Question about Seiki 26" 720p LCD TV - SC261FS
Seiki 26lcd menu pops up - Seiki 26" 720p LCD TV - SC261FS
Seiki 42 inch 4k tv won't recognize wireless router signal on newly purchased tv
Make sure your network is running and that your set is receiving a good strong signal. Then go to your set menu and use the network menu to set up seet to tv - follow the prompts . If no result, contact mfg to guide you through the exercise. If set is bogus return for another one.
Sep 12, 2017 | Seiki Televison & Video
How can I get my seiki TV to turn on when its plugged in the red light won't come on it just pops on for a second then flashes off when I plugged it in to the power
That can be problematic if that happened. You'll need to obtain a service /repair manual from Seiki's website to find out how to put the TV in the service mode in order to flash the firmware again
Oct 01, 2016 | Seiki Televison & Video
1 hdmi1& 2 inputs on seiki TV don't work modelSE39UY04-1 how do I fix it
First thing to check is the menu options to see if they are enabled. IF they are then you are looking at the main board being bad: http://tvchopshop.com/tv-models/seiki/se39uy04-1/
Jun 02, 2016 | Seiki Televison & Video
Why does menu screen keeps popping up?
ain system control memory IC fault. Check and replace it.
Dec 26, 2015 | Seiki Televison & Video
How to reset Seki tv when it goes off and will not come back on
Seiki hard reset tv factory settings Flat Panel Televisions ...
www.fixya.com > ... > Flat Panel Televisions
Seiki flat panel televisions hard reset tv factory settings related questions and answers. Ask your Seiki questions. Get free help from flat panel television experts.
How to reset a seiki hd tv that keep reading no signal? - The ...
www.askmefast.com > Family & Relationships > Singles & Dating > Signal
To reset your seiki hd tv you just need to press on the menu: 0000 The TV will ....Getting to factory settings seiki tv ..... "How to reset seiki tv that reads no signal?
FAQ's ' seiki
Dec 19, 2015 | Seiki Televison & Video
How to get rid of a black square on my 40" seiki tv . I tried everything
The Closed Caption function is set in the "text" mode. To remove it, access Closed Caption in the Main Menu and change the Mode setting from "text" to "off".
Feb 25, 2015 | Seiki Televison & Video
I have sound but no picture on my 32 in Seiki T.V. Model no. SE322FS What is my problem?
turn on the tv. press menu? can you see a menu? if not. your tv requires service.
can you see a menu? might be a connection issue. if you can see a menu respond
Feb 18, 2015 | SEIKI Digital SE322FS 32" LED TV 1366x768,...
Seiki tv menu keeps coming on
  • Seiki is very good with problems if you purchase your TV less then a year ago call them and they will take tv back and fix it no charge and they won't charge shipping either Good luck Joe
Apr 22, 2014 | Seiki SE221FS 22 in. TV
The menu options keep poping up
I doubt this is a user fix. There is a problem in a mother board .
I would run to the warranty and try to replace it.
Mar 09, 2014 | Televison & Video
How do I reset SEIKI TV?
I have a seiki 32in. tv. The sound bar keeps jumping back to no volume mode then when i go to the menu it is jumping around so bad you cant click on anything, please help
Mar 20, 2012 | Televison & Video
Seiki 26" 720p LCD TV - SC261FS Logo
Top Seiki Televison & Video Experts
Andrew Taylor
Andrew Taylor
shaun taylor
Are you a Seiki Televison and Video Expert? Answer questions, earn points and help others
