Question about Dishwashers
Whirlpool adp 252 MICRO SWITCH ON BOTTOM PLATE. WHAT IS THE PURPOSE?
2 Suggested Answers
  • 196 Answers
SOURCE: Whirlpool Dishwasher ADP 252 model
Sounds like you have a heating problem. Machines with a timer are controlled by the thermostat, so it wont click on until the machine reaches the correct temperature. Is the water hot? If yes then you need to replace the thermostat and high limit stat. If not hen it will be either the stats or element. Most likely the stats.
  • 2q==
They typically look something like this, but if you visit an online spares site and select your make and model it will give you a breakdown of all the parts. To change put machine on its side and remove the bottom panel, this will give access to the components. If not then tilt machine back and remove the front kicker plate and the the panel in behind. The stats will be at the front of the appliance for access. Hope this helps
Posted on Mar 14, 2011
How does the whirlpool adp 252 function?
http://www.manualsdrive.com/captching.php?lang=en&search=WHIRLPOOL+DISHWASHER+ADP+252+VIEW+USERS+GUIDE#.U2zBnVf1WIw
May 09, 2014 | Dishwashers
Whirlpool Dishwasher ADP 252 model (old) It will start with the program and then just stopped. I have to turn the knob to carry on with the next step of the program. Maybe dirty? Can I clean it somehow?
  • 2q==
Mar 14, 2011 | Whirlpool Dishwashers
My whirlpool adp 4552 keeps on flashing 7 times...whats the problem?
This is not a solution, but a start. There should be a tech sheet somewhere with the dishwaser. Often it is stuck to the back of the kick plate. In this, or possibly in your owners manual, there should be a list of "error codes" This should explain what the seven flashes mean.
Good luck
Nov 17, 2010 | Whirlpool Dishwashers
Whirlpool dihwasher adp 4552. Water comes into dishwasher, appears to start cycle then water is drained out again and light flashes to show a problem!
This is a typical anti flood activation due to the anti flood device (polystireen float and micro switch) at the base of the washer detecting a water leak / spill. This device puts the washer in pump out mode. Check to see if water at the base is causing the polystireene float to activate the switch. Dry the water and rectify the fault (normally a leaky pipe or pipe clamp) and this should solve the problem.
Mar 25, 2010 | Dishwashers
Whirlpool adp 6600 will not function start light is just flashing
Whirlpool adp 6600 will not function start light is just flashing. Waht di I do?
Sep 17, 2009 | Whirlpool 24 in. ADP6940 Dishwasher
Ice won't dispense, suspect switch in door cover. how to remove door cover to check? Oddly enough, my ice maker stopped working AND the switch in the door (or other circuit problem for dispensing) failed...
Insert a small putty knife between the dispensor plate and the dispensor cover about 1-2 inches from the sides and press down and inwards . Do this carefully because there are 2 plastic "clips" at the bottom . Once bottom is free , lift upwards and the cover will come off . Remove the plug and it's free . There is a white contraption , large , that have 2 rods the micro switches clip onto and sometimes , the switch on the left , has the broken rod holding the micro switch . This causes no ice dispensing .
Aug 15, 2009 | Whirlpool ED2GHEXN Side by Side...
Whirlpool Dishwasher ADP 4601 , Light flashing constantly.
There is a switch attached to the door latch that may need to be replaced. (the switch is inside the door).
Feb 08, 2009 | Kitchen and Much More Dishwashers
Whirlpool adp 5540
My dishwasher isnt working anymore after i cleaned the filters? i took out and cleaned the filters in it and now it doesnt seem to be working properly. it goes thru the cycle but its not cleaning. the dishwashing tablet falls to the bottom and isnt even dissolved completetly after the cycle has finished. is it possible that its blocked somewhere?
It is a Whirlpool ADP 5540
thanks for your help
**** the walls are still dirty after the cycle but there is steam in there as if its done its normal cycle
May 13, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
Dishwashwer not cleaning properly
You can try one of the cleaners sold for this purpose like glisten, dishwasher magic or jetdry dishwasher cleaner. It may not be getting enough water due to the fill valve clogging up. You can check this by small amounts of water slowly with a cup in the wash cycle and quickly opening the door to see if the upper sprayarm is turning. If more water helps you need to replace the valve.
Apr 18, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool adp 8540 - 7 flashes
replace the control board in the console
Apr 10, 2008 | Dishwashers
Dishwashers Logo
20 people viewed this question
Top Dishwashers Experts
