Samsung HTD-5530 Home Cinema HDMI output connector
Samsung HTD-5530 Home Cinema HDMI output connector needs replacing, is this possible?
  • 12 Answers
SOURCE: samsung home cinema
http://www.dvdunlocked.com/unlock_dvd_player.htm
try that
Posted on Aug 10, 2008
SOURCE: Samsung home cinema system HT-THX25 Multiregion hacks
Turn on the HT with no DVD. Press the following buttons on the remote: ENTER 8, 4, 2, 6, 9 ENTER
It will turn off. When turned again on it is a region free HT.
Posted on Nov 26, 2008
SOURCE: i cant get my samsung home cinema system to play through my t.v
I bought the optical audio cable ($15 WalMart) and use the Digital In on the DVD player to play the sound through the surround system and turned the TV speakers off. Works great! The optial audio has square ends and looks transparent with just one round shaped cable that goes from the TV to the back of the DVD player.
Posted on Jan 01, 2009
notsomot
  • 67 Answers
SOURCE: connecting up a home cinema kit
Heya,
The good news is that the monitor and the Home cinema can be connected but you need to get a cable. Bad news is the cable did not come with it.
The monitor has D-SUB, DVI-D
so you need a HDMI to DVI-D connector then you need another cable to route the audio to the system which you should have.
like ebay item
Item number: 220341264176Hope it helps
Posted on Jan 10, 2009
ginko
  • 19396 Answers
SOURCE: SAMSUNG HT-TZ212 home cinema kit comes up with protect
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Posted on May 04, 2009
Hi I have a Samsung ht 350 home cinema,everything works fine good sound and everything but the only thing I don't understand is when I connect hdmi from it to the tv the Samsung goes in to prot mode??
Could be a faulty cable. Try changing the HDMI cable. Either that or the output from the TV is excessive. Check that the TV to make certain the HDMI output is the right kind.
Feb 14, 2016 | Samsung Audio Players & Recorders
Panasonic home cinema connection issues
What other audio/video outputs does the TV have? Does it have an HDMI port? If so, connect TV to your home theater using HDMI to HDMI.
Jun 07, 2013 | Panasonic SC-BTT490 5.1 3D Home Theater...
How connect toshiba tv to samsung home cinema whit hdmi? i connect but still no sound. i want watch tv but listen in cinema sistem
the hdmi jack on the tv is an INPUT jack, not an output. to use your reciever for tv sound, you have to find the audio output on the tv (most do not have an audio out, but some higher end tv's have a fiber-optic digital out, which may or may not be compatible with your surround sound reciever)
if your tv does not have an audio out, the only way to get the tv sound into the styereo is to use a tuner box, like a cable box or satelite box. tuner boxes always have either hdmi or stereo audio outputs.
to use hdmi with your surround sound, you are supposed to run HDMI OUTPUT from the tuner box or disk player into the HDMI INPUT of the stereo, and then run the HDMI OUTPUT of the stereo into the HDMI INPUT of the tv.
Mar 12, 2011 | Audio Players & Recorders
I have an LG TV with an LG HOME CINEMA SYSTEM problem is: watch dvd/blue ray - video fine sound fine (through speakers) watch tv / sky -- video fine sound None throughspeakers on...
There are two things that I can suggest.
1-Test your optical cables to make sure they a good on a known working source because they are very fragile and break very easily.
2-Try to eliminate the use of optical output from tv to receiver. There may be a problem from the HDMI to optical conversion at the tv. Instead, try running the audio directly from the source to the receiver, and let the tv deal with video input only.
Hope this helps,
Good Luck.
Jan 07, 2011 | LG Audio Players & Recorders
Is it possible to connect an LG 5010 tv to a
Yes, you can connect any home system into the TV by either using a scart or HDMI connector to produce the picture on the TV. The sound will still be present through the cinema system
Nov 22, 2009 | LG 42LC2D 42 in. LCD HDTV
Connecting ps3 to home cinema
For sound use the Digital Coax in, if the PS3 has digital out. Most HiFi home cinema systems have HDMI with all channels audio through HDMI. Check cinema settings to configure input for hdmi audio, also check PS3 audio output setting options to include all supported audio type by your receiver. It's not just a plug and play. Both systems need to gor through a user setup process to make sure they sync and play well with each other.
Jul 24, 2009 | Audio Players & Recorders
Samsung series 6 tv & Samsung 2:1 home theatre problems
if you got all the lead you should have fibre optics which connects from dvd to tv and then set your dvd to digi in. you should get the sound. i have same cinema system and i have done the same
Jan 13, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Connecting up a home cinema kit
Heya,
like ebay item
Jan 10, 2009 | Wharfedale Televison & Video
Optical output
optical output from the tv can only go to an optical input on another device.
hdmi is for picture only.
what tv and home cinema make and models do you have?
Nov 12, 2007 | Samsung HP-R5052 50 in. Plasma HDTV
HDMI conection
Hi.
Connect the Home cinema and the TV with the HDMI cable. When you turn it on, first turn on the TV and then the home cinema. I hope this works.
Oct 07, 2007 | Samsung HT-HDP40 - 800 Watts 5 Disc HDMI...
Televison & Video Logo
Top Televison & Video Experts
