Question about Vacuums
Electrolux el8505 brush wont spin and buttons not working. turns on as soon as i plug it in and can only be turned off by unplugging :/
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 179 Answers
Have you taken it apart or has any work been done?
Posted on Oct 21, 2013
  • 2418 Answers
SOURCE: I have a electrolux Pronto 2 in 1 and the suction
There is a filter inside the main filter. Once that filter gets clogged it will loose suction. Pull the filter and clean it, you can wash it by hand. Turn the unit roller side up and check for a small screw cover that you can use a dime to loosen. This cover is used to remove the roller unit. Once out check and clean then check the gear assy. for miss-alignment.
Posted on Jan 27, 2011
dragonsthatk
  • 547 Answers
SOURCE: older electrolux canister brush will not turn used reset button
change the belt
Posted on Feb 12, 2009
SOURCE: electrolux epic series 3500 sr serial v87779 l
Sorry I didn't see this sooner. Your problem may be solved as simply as pushing the small red reset button exposed on top of the power head when you tilt the arm back. Very simple. Hope this helps.
John
Posted on Nov 05, 2008
askdyson
  • 2572 Answers
Official advice and support for Dyson technology
    Verified Fixya Pro
    SOURCE: brush inside main head doesn't spin, and stops
    Sorry to hear you're having difficulties with your DC14. If the brushbar won't run when the cleaner is in contact with the carpet, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
    Kind regards,
    Jack
    Dyson Customer Service
    Posted on Aug 12, 2011
    SOURCE: Electrolux EL8505 does not have suction. Hoses
    I had the same problem I found a clog in the hose between the beater brush and the canister. I used compressed air to unclog.
    Posted on Jan 02, 2012
    Why doesn't brush roller rotate?
    The ends may be clogged with debris. You will have to remove the brush roller and remove one end cap to disassemble the roller for cleaning.
    Jan 09, 2016 | Panasonic Mc-Ul594 Eco Max - Bagless...
    Where is the reset on electrolux EL8505?
    it may be the rocker arm located under the the switch.They are plastic and break,best bet is to take it to a repair shop Not too expensive of a fix
    Sep 01, 2014 | Electrolux EL8505A Bagless Upright Vacuum
    My electrolux vacuum has a red light that won't turn off and my brush roll won't work
    Check the belt and the end bearings are free by hand. (electric off plug out) if not free remove plate to access roller/brush, remove clear any obstruction (Hair/string/thread) replace and test. ensure you site belt back on to spindle and roller/brush correctly...
    Aug 22, 2014 | Electrolux Vacuums
    EL8505 brush will spin at only certain handle positions. The brush is unhindered and the belt is in position and in good order. The vacuum feels like it is sufficient. When the brush is not spinning the...
    Many vacuums have a switch positioned somewhere by the pivot point that is pressed when the catch is released and the handle taken out of the 90 degree storage position. I haven't worked on an EL8505 but I have fixed a couple other brand / model vacuums that were behaving the same way you describe in your problem. In most cases it is either a perfectly good switch that had moved out of position because the framing it is supposed to sit in is broke or worn down or a bad switch that only works when the plunger was in just the right spot.
    The link is a parts blowup of your vacuum and I think A-26 is the part you need. It appears to have both the bracket and the switch in one part. Make sure where it mounts doesn't have any damage preventing it from staying in the right place and alignment.
    Electrolux EL8505A Parts List and Diagram eReplacementParts com
    Mar 23, 2014 | Electrolux EL8505A Bagless Upright Vacuum
    The red "!" icon is on when I turn on my vacuum
    Button on CARPET, lower the handle for use, turn on power and the brush turns. Handle up like for storage, brush does not turn. Bare floor button pushed, does not turn.
    Dec 25, 2013 | Electrolux EL8807A Precision BrushRoll...
    Electrolux EL8505 does not have suction. Hoses have been checked. No warning lights on. Help
    Apr 27, 2011 | Electrolux EL8502 Versatility Bagless...
    There is a light on the top that looks like a cord that is on. the vacuum hose attachment does not work. I just changed a bag did i do something wrong
    The light with a cord "plug" on it indicates that there is power coming to the vacuum. This is normal.
    Assuming that the vacuum works, but not the power nozzle, turn the PN over to view the brush. Clear all hair, thread, fibers, etc., that may be wrapped aroung the brush. Use a sharp knife or scissors to cut through them for ease of removal. Make sure the ends of the brush are cleared as well. Try the vacuum and press the reset switch on the PN. Does it work?
    Is the PN motor running, but the brush isn't spinning. Turn PN over and try to spin the brush. If it turns freely, the belt is broken and needs replaced. This should be done by an authorized Aerus Electrolux service tech to avoid incorrect reassembly and resulting damage to vacuum and owner.
    If the brush doesn't freely spin, but turns with resistance, this is normal.
    If it still doesn't work, try the Sidekick mini power nozzle that should have come with it. If it works, but the full size PN doesn't, there's a problem with the PN. It needs to be taken to an authorized Aerus Electrolux store for diagnosis (free) and repair.
    If the Sidekick doesn't work, the problem is in the hose, wands, or canister. It could be due to bad switches, wiring, and other electrical problems. In this case, the entire vacuum needs to be taken to an authorized Aerus Electrolux dealer for diagnosis and needed repairs.
    http://www.aerushome.com/storelocator/
    Mar 06, 2011 | Electrolux Epic 6500 Vacuum
    The brush on ours wont spin
    Take out the brush roller. (turn the plastic lock mechanism with a coin or screwdriver, pull out the plastic holder, and the brush will pop out). The brush roller has two white caps on the ends. Chances are, one or both of these caps have moved out just a bit, putting too much force on the delicate motor. Simply push the caps back firmly into place. Make sure the brush and the surrounding area is clean, put back in and It should spin .
    Feb 25, 2010 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
    Vacuums Logo
    85 people viewed this question
    Top Vacuums Experts
    AskDyson
    AskDyson
    D. Floyd Kolb
    D. Floyd Kolb
    Are you a Vacuum Expert? Answer questions, earn points and help others
