOURCE: Samsung SyncMaster 730B monitor green color problem
video controller card has gone bad need new video controller card.
Posted on Mar 16, 2009
lserni
  • 466 Answers
SOURCE: MY SAMSUNG SYNCMASTER MONITOR SCREEN DOES NOT COME
The cable connecting to the PC might be loose, or the part entering the monitor could be.
Try turning the monitor on, and after a few seconds, turn on the computer. You should be able to see the BIOS POST screen text flashing by. If you can't, there is something wrong in your hardware settings.
If you can, however, that's the OS resolution set too high: the monitor shuts down to protect itself. Boot in safe mode by pressing the F8 key immediately after powering up, then lower the video resolution in Control Panel display settings to something safe - 1024 x 768 usually does the trick. At that point you can reboot in normal mode and raise the resolution again to the maximum supported by the monitor (check the manual for that).
Posted on Oct 31, 2009
Keynan
  • 977 Answers
SOURCE: Samsung SyncMaster 713BM
Hey!
Follow the instruction below to solve your problem:
Restart your computer and enter Safe Mode (press F8 right as the computer starts booting up. Choose Safe Mode in the menu, press Enter twice).
While in Safe Mode, open Control Panel and go to Add/Remove Programs (Programs and Features on Vista/7) and uninstall the display driver software/drivers.
Restart your computer and boot normally. Now you should be able to see everything. Things might look bigger and uglier, that because there's no display driver installed. All you have to do now is reinstall the display driver. Use it's original disc or go to the manufacturer website and download the latest driver.
Pelu.
Posted on Mar 27, 2010
How to change to monitor analog syncmaster s22b150?
Refer its user manual for details. If you haven't it with you now; just download it for free, from www.retrevo.com/
Nov 10, 2014 | Samsung SyncMaster S22B150N - LED monitor...
Does not turn on
Hello
With any monitor, check the following to determine if the issue is MONITOR related or COMPUTER related.
1. Verify the monitor is receiving power - use a known good power outlet and plug it into the monitor
2. Samsung monitors have a light on the power button - are you getting any color light from this? Orange means it is in "stand by" mode and is waiting for the PC to send it a signal. Green means the monitor is getting a signal from the PC and the monitor is on.
3. With the monitor on, press the buttons on the monitor to bring up the OSD (on screen display) that changes the monitor settings. If you have a green light on the power button and press one of these buttons (AUTO works best), this will display the monitor adjustment options on the screen.
If you see the on screen adjustments, your monitor is working and the issue may be with your PC. Move the monitor to another PC and verify the monitor is working correctly.
IF you don't see anything on the screen and the power light is green, the monitor has failed.
This could be the lights that illuminate the screen have failed (something that happened to my Samsung Syncmaster monitors after about 6 years of use) or the screen has stopped functioning. In either case, replacement parts are hard to find and a monitor swap is likely.
Nov 03, 2013 | Samsung SyncMaster S22B150N - LED monitor...
22 samsung syncmaster S22B150 led monitor color settings problem how to fix
I have the same monitor. It was working just fine for almost a full year and recently I started to play games on Furg Games Play Free Online Games for a few hours a day and my eyes started to hurt. I've tried to change brightness and contrast several times but still I can't stay more than an hour in front of it.
Oct 11, 2012 | Samsung Computers & Internet
Display not working but system functioning
tried with other monitor just to ensure if the problem is only with in the monitor. if the same problem, the cause it could be the inverter board for screen back light which has component being shorted.
Aug 15, 2012 | Samsung SyncMaster 713N 17" LCD Monitor
I just bought a used Samsung SyncMaster 2243BWX LCD and plugged it into my Mac Book Pro (an older model) with OSX 10.4 The screen shows a display but it is shifted from the one on my computer with the...
There will be buttons on the front of the monitor where you can change the position of the screen, you could also do this in the display driver on your macbook although I couldnt tell you exactly how on that particular mac, pretty sure the menu onthe monitor will get it sorted though.
Oct 29, 2010 | Samsung SyncMaster 203B LCD Monitor
Samsung SyncMaster 213T - DIM DISPLAY
I would follow the self-test below. If you see the same issue in the test screen then your monitor has lost it's sync and would need a board replaced.
If it dosn't appear during the test, then you might want to test it on another PC.
Self-Test Feature Check
1. Turn off both your computer and the monitor.
2. Unplug the video cable from the back of the computer.
3. Turn on the monitor.
If the monitor is functioning properly, you will see a box in the illustration below.
This box appears during normal operation if the video cable becomes disconnected or damaged.
4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the monitor.
If your monitor screen remains blank after using the previous procedure, check your video controller and computer system; your monitor is functioning properly.
I’m happy to assist further over the phone at https://www.6ya.com/expert/marnin_498840f315fe3361
Jul 22, 2009 | Samsung SyncMaster 712N 17" Flat Panel LCD...
When monitor power button is pressed, a small white image appears and alternates briefly between an alalog and digital icon in black then the screen goes blank, no color.
My issue is similar.. however after trying a couple of times it will work. (yes everything is plugged in) It will function for a good 10 minutes before just powering off (blackout) screen.
If you attempt to turn it on after it blacking out, the blue led for the power button will blink a couple of times and it will remain off.
However if you wait 5-10 minutes and turn it back on, it will repeat itself...
I have it hooked up to a radeon X1650 graphics controller as a secondary digital controller, and its hooked up by VGA cable.
I also have two other displays besides this one (one primary and extended that dont have any issues whatsoever.. they continue to function while the syncmaster 193p takes its time snoozing.... please help.
Mar 17, 2009 | Samsung SyncMaster 193P 19" LCD Monitor
Samsung SyncMaster 215tw screen goes black after about 1 sec.
I have the same problem its defenitly a problem with the lcd monitor not with the graphics card nor the pc. I hooked up the digital and afterwards the vga connection both had the same result. 1 s perfect screen all visible but than black. pushing the on/off or standby button again shortly 1s the display works than it blanks. Did the same test while connected to a dvd player via the composite video... same problem . Since the previous posts are that old and without a solution I guess there is no hope in getting it fixed.
Jan 20, 2009 | Samsung 215TW SyncMaster 21" LCD Monitor
Computer Image
the picture quality is better on smaller monitor due to higher resolution i.e the image can only be reproduced at a maximum resolution as specified by the by the manufacturer. for instance 1366x768 for the 460p
Jan 14, 2008 | Samsung SyncMaster 460P 46 in. HDTV-Ready...
Computers & Internet Logo
37 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
