I need a Dianz cbb60 mkp sh 8uf capacitor for a ryobi bench grinder.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 24 Answers
You can get these at any ac/heating parts houses such as ferguson rsd or allied...you will need to have contractors license to purchase from these parts houses...try getting one online
Posted on Oct 22, 2013
2 Suggested Answers
SOURCE: i need a Dianz cbb60 mkp sh 60uf capacitor for a log splitter. Dianz does not carry them anymore.
TITON PRO 370 is the substitute capacitor you need. It is the only one that will fit in the switch box. (TRC60)
60MDF, 2" dia, 4 7/8" long, Motor run capisator
Posted on Aug 21, 2013
I need a Dianz cbb60 mkp sh 80uf capacitor for a Quick Split log splitter.
take it as a sample to any motor rewind/repair shop and they will have a match
Jan 09, 2017 | Cars & Trucks
I have a Ryobi bench grinder and the grinding belt keeps slipping to one side have tightened to maximum and the belt says its for a Ryobi
it is slipping to one side because the pulley on the end is not aligned correctly
on the adjuster arm that holds the front pulley there is a lever or knob that you use to adjust alignment ( instructions in user manual) find that adjustment and slowly move it while the belt is running
you will see the belt running position change to you get it properly aligned
each belt regardless of ryobi or generic will need adjustment after fitting
Nov 27, 2016 | Bench Grinders
How to change a grinder blade on a ryobi grinder
Handheld grinder or bench grinder? I'll assume you're asking about a handheld grinder.
Engage the arbor lock. You may need to rotate the wheel until you find the spot where the arbor lock locks the wheel. Use a wrench or a gloved hand to unscrew the wheel (I use my bare hand). Screw the replacement wheel on and disengage the arbor lock. The new wheel doesn't need to be very tight, it'll tighten itself as you work.
Jul 15, 2014 | Saws
I need a Dianz cbb60 mkp sh 60uf capacitor for a log splitter. Dianz does not carry them anymore.
Mar 27, 2012 | Heating & Cooling
My ryobie bench grinder keeps tripping the rcd within a second of turning it on?
Assuming your local tech confirms that your bench grinder tests ok. The problem is probably that the grinder draws too much current for the RCD and is therefore detected as an earth leakage. High amperage devices often do that. Your best bet would be to plug it in to a socket which is on a non-rcd circuit. Maybe you have an RCD on the whole house though? I would start with returning the grinder and trying a different brand with a lower amperage/wattage rating. If that doesnt work, I would call an electrician to discuss installing a different RCD or running a separate circuit for your power tools.
Mar 03, 2011 | Jet Industrial Bench Grinder 6in new
Given a bench grinder which did not work. How to test/fix?
I cleaned all the wiring connectors etc and used a 4-way extension cord with an i/o switch and thermal/arc breaker surge protector thingy. I had a piece of thick cable with a molded three prong plug which I had removed from a dead paper shredder (I think??) and connected the ground to the case (previously not connected) the black to the black and white to the white. I taped the connections and plugged the test cable into the extension thingy with its switch off and plugged it into the wall outlet. Then, with the grinder switch on, I gingerly switched on the extension thingy and the grinder (sans all moving parts) ie just the motor case and spindle (held securely in the B&D workmate) and viola(!) it worked fine and built up to very fast. I switched off the grinder switch and the motor slowed, taking an age to come to rest.
Then, I fitted a grinding wheel on the left hand thread end, tightened everything and retested, using the grinder switch to start it and it spun really fast.
Soooo, I guess the secure ground is an essential feature of a capacitor induction motor. I checked some old furnace motors that were "maturing" in the basement and they had no capacitor but only 2 wires...
I am now trying to remember which parts came off last and put it all back together. I plan to test it each time I put a part back...just in case. I hate it when you fix something on the bench and when rebuilt, it won't work...don't ask about the electric starter on the snowblower..not a happy puppy!
Please, pretty please and then some, do tell me if my "fix" is wrong and I could risk all kinds of nastiness.
Thanks,
Jenni.
Jan 24, 2009 | Grinders
Heating & Cooling Logo
127 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
