Question about Swingline Shredder, Cross-Cut, Auto, 100 Sht Cap, 17"x12"x17", Black
The tray where you can place paper to shred automatically turns on when you close the tray but does not pull the paper through. Have check the tray and seems that 1 of the rubber wheels that grabs the paper pull through is starting to break down. There are little tiny rubber pieces on the paper but the paper will not get pulled through.
    Top Expert:
  • Swingline Master
  • 34,153 Answers
The paper feeder will have to be repaired.
Posted on Oct 21, 2013
The shredder doesn't automatically shred anymore. How do I set it so the "eye" works and it shreds automatically without me holding down the button?
Check the Power Ensure that the shredder top is firmly placed in the shredder basket if the unit will not operate. If the top is not in place the feeder will not work and accept any paper. Make sure it is firmly plugged into the wall outlet and that the outlet is active. Rest the Shredder Let the shredder cool down if the shredder has been running continuously for a long time. It may have overheated and needs to be left in the off position for at least 30 minutes to reset. Verify the basket is empty or not too full as that will cause the shredder to deactivate. Clear Paper Jam Rotate the shredder into "Auto" and reverse to loosen any paper jam that is stopping the gears. Pull out any papers that are sticking out from the shredder feeder. If there is no progress then unplug the shredder and remove the shredder top from the bin. Turn it upside down and use tweezers to free any paper that is blocking the gear. Auto Mode Not Working Select the "Auto" option and feed paper into the center of the feeder tray if the shredder is only working in reverse mode. The sensor is located in the middle of the feeder tray and could be blocked by jammed paper. Use an index card to firmly unblock any paper that could be blocking the sensor.
Sep 04, 2013 | Quartet gbc 5550X Shredder
Paper jam printer 3524
Clear the jammed paper as follows.
If the jammed paper is removed completely by using the information in the following steps, you can install the paper tray first, and then close the front cover and the printer will resume printing automatically.
If the printer does not start printing automatically, press the Go button. If the printer still does not start printing, please check that all the remaining jammed paper has been removed from the printer. Then try printing again.
Pull the paper tray completely out of the printer.
Pull the jammed paper up and out of the printer.
Press the cover release button and then open the front cover.
Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared, go to Step 7.
Open the jam clear cover. Pull the jammed paper out of the fuser unit.
Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
Pull the Duplex Tray completly out of the printer.
Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
Put the drum unit assembly back in the printer.
Put the paper tray in the printer.
Close the front cover.
Dec 21, 2010 | Office Equipment & Supplies
Cartrige won't move
Instructions Things You'll Need:
  • Cup of distilled water
  • Clean wash cloth
    Fixing The Printer Cartridge
  1. Shut down the HP 6480 by pressing the "On/Off" button on the right side of the control panel. Some paper jams will clear themselves just by turning the printer off and starting it again. Wait a few minutes after the printer has shut down and then turn it on again.
  2. Remove the paper feed tray. If the printer does not clear the paper jam by itself, shut off the device again. Be sure to pull the tray out gently to avoid damaging the device.
  3. Lift up the automatic document feeder. The feeder makes up the top half of printer, and it can be opened like the hood of a car. Lift the sides of it slowly. This exposes the printer mechanism and ink cartridges. Pull the jammed paper up and out of the printer mechanism with both hands. Pull it gently to ensure you don't damage any components.
  4. After removing the paper, clean off the cylindrical, silver printer roller. Dampen a clean cloth with distilled water, and gently wipe any dirt, ink or paper off the roller. Rotate it when you're done cleaning one side, and continue rotating and cleaning until the roller is clean on all sides.
  5. Close the automatic printer feeder. After removing all paper, close the top printer feeder and shake it to ensure it's fastened. Re-attach the printer tray by lining it up with the arrow markers on both sides of the printer.
  6. Put one sheet of paper into the printer tray, and reset the HP 6480 by pressing and holding the "On/Off" button for 15 seconds. The printer should automatically restart and return to factory settings. It will run diagnostics and the printer cartridges should begin moving again as they print a test sheet.
Dec 21, 2010 | HP PSC 1350 All-In-One Thermal Printer
I do not know how to remove the drum to fix a paperjam
Brother strongly recommends that customers do not use generic drum unitsand/or toner cartridges, or refill their Brother toner cartridge. Each Brother laser printer is designed to work at pre-set temperatures that are matched exactly to each of our individual toner formulations. Each individual component is designed to work with the other to ensure quality and reliability. Using non-Brother supplies may affect the Verify the message displayed on the LCD.
Warning: If you just used the machine some parts inside the machine are extremely hot.
1. Pull the paper tray completely out of the machine.
2. Pull the jammed paper out of the paper tray opening. If you are unable to remove the jammed paper continue to STEP 3. If you are able toremove the jammed paper continue to STEP 9.
3. Open the front cover. If you cannot open the front cover, do not useextra force. See below for further assistance.
4. Pull out the drum unit and toner cartridge assembly. The jammed papermay be pulled out with the toner cartridge and drum unit assembly, or removing the drum and toner assembly may release the paper so you canpull it out of the paper tray opening.
a. If you are able to remove the drum assembly and jammed paper continueto STEP 5.
b. If you cannot remove the drum unit and toner cartridge assembly easily, do not use extra force. See below for further assistance.
