Question about Irons
Turbosteamer 220 i have a turbosteamer 220. I plugged it in and the light did not come on nor is the steam coming out. The water heated up though. What could it be?
3 Suggested Answers
  • 883 Answers
SOURCE: Water and iron heats up but no steam comes out.
there is most likely a small port where some particles have clogged...fill reservoir with vinegar and water (50/50) and allow to soak 24 hrs, then reheat then shake vigorously to drain then rinse then retry
Posted on May 23, 2007
  • 3 Answers
SOURCE: I have a turbosteam 6060 sunbeam iron. It will
If I was you I would either go to the Sunbeam site and in the search box enter the model name and number and get a download a manual for fixing the iron or troubleshooting problems. If that don't work Send the Iron back to the company for a new one.
Posted on Feb 11, 2011
I have a domena steam press and there is water coming out and soaking the clothes. Water comes out as steam but as well as this it drops out as water.
Lime scale build up inside the elementchambers causing poor heat transfer to the water the steam being cooler thAn usual condenses back into water it reaches the porthole the steam is ejected from and you get this leaking effect steam and water together your need to professionally get the device descaled
Jul 03, 2016 | Irons
No steam coming throwc
Normally when water is put inside steam irons, it get stored in tank then if thermostat knob is set for steam then water moves to bottom heated portion of iron. Water converts to steam as base plate is hot, heated steam comes out through perforated holes. If holes are blocked due to scale formation steam flow is blocked. The descaling has to be done as per instructions given on descaling wax manufacturer. sometimes if water does not enter through a rubber washer that is water tank to heated bottom portion then also steam will not get generated hence no steam. Please check above points and identify the problem.
Jan 08, 2015 | Irons
Sunbeam steam valet instructions
How to fill your Sunbeam Steam Valet
Here is how you fill your Steam Valet. Press the small button on the back of the handle and pull bottom of handle apart from the top half of steam valet. Then take off the white cap on the inside of the handle and fill with water to top. Place cap back onto the opening and slide handle back and click in place. Plug in and you're ready to steam within a few minutes. If it spits out water let heat up a little longer if that doesn't stop it then tie a thin cloth over the top part where steam comes out to keep the water from spitting out onto your fabric. Hope these instructions are clear enough. More questions about this iron go to www.manualslib.com.
Feb 29, 2012 | Sunbeam Irons
I have a turbosteam 6060 sunbeam iron. It will not steam, just beeps and cycles off
Feb 11, 2011 | Sunbeam 3017 Iron with Auto Shutoff
I have a Russell Hobbs Steam Generator iron - less than two years old. It has started to leak water - not really sure where it's coming from - it just pours out and eventually fuses the plug.
My Russel Hobbs Steamglide iron has stopped pumping steam , iron itself heats up but no steam...has the pump gone and can it be reapired
Oct 08, 2009 | Irons
The iron seems like it is on but no steams come out I will mess with the wire and then too much steams comes out and I have water stains
Power Cord is bad and power cuts on and off not allowing the proper heat. When power cuts off you lose heat and the iron fills up with water and not steam then when power returns you have to much steam.
Jul 17, 2009 | Rowenta Irons
While ironing with steam, scale deposits came out through holes. how do I clean iron
You can try this out, fill the Iron with a considerable amount of water, Switch On your Iron, Increase the heat controller Knob to the maximum so that the water boils and Place it Upside Down (As if you want to Iron) but dont let it touch the Pressing Table. Then keep pressing the button that disperses the steam until the whole water inside it finishes, repeat this same process over and over until it comes out clean...
(Alternatively however, you can just pour hot water though the water-inlet hole, and after a while, shake the iron and turn the water out upside down and let it pass out of the water-inlet hole...but please be careful with this second method though...because of the hot water)...hope it helps.
Jul 10, 2009 | Sunbeam 4214 Iron
Conair steam cleaner sc20 - plugged in, pushed button, no steam
If you need instructions go to www.HandBookLive.com. There are videos for GS4 and GS10 under Appliances category. It says that steam is produced in about 5-6 minutes after you turn power on. Also there is a low water indicator light on GS10 that kills power to teh unit if the water level is low. Maybe that's the problem... Not sure if sc20 is similar
Apr 15, 2008 | Conair Compact Garment Steamer Iron
May 18, 2007 | Euro-Pro Steam Generator EP8001 Iron
Irons Logo
62 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
