Question about Frigidaire FPCO06D7MS
Frigidaire FPCO06D7MS top lamps burned out - Frigidaire FPCO06D7MS
What would cause both oven-top lights to blow out - not burn out BLOW OUT? It has happened twice. Have had light switch repaired in control panel.
maybe to much wattage on the lamp and de water vapors from the food come in contact with the lamp be to hot and blow out.
Mar 04, 2016 | In Microwave Ovens
The light inside the microwave has burned out and I do not know how to replace.
Open the top front panel, and the lamp is located at the top.
Sep 23, 2015 | GE Microwave Ovens
Microwave smell like burning rubber
Good Afternoon Friend,
I understand that you are receiving a burning rubber smell from your Frigidaire microwave. I also see that your appliance will run for a couple of seconds, and then you hear a weird noise, followed by a burning rubber smell. I suggest contacting your local authorized technician, especially when dealing with your microwave. They will be able to diagnose your appliance and determine what is causing that sound as well as the burning rubber smell. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire Microwave Ovens
I have a plmv178hc Frigidaire microwave oven. The oven completely stopped working today in the middle of cooking a 3 min. meal. Nothing is working on it the breaker didn't go off and the outlet is working....
You need a microwave fuse. Also the reason for it blowing fuses may be that it's time to replace the capacitor inside. It may be time for a new magnetron too. If you have the top open look to wires that burned in two and may be touching the frame If that is so you may not need any parts at all. Also check the thermal cutoffs (button looking safety equipment)
Oct 22, 2013 | Frigidaire GLMV169D Microwave Oven
How to replace burned out light bulb
You need to remove the top cover to access the bulb. That is the only way on most microwaves.
Dec 02, 2011 | Emerson MW8107WA Microwave Oven
Replaced the burned out lamps in the counter top light fixture and the switch no longer functions. Tried each lamp separately and together and same result. Just stays on.
It sounds like the switch has fused shut, it may just need jiggling on and off a few times to free it, turn off the power before you try that. The switch can easily be checked by a competent engineer with a meter. It does seem an unlikely coincidence though, are you sure you haven't twisted the lamp fitting as you inserted the lamp, thus shorting something? Check none of the fittings are loose or twisted
Jan 27, 2011 | Whirlpool MH7130XE Microwave Oven
How do i replac the interior light on my frigidaire fmv156dc microwave?
We have the service manual and have uploaded it to our site here to help you.
From page 33:
OVEN LAMP and Lamp Socket REMOVAL
1. Disconnect the power supply cord, remove the oven from
the wall and remove the outer case. (Refer to procedure
of "Removal of Oven from Wall" and "Outer
Case removal ".). And proceed as follows.
2. Open the door and block it open.
3. To discharge the high voltage capacitor, wait for 60
seconds.
4. Remove the three (3) screws holding the hood intake duct
R to the oven cavity top plate, the oven cavity front flange
and the fan duct. And remove the hood intake duct R.
5. Turn the lamp socket and release it from the magnetron
duct.
6. Screw the oven lamp off from the lamp socket.
7. Now, the oven lamp is free.
8. Pull the wire leads from the oven lamp socket by pushing
the terminal hole of the oven lamp socket with the small
flat type screw driver.
9. Now, the oven lamp socket is free.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 10, 2011 | Frigidaire FMV156DC Microwave Oven
Replace Lamp
Your owner's manual should cover it if it is intended to be removed by the consumer.
If not, then you'll have to remove it from the wall and tear down the oven to get to it.
You should be able to find the installation instructions here.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites. We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
May 05, 2010 | Frigidaire PLMV169DC Microwave Oven
How do you change interior 20 w lamp?
remove the 3 screws on the vent above the door. Next unplug the oven from the power source.Next you will see a single silver screw above the control panel..remove it and slide the control panel upward and out. This will give you access to the lamp socket...turn it left or right and pull slightly ...you can now unscrew and replace the bulb....It was my exp that the lamp got loose in the socket from slamming the door after about a year, and I only had to tighten the bulb..Hope this solves the problem...Jerry
Mar 19, 2009 | Frigidaire FMV156EM Microwave Oven
Frigidaire FPCO06D7MS Logo
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