5. Place the drum unit on a drop cloth or large piece of disposable paper to avoid spilling and scattering the toner. Hold down the blue lock lever on the left side of the drum assembly and lift the toner out of the drum unit. Examine the drum carefully for small pieces of paper that may be jammed inside.
6. Reinsert the toner cartridge in the drum unit until it clicks into place. If you put it in properly, the lock lever will lift automatically.
7. Place the drum unit and toner cartridge back into the machine. Use equal pressure on both sides of the drum unit when pushing it back into place. Make sure it clicks into place.
8. Close the front cover. Make sure it clicks into place.
9. Remove any remaining paper in the paper tray and then reload it. The tray can hold up to 250 sheets of 20lb paper. Do not over fill the tray.There is a maximum paper mark located on the top of the right and left paper guide. It looks like a V cut out in the plastic. Fan the stack of paper well to avoid paper jams or misfeeds.
NOTE: If you are using special paper and the machine has problems feeding it from the paper tray, try the paper again using the manual feed slot
10. Put the paper tray firmly back into the machine and unfold the output paper tray support flap before using the machine.
11. Turn the Brother machine around with the back of the machine facing you.
12. Open the back cover.
13. The black plastic inner chute should spring open automatically when the back cover is opened. Note: The inner chute has a diagram on it of a piece of paper being removed from the unit.
14. If there is paper inside the machine carefully remove it.
15. Close the back cover. NOTE: The inner chute will close automaticallywhen the back door is closed.
16. To test, print the Help List:
a. Press the REPORTS key located on the right side of the control panel.
b. Press the up or down arrow key until Help list appears on the display(#2).
c. Press Menu/Set. The report should begin printing.
Thanks an good luck
Nov 27, 2010 | Brother MFC-7220 All-In-One Laser Printer
How to open drum to remove the jammed paper inside
Hi Good day!! here are the steps how to remove paper jam in brother hope it help's you!!
1. Pull the paper tray completely out of the printer.
2. Pull the jammed paper up and out of the printer.
3. Press the cover release button and then open the front cover.
4. Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
5. Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared.
6. Open the jam clear cover. Pull the jammed paper out of the fuser unit.
7. Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
8. Pull the Duplex Tray completely out of the printer.
9. Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
10. Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
11. Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
12. Put the drum unit assembly back in the printer.
13. Put the paper tray in the printer.
14. Close the front cover.
Oct 19, 2010 | Brother MFC-7440N Laser Printer
I had a paper jam and I took the back off and this
Step one: Remove any loose paper
Remove all loose paper from the input and output trays.
1. Turn off the product.
2. Unplug the power cord from the back of the product.
3. Push the button on either side of the rear-access panel or the duplexer (two-sided printing accessory) and then remove the panel or duplexer.
4. Find any jammed paper inside the product, grasp it with both hands, and then pull it out of the product, toward you.
5. If the product has a duplexer, push the latch on the top of the duplexer and lower its cover.
6. Carefully remove any jammed paper.
7. Close the cover.
8. Reinsert the rear-access panel or the duplexer into the product.
9. Plug the power cord back into the product.
10. Turn on the product.
Step three: Open the top cover and clear the jam
3. Open the carriage access door. The carriage moves to the right side of the product.
4. Gently pull the paper out of the rollers.
5. After clearing the jam, close the carriage door.
6. Plug the power cord back into the product.
7. Try printing a document.
· If the issue is resolved, do not continue troubleshooting.
· If the issue continues, proceed to the next step.
Step four: Clear the jam from paper tray 1
1. Remove all paper from the output tray.
2. Turn off the product.
3. Unplug the power cord from the back of the product.
4. Lift the output tray and then check for jammed paper in input tray 1.
Use these steps to remove any jammed paper.
a. Raise the output tray.
b. Grasp the jammed paper and pull it out of the product, toward you.
c. Lower the output tray.
5. Plug the power cord back into the product.
6. Try printing a document.
· If the issue continues, and if paper tray 2 is not installed on the product, proceed to 'Step six: Clear the jam from the automatic document feeder (ADF).'
· If the issue continues, and if paper tray 2 is installed on the product, proceed to the next step.
Step five: Clear the jam from paper tray 2
4. Lift the product off tray 2.
5. Remove the jammed paper from the bottom of the product or from tray 2.
6. Reposition the product on top of tray 2.
7. Plug the power cord back into the product.
8. Try printing a document.
3. Remove the ADF input tray and open the ADF cover.
4. Remove the jam cleanout part. With both hands, lift up on the two handles until the part unsnaps. Rotate and lift the cleanout part and then set it aside.
5. Lift the green lever attached to the pick mechanism and then rotate it back until it stays open.
6. Check the ADF paper path for jammed paper.
7. Check for jammed paper where paper enters the ADF paper cleanout.
o If the paper comes out with gentle pulling, proceed to step 9.
o If the paper does not come out with gentle pulling, follow these instructions.
1. Open the ADF, and then use both hands to gently loosen the paper.
2. When the paper is free, gently pull it out.
3. Close the ADF.
8. Lower the green lever.
Reinstall the jam cleanout part. Push down on the two tabs until the part snaps into place.
9. Replace the ADF input tray.
10. Check the following to make sure that the ADF frame and parts are secure and correctly set up.
o Make sure that the ADF frame is secure and attached correctly.
o Make sure that the ADF cleanout part attachment is secure. If it is loose, push down on the two tabs until the part snaps into place.
o Make sure that the ADF pick mechanism is secure. Lift the green lever attached to the pick mechanism and then rotate it back until it stays open.
Make sure that the two-catch is holding the roller mechanism securely in place and that the stack stopper is in the correct position.
1 - Stack stopper
2 - Two-catch
11. Plug the power cord back into the product.
12. Turn on the product.
13. Try printing a document.
Jan 01, 2010 | HP Officejet Pro L7680 All-In-One Printer
My Brother HL 5250DN printer has started making a loud clicking sound when it tries to feed paper for printing. It then stops and the paper light starts flashing.
Observe Cautions signs in printer.
Always remove all paper from the paper tray and straighten the stack when you add new paper. This helps prevent multiple sheets of paper from feeding through the printer at one time and prevents paper jams.
1. Press the cover release button and then open the front cover.
2. Slowly take out the drum unit and toner cartridge assembly. The jammed paper will be pulled out with the drum unit and toner cartridge assembly.
3. Pull the paper tray completely out of the printer.
5. Pull the jammed paper up and out of the printer.
6. Open the front cover again.
7. Open the back cover.
8. Pull the tabs at the left and right hand sides toward you to open the fuser cover (1).
9. Using both hands, gently pull the jammed paper out of the fuser unit.
10. Close the back cover.
11. Pull the duplex tray completely out of the printer.
12. Pull the the jammed paper out of the printer or the duplex tray. Put the duplex tray back in the printer.
13. Push down the blue lock lever and take the toner cartridge out of the drum unit. Clear the jammed paper if there is any inside the drum unit.
14. Put the toner cartridge back into the drum unit until you hear it lock into place. If you put the cartridge in properly, the blue lock lever will lift automatically.
15. Put the drum unit and toner cartridge assembly back in the printer.
16. Put the paper tray firmly back in the printer.
17. Close the front cover.
18. Make sure that the Paper LED is now off and the printer is ready.
After clearing paper jam if noise persist printer may need a Repair Tech and parts replacement for broken or wore parts.
Dec 04, 2009 | Brother Office Equipment & Supplies
PAPER JAMMED-PRINTER HL5150D
Hello a_bowen1
You can clear the jammed paper as follows.
Note
    • If a paper jam occurs when using the optional lower tray unit, check for correct installation of the upper paper tray.
    • Always remove all paper from the paper tray and straighten the stack when you add new paper. This helps prevent multiple sheets of paper from feeding through the printer at one time and reduces paper jams.
  1. Pull the jammed paper up and out of the printer.
  1. Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
hl50_05712.gif Caution
    To prevent damage to the printer caused by static electricity, do not touch the electrodes shown below.
  1. Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared, go to Step 7.
Note
    If you have to pull the paper toward the back of the printer, the fuser may get dirty with toner powder and it may scatter on the next few printouts. Print a few copies of the test page until the scattering of toner stops.
chap0615.gif Caution
    After you have just used the printer, some internal parts of the printer are extremely hot! Wait for the printer to cool down before you touch the internal parts of the printer.
  1. Open the jam clear cover. Pull the jammed paper out of the fuser unit.
  1. Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
  1. Pull the Duplex Tray completly out of the printer.
  1. Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
  1. Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
hl50_047.gif Caution
    To avoid print quality problems, DO NOT touch the shaded part shown in the illustration.
    If you accidentaly touch the shaded part, wipe the surface with a dry lint-free soft cloth.
  1. Put the drum unit assembly back in the printer.
  1. Put the paper tray in the printer.
  1. Close the front cover.
Good Luck and don't forget to leave a rating based on my solution:
Mark
Apr 04, 2009 | Brother HL 5150D Laser Printer
Kyocera Printer FS-1800 plus - paper jam Can't find the printer manual. Please provide steps to clear the paper jam and reset the printer.
Hi, first of all,pull out paper tray and check any paper,or scrap jammed.When paper tray is pulled out,open paper transport unit-You have green handle on the right side of machine,in the place of right side of paper tray.Pull out paper transport and remove paper.Just close paper transport unit and paper tray,open and close top cover.
Nov 29, 2007 | Office Equipment & Supplies
Swingline Shredder, Cross-Cut, Auto, 100 Sht Cap, 17"x12"x17", Black Logo
116 people viewed this question
Top Swingline Office Equipment & Supplies Experts
Paul Bade
Stitch85
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Swingline Office Equipment and Supply Expert? Answer questions, earn points and help others
